Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
Noise vacuum making a very loud noise but suction seems to be ok
  • 1 more comment
  • Anonymous Oct 07, 2008
    Smae problem - so loud it hurts my ears to use. Suction ok but not great.
  • Anonymous Oct 28, 2008
    Terribly loud noise when turned on, but the vacuum still works pretty good. It is a beltless system... so that could not be a solution.
  • glitter101gi Nov 06, 2008
    my vacuum still runs, but makes a horrible noise. This would be the 4th time I have had to take it in to get fixed, and i would like to avoid not having my vacuum for 2 weeks.. HELP
  • 281 Answers
You might have something stuck in the motor fan like a paper clip or a bobby pin.might have picked up a coin or a nail.regardless it sounds like its in the motor need to disconnect the base from the upper half of the vacuum to get to the motor.on the top of the base on each side of the motor you will see a small plate with 2 screws on them take them out and you should be able to seperate the base from the top half of the will see the motor housing and on one side you will see the fan.look and see if something is stuck in the fan.if so try to get it out and put everything back together start from the last thing i explaind all the way up to the first thig i explained
Posted on Apr 10, 2009
    Problem Solver:
  • 7 Answers
I have the same problem with the same age Kenmore. I checked for clogs but there were none. The loud noise sounded like a vibration. The noise was so loud you almost couldn't be in the house when using the vacuum. What I found was, the outer rubber housing of the motor/fan was held together by electrical tape and split at the electrical tape (wow, that's a surprise!!). I taped the housing together with fresh tape but the motor housing continued to split when the filters got slightly clogged and higher pressure was generated inside the motor. I suspect that the split was causing some amount of air from the motor to be exhausted into the inside of the vacuum causing internal parts to vibrate and resonate.
I haven't been able to fix this problem. Unfortunately, the excessive vibration caused a control board to fail which controls the agitator. At this point the vacuum is useless. Poor design by Kenmore so I don't know if it can be fixed.
If you know of a solution, let me know
Posted on Dec 05, 2008
  • 55 Answers
What does this noise sound like? If it's a squealing noise, chances are that it is a belt going bad. You can purchase a new belt at your local Sears, or probably even your local grocery/department store. The vacuum belt is easy to replace and inexpensive. Instructions for belt replacement are in the owner's manual, or sometime on the belt's package. Hope this helps... Please take a few seconds to rate how helpful this suggestion was. Thanks and good luck!
Posted on Sep 12, 2008
Vacuum works quietly and well when using the wand attachment, as soon as it is lowered into 'floor vacuuming' position it makes a very loud noise but doesn't seem to lose suction.
Hi Ismaias, it's Jack at Dyson.
The issue you're describing sounds unusual. If you think the noise coming from the cleaner head and brush bar is excessively loud, you might like to follow the steps shown in the video below to make sure nothing is jamming or obstructing the brush bar:
If you're confident there are no obstructions, but your machine is still sounding much louder than it should be, please do not continue to use your machine. At this point, it would be best to contact the Dyson Customer Helpline directly so we can provide further assistance. If a repair or a replacement part is needed, we can also confirm if this is covered under your Dyson warranty.
When you have your DC50 to hand, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 22, 2015 | Dyson DC50 Animal Upright Vacuum Cleaner
Making loud high pitched noise and no suction. Belt seems fine
Sounds like something is clogged/blocking the intake hose. Pull off your bin & see if you can feel/see anything blocking that hose that everything goes thru.
Jul 08, 2011 | Bissell Vacuum - Momentum Cyclonic 1 ea...
My Kenmore bagless intelliclean vacuum is making a loud noise mainly when it is vacuuming on the highest setting (when the light is red). We have taken it apart and cannot find a clog. It has also lost...
This might help, it was posted on a previous problem but is the same issue you are having it seems: "Here is a possible solution. If the vacuum sounds normal when the green light comes on, then the issue is a suction bypass. Kenmore built a suction bypass in to help cool down and protect the motor should someone either never clean the filter, empty the canister or somehow manage to clog the hose. There is a spring holding the bypass closed and is overridden by vacuum suction. I guess the spring becomes weak, allowing high suction to pull it open which in turn reduces suction so it closes again. It can do this several times per second making a loud racket and slightly affecting performance until the sensor goes green, then the vacuum suction is too low to overcome the spring tension thus why it sounds fine then. The trick? The very hard way (what I did) was to open the vacuum, open the casing where the spring is and pull it apart slightly to increase the spring tension. The easy way is to put tape over the hole where the bypass is. The inlet is under the hose track on the back on the right side as you're looking at it. The hole is about the size of a quarter and you'll see fins across the hole. The tape would keep the suction. The motor would still pull back the bypass but since tape is applied, there would be nothing to reduce the suction thus keeping performance and reducing the noise. However, this circumvents the intended design so you do so only at your own risk."
Dec 27, 2010 | Kenmore Progressive Bagless Upright with...
suction wise have you checked the internal pipes on your vacum as for the load noise if it is quite a load noise a humming noise it is ure motor so not worth fixing motors r pricey for a vacum
Feb 03, 2010 | Kenmore Vacuums
The engine in my vacuum is making a loud rattling
if its over a year old junk it if not it would be under warranty
Dec 14, 2009 | Bissell 3102-0 EasyVac Upright Vacuum
Filters all seem clean and clear, suction is fine,but loud noise
Sounds to me it could be tha fan impellor.
This is vac's etc... email us if you need to.
Nov 04, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
He dyson is making a very loud grinding noise
The belt that rotates the beater bar may be damaged - call the Dyson helpline for troubleshooting and for a solution to the problem.
Jul 03, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Loss of suction, loud blowing noise
Try cleaning out the vortex this will sort out poor suction.
Oct 16, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
348 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
