Question about RCA F32450 32" TV
Green light flashes 3 times
What does this mean i cant get no picture and it wont turn on green light just flashes 3 times then goes off
  • RCA Master
  • 5,138 Answers
Bad Flyback transfomer most likely.
Posted on Sep 17, 2008
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Tip
Pix shuts off, green light starts flashing, pix comes back and shuts off again
If you have an issue where your picture turns off and the green power light starts flashing, you are most likely looking at a weak or old lamp. Do not be confused with a pix loss and a RED light flashing, as this can be caused by many things. The normal sequence of events for this fix is this:
1) TV turns on normally, plays for 1 to 3 minutes (may be more or less time)
2) Picture goes out and green power light begins flashing. It may flash for up to 2 minutes
3) green light turns on solid (stops flashing) and picture returns.
4) Picture goes out again and process repeats.
You may have been told that "if the lamp light isn't on, it isn't a bad lamp".
FALSE!
A weak lamp will cause the process above to occur. Other signs of a weak lamp:
The reflector in the lamp is very cloudy
You may see a "growth" or "bubble" on the vertical glass tube which is the lamp
You haven't replaced the lamp in quite some time or it is the original lamp from when you purchased the TV.
In cases like these, try a new lamp. Stick with an original Sony lamp, as there are many stories (both personally witnessed by me and also documented on the web) about problems with after market replacement lamps. And remember, lamps DO NOT have a shelf life; you can store them in a good environment (not too hot or cold!) for an indefinite period with no ill effects.
on Nov 03, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Wd62627
It could be your power supply board.
Jul 23, 2013 | Televison & Video
I have a SONY KF-WE50 rear projection tv, a few weeks ago it started to turn the pic and sound off while the green light was flashing around 30 times. After the light finished flashing both the picture and...
the green is the reboot process and is normal.
the red light is an error code indicator.
count the blinks of the red light...it cant be 30 times (I think)
it will blink a sequence, pause, then do it again for a total of three times.
count carefully, it gives you three chances to catch the number it is blinking.
Apr 13, 2011 | Sony Televison & Video
When i turn on my playstation3 it wont turn on. It was workin
Your motherboard is damaged I would send it to be repaired.
Feb 06, 2010 | Sony Playstation 3 (PS3) Console
WS-55517 Mitsubishi Rear HDTV projection tv will not turn on
2 blinks followed by 1 blink is the X-Ray protection-----means some problem in the High voltage circuit ---set produces over 25 thousand volts to fire the 3 picture tubes inside up----It could be excessive high voltage-------I think you would have to get lucky for someone to find and fix it in your home----more likely it will need a visit to a Repair shop.
Aug 20, 2009 | Mitsubishi VS-50605 50" Rear Projection...
WHY WONT MY 7280 CHARGE OR TURN ON
The red light indicates its charging.  My guess is that the battery is dead and will nto hold a charge.  This is an older model phone and the lives on the batteries is 1-3 years at most.
Jun 04, 2008 | RIM BlackBerry 7280 Handheld
Vivitek tv
I have a 56" model that I have had a similar problem. My bulb burned out in <90 days. Warranty was 90 days on the bulb itself. When the TV picture goes out, the indicator LEDS blink on and off.
Here is what you have to determine:
1) First cover the left LED with a piece of paper so that you can't see it blinking. I don't know if your layout is the same as my TV. You may have to switch the paper blocking the LED.
2) Pay attention to the other LED and READ its' flashing code. In my case, the code was 2-3. It would flash 2 times, pause briefly, then flash 3 times. This meant code 23. That indicated the bulb was burned out.
3) If you look in the manual, It does have a code list of some sorts to tell you of the codes and their meanings. Hope this helps.
Nov 20, 2007 | Vivitek V37835 46 in. LCD Television
RCA F32450 32" TV Logo
113 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
