Question about Kenmore 24032\24036 Top Load Washer
Kenmore spin cycle issues
We are having issues with our washer. It stops abruptly when the lid is open. The drum can no longer be moved by hand. Also when it is in spin mode it either isnt spinning fast enough to draw the water out of the clothing or it isn't draining. Clothes are still soaked after spin cycle. We have had this washer for about 6 years.
    Novelist:
    Champion:
  • 261 Answers
Does it agitate and spin at the same time? the motor has a pump on one side and gear case on the other. if the gear case is seizing then the pump is lagging because the motor is loaded from a seizing gearcase and the gear case needs to be replaced.
Posted on Sep 04, 2008
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Washer won't spin. Belt is slipping. Tub is stuck.
The belt sounds worn out since its slipping. Change it out. Its cheap fix.
The drum brake does just what is sounds like. brakes the drum. For instance when u open the lid during a cycle and everything stops thats the drum engaging and stops the movement of teh drum. If the brake is malfunctioning two things will happen, you open the lid (assuming the safety switch is still good) or the drum will not spin at all.
Aug 24, 2009 | Maytag LAT3600A Top Load Washer
Kenmore machine stopped spin. Checked the
Check your lid switch. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If not activated by a lid strike, other models have the lid switch located under the washer casing next to one of the lid hinges. It is activated by a rod contacting an actuator. The mounting scews for this type are located under the operator console.
If you determine the switch to be defective, the following link explains how to access the washer interior and replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of a replacement is $25 to $35.
If you have questions, please let me know. I hope this helps you.
Key Symptoms:
If the Motor Coupling were bad the washer will not agitate or spin, but WILL drain.
If the Lid Switch fails, the washer will fill, but stop before the spin cycle and WILL NOT drain.
Aug 23, 2009 | Washing Machines
Kenmore 110 washer drum spins with lid open during Rinse/Spin
Slow agitator could be linked to shaft bearings going south. Pull the agitator off and check the block on top of the shaft. With everything turned off, try to turn the shaft. It should turn freely both ways. Other things to slow down the works could be a very worn drive belt from the motor.
The lid switch problem seems to be a wiring short--trace the wiring back from the switch to where ever it ends up (at the timer?). If it winds up at a relay, the contacts may be stuck together. It would be nice to have a wiring diagram--ah well. Don't know if any of this helps, good luck.
Jul 16, 2009 | Kenmore 22422 Top Load Washer
Washer stopping abruptly at end of spin cycle.
Hi, it sounds like maybe some dust has gotten in the basket drive pads causing it to stick. Has it been happening long? Sometimes it will work its way out. Try turning the tub with your hand clockwise. You can also put a heavy load in the washer (wet) and let it get to a high spin. Then open the lid and see if it starts stopping slower.
If this doesn't clear its self up, you will need to change the basketdrive.
Please let me know if this has helpped.
Thanks
Vic
May 17, 2009 | Kenmore 15864/15862 Top Load Washer
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Drum won't spin
check the lid switch plastic tongue mounted some times front--,,lid right hand side,this is a safety measure switch,when lid is open it disables the spin cycle-------tom
Aug 22, 2008 | Kenmore 25842 Top Load Washer
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
111 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
