Question about Acer Aspire 5100-5033 Notebook
Noisy fan after a few minutes start up
I have an Acer Aspire 5100 laptop which I got in the end of November last year. Now it was running fine, until a few months ago when I moved it to the side to plug the power cord back in, there was a noise where the fan it. It was loud and made me think it was gonna blow up lol. Anyway(I **** at describing sounds), I got it looked at, but it didn't do the noise, only when it was moved around. Which was fine, I could still use it. Then it was offline for three weeks and I started using it again which is ran fine until yesterday when it would start up. I turned it onto hibernate which normally gets rid of the noise, and when I started it up, a few minutes would go by then bam, the noise starts again. Sometimes the noise starts when the laptop gets turned on but then goes away again.
Also, its worth mentioning the other day, when I turned it back on after the three weeks(we had a powercut, then storms so I kept it off), it made this high pitch sound which disappeared. Does anyone know whats going on here? The high pitch sound hasn't happened again, its just the noisy fan.
Yeah. i had this problem too. the fan is noisy because it is garbage. it needs to be replaced if you want to get rid of the noice. you moving the laptop wen the noise first started is just coincidence. the heatsink is fine, but the fan itself is poorly made. The ball bearings get loose and so the fan doesnt stay in its vertical plane and it kind of shakes a little, thats why it makes the noise. if you open it up and turn your laptop on, and wait for the noise, you will notice that if you push down lightly on the center of the fan, the noise goes away, because you are creating pressure at it's center of gravity point which makes it stop wobbling. you wont see the wobbling with the naked eye, because its much to slight to see, but its definatly enough to make that annoying fighter jet take-off noise..
as far as the noise, thats the sound it makes when something is wrong with the battery (if you ever drain it all the way down and try to boot it, it will make the noise) kind of messed up noise in my opinion, but its not a big deal, as long as it doesnt repeat.
for the fan, you dont need to replace it if you dont use your laptop a lot, you can try to keep your laptop cooler to keep the fan from turning on also. i suggest one of those USB fan pads that you put under the laptop, or a thermal pad, thermapak makes one for $30 i think, and it drops temps by 6 degrees celcius they claim, i dont know exact numbers but if def helped me. you can also try to put something in the back to keep the back elevated (where all the heat is) and the fan wont spin as much.
i know with desktop fans that get lots of use, noise is the 1st sign of fan failure to come, but ive been using my laptop with that god awful noise for about 4months now, and its still alive and kicking.
good luck!
Posted on Oct 13, 2008
How to fix noisy fan?
look for the fan opening, get a can of air and blow it threw the fan vent, while the computer is off, than let it set for a few minutes than start it back up, if fan is still noisy, than you need a new fan installed.
if you want to do the work yourself you can do it your self. now if you dont want to try it than i have a few place to take it for service.
acer authorized dealer, best buy, or if you have a friend that you trust that will fix it for little to nothing except cost of parts, the fan part for the acer should be around 7-10.00 dollars + labor + shop fees. TO FIX LAPTOP CPU FAN
/how disassemble acer aspire laptop
/how to replace CPU fan acer laptop
/how to oil cpu fan for acer laptop
Apr 22, 2015 | Acer Aspire Computers & Internet
Hello, i have a Acer Aspire 5100 Laptop which i bought in 2007. Recently i have started having problems with HD-Ready videos (720p). before when i use-to play 720p videos on my laptop it use to run...
As you say the laptop handles the video well in the beginning, then when it runs for a few minutes it has trouble rendering the video in sync with the audio.
The reason for this problem is that 720p videos need the Graphics card in the laptop to work hard, this process generates heat and this heat needs to be removed from the laptop or the whole system does what's known as throttle down.
It slows down to reduce the heat it produces, thus preventing damage to the system.
The solution to this problem is to clean as much dust out of the laptop computer as possible, use a vacuum cleaner. Turn the laptop off and remove the battery. Clean the vents, it is a good idea to raise the back underside of the laptop with a pencil or the like. Some-thing that will raise the laptop off the work surface without obstructing the vents on the underside of the laptop. By raising the laptop it will allow for greater airflow through the laptop, therefore reducing the operating temperature of the laptop therefore making it more efficient and responsive.
Your laptop shuts itself down, this confirms that it is overheating. It does this so it does not damage itself.
If it still overheats then you will need to contact a computer technician to give it a good through cleaning. To clean the dust between the heatsink fins. Possibly increase the fan speed or replace the fan.
Take care!
Jun 10, 2011 | Acer Aspire 5100 Notebook
Ever time i start up my acer aspire 5100 its coming up an invalid arument encountered how do i get rid of it plz have i unistalled a program or something to do with acer
try to run system restore first remember the last date that your acer aspire 5100 works properly and if the same problem coming reinstall your operating system this 100% will correct solve your problem.
Sep 16, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 5100
Sounds like the power jack is loose if you have to hold it in a certain position. As for the screen your inverter might be shot. Try connecting an external monitor to your laptop and see if you get a display.
Sep 08, 2009 | Acer Aspire 5100 Notebook
ACER Aspire 5100 powers down at will
When you turn the laptop on hit f8 until the menu comes up, try use the last good known configuration. If that does not work tap f8 goto safe mode and then to system restore and restore it to an earlier time. Let me know if it works.
Apr 15, 2009 | Acer Aspire 5100 Notebook
Acer aspire 5100 won't stay on when booting on battery
replace the battery. Batteries usually only last about two years and it sounds like it just cant hold any more juice. To find a battery go to and type in the model of computer and push search. Sorry for the news but its an easy fix
Dec 30, 2008 | Acer Aspire 5100 Notebook
Laptop Overheating
i have read lot of same type of problems,with acer,if it is under warranty send it before end, there is fee of 449.00 for out of warranty notebooks. my 5100's have problems,very unhappy! with acer good-luck!
Jun 21, 2008 | Acer Aspire 5100 Notebook
Possible Video problem with Acer Aspire 5102.
are the fans running??
could be slight heat problem.
google for speedfan.
a utility to control fan speed on most laptops
Feb 01, 2008 | Acer Aspire 5100 Notebook
Acer aspire 5100
look on the front of the lap top for a button fo rthe wireless network and turn it on
Jan 13, 2008 | Acer Aspire 5100 Notebook
My Acer aspire 5100
If you are able, when the pc is booting up keep pressing F8, this will take you to safe mode and not allow the graphics driver to run. When in the safe mode options, select either Last known good configuration or start windows in safe mode. Last known good configuration should find the last good system settings, when it reboots. Start windows in safe mode allows you to go into windows using the administartor account, and then you should select system restore and restore back to the day before or just before you updated the graphics driver.
Aug 16, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100-5033 Notebook Logo
1,006 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
