Question about HP Photosmart C5280 InkJet Printer
How to scan to Apple computer
HP machine instructions show "scan & print" or "scan to memory card".  I want to scan into my computer but there is no instruction on how to accomplish this.
    Problem Solver:
  • 14 Answers
It sounds like your HP isn't seeing your computer since the only options it's offering do not relate to a computer. Have you checked to be sure your computer is seeing your printer? Can you print from your Apple to this printer?
Also, Apple has a utility called Image Scan that might work for you. Double click on the hard drive, then go to Applications>Image Capture and see if that program will see your HP. If it will allow you to select the HP. If it doesn't see it, you might be able to go to Devices in the menu at the top and have it search for the HP. You might need to use the TWAIN UI to help you connect.
I have found Apple computers to be more difficult to attach (and keep attached) to scanners than PCs (even thought i hate to admit that!)
Posted on Aug 29, 2009
Can you just give me a link or quick advice on scanning with HP photosmart c5180? I would like to to scan and save to disk/save to laptop.
Scanning with HP Solution Center Software in Windows
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02455373&cc=us&lc=en&dlc=en&product=1153481&tmp_track_link=ot_search#N43
FROM THE MANUAL ON PAGE 14 http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf Scan an image You can start a scan from your computer or from the HP All-in-One. This section explains how to scan from the control panel of the HP All-in-One only. To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must also be installed and running on your computer prior to scanning. ? On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running. Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software. ? On a Mac, the software is always running. Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One. To save a scan to a memory card 1. Make sure your memory card is inserted into the appropriate slot on the HP All-in- One. 2. Load your original print side down in the right front corner of the glass. 3. Press the Scan Menu button. 4. Press to highlight Scan to Memory Card, and then press OK. The HP All-in-One scans the image and saves the file to the memory card in the JPEG format. To scan a photo and reprint it 1. Press Reprints. 2. When prompted, load your original photo print side down on the right front corner of the glass, and then do one of the following: To reprint your original photo using the default print settings ? Press Print Photos. To change print settings before reprinting your original photo a. Press OK. Basics Guide 13 HP All-in-One overview b. Press or to highlight a paper size, and then press OK. The paper size choices available vary depending on your country/region. Note Depending on the paper size you choose, you might be prompted to choose a layout for the photos on your pages. c. When the Fix Faded Original? prompt appears, highlight Yes or No as appropriate, and then press OK. The HP All-in-One scans your original and shows a preview of the photo on the display. d. Press OK to display the selection menu. Tip If you want to print more than one copy of the selected photo, press to highlight Copies, and then press OK. Use the arrows to increase or decrease the number of copies. If you want to edit the photo before printing, press to highlight Edit Photo, and then press OK. e. Press to highlight Done, and then press OK. The Print Summary screen appears. f. Press or to highlight one of the following options, and then press OK. Print Options Enables you to manually specify the type of paper on which you are printing and whether you want to print a date and time stamp on your photo. By default, the Paper Type is set to Automatic and the Date Stamp setting is set to Off. If you want, you can change the defaults of these settings with the Set New Defaults option. Print Preview Displays a preview of what your printed page will look like. This enables you to verify your settings before printing and wasting paper and ink on potential mistakes. Print Now Prints your photo with the size and layout you selected. To scan to a computer 1. Load your original print side down in the right front corner of the glass. 2. Press Scan Menu. 3. Press to highlight Scan to Computer, and then press OK. 4. If the HP All-in-One is connected to one or more computers on a network, do the following: a. Press OK to select Select Computer. A list of the computers connected to the HP All-in-One appears on the display. Note The Select Computer menu might list computers with a USB connection in addition to those connected through the network. Chapter 1 14 HP Photosmart C5100 All-in-One series HP All-in-One overview b. Press OK to select the default computer, or press to select a different computer, and then press OK. The Scan To menu appears on the display, listing the applications on the selected computer. If the HP All-in-One is connected directly to a computer with a USB cable, proceed to step 5. 5. Press OK to select the default application to receive the scan, or press to select a different application, and then press OK. A preview image of the scan appears on your computer, where you can edit it. 6. Make any edits to the preview image, and then click Accept when you are finished.
Jun 05, 2011 | HP Photosmart C5180 All-In-One InkJet...
I have a Mac w/Snow Leopard. I cannot get to hp.com\support to download drivers for an Office Jet 7780. The Mac recognizes it as a printer but not as a scanner.
As from this link , the drivers for most HP printers are already built-in to Snow Leopard. Thus, they didn't recommend reinstalling driver from your HP printer CD. Here are some excerpts regarding scanning feature on Snow Leopard from the link: Scanning: The Scanning interface is now built into Snow Leopard and supported with the Apple Image Capture application. Instructions follow. NOTE: HP Scan Pro software (from Mac OS X 10.4, 10.5) is not supported in Snow Leopard. The HP icon for HP Device Manager still in the dock after upgrade is not functional and should be removed. NOTE: Scan support from pushing the Scan button on the printer is not supported with this version of the scan interface built into Snow Leopard. Scan functionality is supported by scanning directly from the computer.
** there are methods on how you can scan on Snow Leopard from the link that I've given above. But I'll paste here Method 3:
Method three: Scan from Print & Fax > Printer browser
  1. From the Apple menu, choose System Preferences .
  2. Click Print & Fax .
  3. In the list of printers on the left side of the dialog, select the HP All-in-One to view the options in the Print & Fax window.
  4. Click the Scan tab, and then click Open Scanner . The Printer Browser window appears.
  5. Click the Scan icon at top right of the toolbar to launch scanning. The scan interface opens. Click Show Details to view settings and options.
Important Gotcha: If the Scan or Print icons do not appear in the Printer Browser window toolbar, you need to delete the current HP printer queue and add a new one, as follows:
  1. Close the Printer Browser window to return to the Print & Fax preference pane. Or, go directly to the System Preferences > Print & Fax pane.
  2. Select your HP printer in the list on the left.
  3. Click the - sign at the bottom of the list to delete the product from the list.
  4. Click the + sign at the bottom of the list to add the product back to the list.
  5. Select your HP printer, and then click Add to create a new print queue. The next time you open thePrinter Browser window, the Print and Scan icons should appear in the toolbar, providing access to Image Capture.
Oct 22, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
There is no "Scan to Computer" option on my printer
Hi
It was my solution which was sent as clarification request.
Choose "Scan&Print" . It creates a file and saves. you have to find the location by doing a search.
luciana44
Aug 30, 2009 | HP Photosmart C6280 Printer
Can I scan pictures to my computer?
Yes ... your all-in-one can print, copy and scan.
Scan an image
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
● On a Mac, the software is always running.
1. Press Reprints.
➔ Press Print Photos.
a. Press OK.
Basics Guide 13
Defaults option.
2. Press Scan Menu.
Jul 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
Scan to Computer
open the solution centre s/w and then populate the destination folder list and the scan to list in the scan settings window.
see if it works...
Feb 03, 2009 | HP PhotoSmart C4180 All-in-One Color...
Hp psc 1350 all-in-one
Source: HP support
( Click link above to read complete article and instructions )
Introduction A full feature software and driver package for Windows Vista is not available for your product. However, the Windows Vista operating system installed on your computer contains a basic driver solution for your product. With the basic driver, the buttons on the product do not function and some of the advanced product features are not available. But you can still print, scan, and import and view images on a memory card, using the workaround procedures in this document. Use the following instructions to install the basic driver in Windows Vista, and then review the workaround procedures to use the available features for your product. Installing the printer driver When you connect the product to the computer, Windows Vista detects the hardware and automatically installs the correct driver. A notification lets you know when installation begins and when it is complete. You do not have to download any software or insert the product CD.
  1. Turn the product on.
  2. Connect the Universal Serial Bus (USB) cable to the printer and to the computer.
  3. A Your devices are ready to use window might display on the screen. If the window displays and does not close automatically, close the window.
Workaround procedures The basic driver in Windows Vista is sufficient for several functions. You can print from a software program, scan documents, and import and view images on a memory card. Printing Use these steps to print from a software program.
  1. Open the document to be printed in the software application in which it was created.
  2. Click File , and then click Print .
Scanning Use one of the following three methods to scan a document. Method one: Scanning with Windows Photo Gallery
  1. Click the Windows (c01367391.gif ) icon.
Oct 06, 2008 | HP PSC 1350 All-In-One Thermal Printer
HP Printer
Try this :-
Installing the printer driver in Windows Vista
Verify that the printer is turned on.
Print a test page to verify that the printer is working correctly.
Using the basic printer functions
Printing: - Open the document to be printed in the software application in which it was created.
Click File and then click Print.
Scanning: - Scanning with Windows Photo Gallery
Click the Start (c5af1ed.gif) icon.
Click All Programs.
Click Windows Photo Gallery.
Click File and then click Import from Scanner or Camera.
Click Import.
Click Scan.
Scanning with Windows Fax and Scanning
(NOTE: This feature works only with Windows Vista Ultimate, Windows Vista Business, and Windows Vista Enterprise)
Click the Start (9c4e39e.gif) icon.
Click All Programs.
Click Windows Fax and Scanning.
Click New Scan.
Click File and then click Scan.
Scanning with Paint
Click the Start (b95b750.gif) icon.
Click All Programs.
Click Accessories.
Click Paint.
Click File and then click From Scanner or Camera.
Click Scan.
Importing and viewing images on a memory card
Remove the memory card and then re-insert the memory card into the appropriate memory card slot on the printer.
(NOTE: See the User Guide that came with the printer for more information on how to insert the memory card in the printer)
On the Auto play screen that displays, click Import Pictures, View Pictures, or Open folder to view files.
Follow the instructions that display on the screen.
Using the advanced printer functions
(You might find that some of the advanced features are no longer available when using this basic driver. You can upgrade to an HP product that is fully compatible with Windows Vista if the advanced features are necessary.
To help you decide what product to upgrade to, click here for information on upgrading the product go to this link or copy and paste it into Browser :-
http://h30216.www3.hp.com/ASA/Controller?adi_hasScript=1&_AD_195R22=110&adi_scriptSID=DF57657645AF158516628FE76C76392C&sysid=84&appid=10251&_ad_stoken=sup&jumpid=re_r10602_advisors/adi/sd
Jul 22, 2008 | HP DeskJet 3940 InkJet Photo Printer
My new hp photosmart c6250 will not print to my computer. the menue only gives the option to reprint or scan to memory card
I reinstalled the program and will control the printer from my computer. The scan menu still does not say, 'scan to computer', as the basic guide book says that it should.
Jul 17, 2008 | HP Office Equipment & Supplies
HP Photosmart C5280 InkJet Printer Logo
994 people viewed this question
Seeker5211
Seeker5211
