Question about Electrolux Kitchen Ranges
Electrolux oven edb715 Lower oven does not heat up but the fan still works. Could this be due to a burnt out element and if so how do I relace it?
  • 639 Answers
Hi edb,
Happy to help you!
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Posted on Aug 25, 2008
Bosch HBN 70 Fan oven will not heat up to temperature, fan and light are working just no heat
99% of the time the problem will be a faulty element or burnt off wire at the element terminal. Best way is to pull the back cover off the oven and check the terminal connections. If these are okay put a set of test lamps across the terminals and you should have 240 volts. If you have 240 volts this tells you that the wiring is okay and the element is faulty. When you turn the oven setting to fan forced selection the power is delivered to the fan forced fan motor and the oven element at the same time. I am not familiar with this exact oven but most fan forced ovens have two fans. There is the fan at the back of the oven that comes on with the oven element and then the extractor fan in the cavity of the oven, which you cannot see but can hear. I trust you are talking about the fan forced oven fan which is generally at the back of the oven.
Feb 05, 2011 | Bosch Kitchen Ranges
Tip
Common faults with Belling 317 Range
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BELLING fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BELLING oven thermostat
4, A quite common and easily overlooked answer is if your BELLING oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 17, 2010 | Belling 317 Electric Kitchen Range
Tip
Common faults with Belling 335 Range
on Jan 17, 2010 | Belling 335 Electric Kitchen Range
Hi my Smeg dual fuel range no longer works on the fan electric oven. The fan runs but get no heat. Is there an element specfically for the fan oven
YES THERE IS AND IT LOOKS LIKE THE ELEMENT HAS BURNT OUT DUE TO NORMAL USE OVER TIME , REPLACE THE ELEMENT AND YOUR OVEN WILL BE LIKE NEW .
Nov 16, 2009 | Kitchen Ranges
Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
Hello stevefer
Welcome.
You said, Your Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
First,
1.What is the Model Number and the year of your wall oven?
2.Did the oven light up and display with any error codes?
3. Did you try to turn the breaker off for 5 minutes to see if this will reset the system?
Perhaps the heating element is failing and may need to be replaced.
I will be able to better assist you when you reply with this information.
Waiting your response.
Huuum
Oct 16, 2008 | Kitchen Ranges
Tip
Common faults with Belling DB90 Range
on Jan 17, 2010 | Belling DB90 Electric Kitchen Range
Tip
Common faults with Belling FarmHouse 932
on Jan 17, 2010 | Belling FarmHouse 932 Dual Fuel (Electric...
Edb705w fan oven element burnt out - replaced element - oven stil not working ?
have you reset clock after turning off to repair? you may have it set to auto
Oct 08, 2008 | Electrolux Kitchen Ranges
I have a Electrolux EXC643 Oven. When you turn on the oven, set to 200 deg C for example, the oven fan and light works, but the oven stay's cold. The circuit breaker has not been tripped, at any point....
circular element is almost certainly open circuit. often the breaker will trip when element goes faulty but not always. take rear cover off and check for continuity
Jul 08, 2008 | Electrolux Kitchen Ranges
Kitchen Ranges Logo
168 people viewed this question
Top Electrolux Kitchen Ranges Experts
Electrolux
Electrolux
Richard Roth
Richard Roth
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
