Question about Hoover F6020-900 SteamVac Upright Vacuum
Pickup water wont pickup the water after putting it down very little comes up into the tank .it worked fine when we baught it but after not useing it for some time it worked now it wont **** water up at all can anybody help.
    Problem Solver:
  • 14 Answers
The clear shroud covering the front of "hood" has two sheet metal type screws at the bottom in front of the brushes, these two screws also hold the little straight brushes ( one on each side) in place. I found one of these screws had broken it's plastic "socket" and was no longer applying any pressure to the hood, this caused loss of suction and would not pick up any water...You can test this by applying a little pressure to the "clear hood" after you have applied water and shampoo. You should immediately see water entering the pickup reservoir container. I removed the broken plastic "socket" and replaced original screw with a longer wood/sheet metal screw. I think this is a weak point on the cleaner and is easily broken by catching the front lip on any hard object. Hope this helps
Posted on Apr 18, 2009
Steam vac won't suck up water from cleaning rug. I did not press trigger for vacuum, I checked vacuum, brushes and recovery tank. All look ok.
Check the little gate on the back of the return tank and make sure it is seated well. If not seated it will stop the water pickup.
Jul 16, 2017 | Vacuums
Biseell little green machine wont squirt water out
The Pumps on these go bad after a couple of months. They rust and will sometimes spray and other times not then eventually not work at all. If your a handy man pull the top off it and remove the pump motor and replace it yourself. The part number is 603-5029 you can put this number in google shipping and get it to your door for about $15 and replace it yourself or have a friend do it. Ebay has tons of them once again just put in the part number and a list of them will come up.
Thanks and have a good one
Sincerely, CRTN
May 22, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
No water spraying out
Problem; No water or solution
After taking the unit apart TWICE trying to determine the problem I finally realized that the rubber washer on the bottom of the solution tank had come off the tank. It was stuck in the drain - I pulled it out of the drain and put it back on the bottom of tank. Now the tank could sit down properly on the drain. As soon as I put the tank back on the machine, bubbles came up through the solution in the tank indicating that solution had drained into the system as it was supposed to.
I started up the machine and it worked like new again.
Jun 28, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hoover steam cleaner wont pickup water
in the front on top the cover that curves down to the floor is where the suction is .it should be plastic you can see into.its probably clogged with hair and dirt.you need tro take that top off and it comes apart in two sections .the middle seperates from the outer part.once apart you can clean it with soap and water.after you get that off you will see on your left side a long square port that needs to be cleaned also.please leave feedback.i hope i was of some help to.pete
Apr 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Jan 10, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
Dirt/Collection Tank Bissell Little Green
I had the same problem, so I took out the black stopper, and soaked the whole thing in bleach water for about an hour, then I took a hand full of " aquarium " rocks and put them inside the tank, and shook them inside using a bit of the same water and then got rid of the rocks,( the rocks worked as an scrubber ) .... it worked pretty good
Sep 22, 2008 | Bissell 1400 Little Green Pro Canister...
Hoover floormate
The tank sits on what is called the reservior asm. it is actuated by the control rod inside the handle. With the tank off, watch and see if you can see that rod hitting the reservior asm when you squeeze the trigger. If it is moving up and down on it, then the resorvior asm may be bad. Also check the valve at the bottom of the tank, manually push it in and see if it releases water.
Feb 18, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Bissell Quicksteamer
the problem is that after used you have to run clear water through it. the reason is that once you put it away there is still soap inside the tubes. after some time the soap gets hard and clogs it. in the case of the machines that have the heat the heater is also full of hard soap.
good luck
Nov 26, 2007 | Bissell 1770 Quicksteamer II Upright...
Bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Nov 06, 2007 | Bissell ProHeat Turbo Deep Cleaner Upright...
Polti Vaporetto 2400: Water out light comes on when tank is full
Hi you need to put 5ml of Kal Stop fo Polti machines into 1000/1500ml of water into the tank, The stronger solution is better (1000ml) Let it heat up and this should break down the limescale on the solenoid. I tried this today and it has worked saving ££££'s in repair by Polti.
Nov 04, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Hoover F6020-900 SteamVac Upright Vacuum Logo
150 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
