Timer part number if timer is under cabinet 4903790100 If mounted in cabinet # 4903790200 Both located to the left of compressor in back. Control Board # 4308600385 if you have the newest modelTimer part number if timer is under cabinet 4903790100
You can't post conmments that contain an email address.
I would agree with the the last poster just one final thing to check make sure the bottom of your fridge in the back of your fridge is dust free dust builds up on the condensers and they get blocks and they don't work as efficiently and also make sure there's the correct space between the back side top and bottom of the fridge according to the specifications I don't have them with me but you should have them in your user manual if you have one.
If it is frost free? the door may have been left open, and warm air taken in, This in turn creates frost to form around fan, Best thing to try is, Empty it, switch it off, and leave doors open for couple of hours! this will defrost any ice or frost build up.
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Sounds like the defrost system of your freezer is not working. It could be either the defrost timer, defrost thermostat or the heater has a problem. The defrost timer turns off the compressor periodically to sent power to the defrost heater via the thermostat. The defrost heater then powers up and heats the evaporator coil to melt the accumulated ice buildup on the cold coils. Most likely issues are that the timer motor is not advancing the timer or the heater itself has burned out.
check the door seal on the top of the door if not sitting flat to the frame it will encourage frost to build up (inside the little grid thing)which will stop the rest of the freezer from cooling enough.
hi i have same problem one of my lodgers left the door open and it froze thick with ice i defrosted it and let it dry for 3 days and was fine for a couple of days then it defrosted so i switched it of for 24 hours it worked fine for a day before it defrosted again could you email me with any help thanks [email protected] matt
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
