Question about Bosch Axxis+ WFR 2460 Front Load Washer
Bosch WFK2401 Drain Pump
When the drain cycle starts, he machine starts making a clicking sound - sounds like coins left in the tumber, but the sound does not ary with the tumbler speed, rather with when water is being pumped out. Other than the noise the unit works fine.
John Austin - Boulder, CO, USA
  • johnkaustin Aug 27, 2008
    Yes - and it was even a penny!
  • fuzzy10 Oct 17, 2008
    I had the same problem.  After reading this I checked the drain pump housing and found a Penny too.  Alas the clicking sound is fixed but the main motor is not turning.
    Is it as easy as changing the motor?
I have a WFL 2060 UC on the bottom right there is a small access door. Inside the door you will find a drain plug which will unscrew counter clock wise. Water will come out so I tipped up the machine and slid a 1" deep cooking pan under the corner. When I unscrewed the plug I found a penny inside.
Posted on Aug 26, 2008
My Bosch WFK2401 washer has stopped filling. The cycle will count down and the pump will run to drain (but nothing to drain!). I have checked the supply lines, there is water and the filter screens are...
I suspect the solenoid on the water input connection has failed, this is the unit that allows water into the machine , if you know a bit open the lid and you should see this just inside behind the cold water connection.
Oct 20, 2013 | Bosch WFK 2401
Bosch wfl 2060 washing machine makes a funny rattling sound when it should be spinning or draining. why
Check the filter behind the flap (Bottom right of kickplate) souns like you have a coin or other foreign object in the pump.
Feb 18, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Splendide 2000S Vented Washer/Dryer makes a bad noise once in the rinse cycle and water will not drain
Check the drain pump. There may be a coin, hairclip , button etc stuck in the blades of the pump. If the machine cant pump out, it wont go through the cycle.
Sep 17, 2017 | Splendide 2000S Vented Washer/Dryer
Started making loud "clicking" noise
Blocked pump, open flap bottom right, drain off excess water manually and remove pump filter. Make sure you get right down and have a look in at the impellor and give it a turn to make sure its free to rotate. You'll probably find a coin, button etc that is catching the pump impellor. When you start a cycle the pump engages for a few seconds and then the w/m takes in water, so if something is stopping the impellor rotating the w/m will not start.
Best of luck
Jul 13, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch WFK2401 won't start error code 6
Open the panel at the bottom using a 2p coin by turning clockwise
Pull the rubber hose out of the holder and drain water into a container until stops
turn large plastic screw to the left for access to the pump
Clear away and debris bits of metal, plastic, etc that has stopped the pump.
Opposite of above to reassemble
Switch on and test... good luck!
Mar 23, 2009 | Bosch WFK 2401
My bosch wfk2401 front loader is stuck on spin
There is a door bottom right of the system which has a screw out (by hand) plug.
Remove this and ensure there are no foreign objects such as coins, bobby pins etc stuck.
I have found this to be a problem with the Bosch systems and cost me $150 the first time.
Ensure you have some towels as when you open the plug, water will escape
Mar 04, 2009 | Bosch WFK 2401
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch Axxis+ WFR 2460 Front Load Washer Logo
198 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
