Question about D-Link AirPlus DWL-G630 802.11g/b Wireless Adapter
My Windows 2000 keeps coming up with Network Cable Unplugged
I have been working on this for about 10 hours, please help me!
Sfvh
Posted on Nov 19, 2008
Why slow startup (10 min) and slow printing (+ 1 hour)?
www8.hp.com/us/en/support.html
Sounds like you may have a mechanical problem with the printer itself.
Aug 18, 2014 | HP PhotoSmart C4180 All-in-One Color...
How to fix looping idetifying with wireless and internet connections
Identifying network ... endless loop [Solved] - Configuration ...
www.tomshardware.com > Forum > Windows 7
Tom's Hardware Guide
Jan 12, 2012 - 28 posts - ‎6 authors
My desktop is stuck on "identifying" when I try to get an internet connection. My laptop wireless works fine. I have uninstalled all network drivers ... Solution for Windows 8 Internet Slowness [Solved ...
Nov 11, 2012
Laptop stuck on "Identifying" network - Configuration ...
Dec 12, 2010
Keeps cycling between Network Cable Unplugged and ...
Mar 19, 2010
More results from www.tomshardware.com
May 01, 2014 | Microsoft Windows 7 Ultimate for PC
Network cable unplugged
Make sure that the cable is not plugged into the uplink on the router. That it is plugged in to a numbered port.
Mar 13, 2014 | TP-Link Technologies TP-Link TL-WR841N...
2004 Emachine- when desktop comes up on lower right there's a flashing icon when clicked on says "Network Connections", Local Area Connection, Network Cable Unplugged, Intel{R} PRO/100 VE...
If the local area connection icon specifies as network cable unplugged, then the computer has not sensed the connection between the computer to the cable modem / DSL modem, please reseat the cable behind the cable / dsl modem to the computer. If the icon still shows unplugged, then change the network cable between the two.
If the issue still persists, please revert with more details lik the kind of internet connection used and the reason for reinstalling.
Jan 04, 2011 | E-Machines eMachines Desktop PC
Won't rewind or record. Has been "updating" the menu more than usual.
tarajo435,
Have you unplugged your 625 receiver yet? If not, unplugged the receiver for about 10 seconds and plug back in. This will cause the receiver to reboot and acquire satellite signal. When the picture comes back on, try to pause. If it still doesn't work, we may need to replace the 625 receiver. I hope this helps.
Ray Calo
DISH Network
Jul 02, 2010 | DISH Network DVR-625 DTV Receiver /...
A network cable is unplugged
OK, in order to solve this problem, I will need more information:
1) What is your operating system (i.e. Windows XP? Windows Vista?)
2) Is this a laptop or a desktop computer?
3) If it is a laptop, is there a switch on the case that turns on and off the wireless ability? Check your user manual - it might be as simple as turning on the wireless switch.
4) If it is a desktop, what kind of wireless adapter did you install?
I'll be able to help more when I get this information. In the meantime, here are a few things you can do:
First of all, you need to delete all of the duplicate connections from Network Connections. They won't really hurt, but they're not helping either. To delete them, just right-click on them one at a time and choose "delete."
Next, you need to understand what the message "a network cable is unplugged" refers to: this has nothing to do with wireless. If there is no actual hard-wire cable connected to your computer, the port (that's the opening that you plug a network cable into) will tell Windows that it is empty. This results in the message "a network cable is unplugged." You can ignore it, or - if you plan to use this computer with a wireless connection only - you can right-click on the connection in Network Connections and choose "disable." This stops the message from appearing, and can be reversed (enable) at any time.
I look forward to hearing from you.
Jan 04, 2009 | Televison & Video
I have a wireless g pci adapter and it is installed on a computer running windows 2000 server. It is supposed to receive the signal from the wireless router wrt54g. It does not find the signal but somehow...
Hi, did you run the CD before you connected the adapter? I know the box says 'easy, no set-up' but there usually is a CD that needs to be run BEFORE connecting the device. If thats done, try bringing up the 'connect to a network' interface, selecting your network and click connect. If you have set up a wireless security password, enter it and click connect. The network cable unplugged is normal when you are running a wireless setup. I hope this is of some help.
Apr 27, 2008 | Computers & Internet
No internet connection
I think the reason for this is that maybe your ISP's server might be down or there might be no connectivity from their side.For me, a good tool that works is Windows Live Messenger's Connection Troubleshooter.It helps most of the time.Run it and keep clicking on repair till you get your connectivity.
You can download Windows Live Messenger from here :
http://get.live.com/messenger/overview
Hope this helps.Tell me if you need more help.
Nov 27, 2007 | Microsoft Windows XP Home Edition
Using G630 but get "network cable unplugged" message
A little confusing this, it would not say 'Network cable unplugged' if windows was refering to your D-link wireless connection(It's wireless) The cable unplugged should be refering to your Wired Ethernet card, so there must be no cable connected at one or other end. You don't mention anything about what the wireless card is trying to connect to(eg Wireless modem/router or another wireless PC). Maybe your pc is getting confused as to whether you wish to connect wirelessly or wired, as it can only work through one IP Address at a time. i could be wrong, but you probably thought that they were working but only one was, you really need to explain why you are using both wired and wireless and what is connected to what, Please reply and hopefully it'll get sorted
Oct 26, 2006 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
D-Link AirPlus DWL-G630 802.11g/b Wireless Adapter Logo
63 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
