Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Lid wont close
Just changed cartridges for the first time and now the lid will not close.
  • jandj232301 Aug 31, 2008
    I changed my ink and my printer says I am out of ink, and will not print. How do I fix this
  • 21 Answers
For jandj232301.... Most likely your print head is clogged, there are 2,00 some nozzle's in it. If the printer is not used for a moderate amount of time the ink can dry up and cause a clog in those nozzle's. You can try doing a printhead clean from the main menu, or homecenter->?->maintenance. Then after that do a calibration, print a demo sheet to see if there is any improvment. The printhead clean pushes ink through the nozzles to try to clear clogs. The calibration scans those nozzles to see which are avalible to use, and makes sure that all the avalible nozzles are being used. If this does not fix the problem you most likely need a printhead but you will have to call kodak; as they are not avalible in stores. Also you can try updating your firmware from kodak home center, or www.kodak.com/go/downloads
Posted on Sep 02, 2008
5 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: Lid won't close
remove cartridge, make sure there are no obstructions anywhere, and then try it again.
Posted on Mar 28, 2008
AldRezaine
  • 995 Answers
SOURCE: changed cartridge, closed the lid now wont stop
Did you properly or surely remove the sealer on the cartridge? If you did it, then you should try the following below:
1) Take the cartridge off and put it back, make sure is in the right way.
2) Push the cleaner bar all the way were it belongs.
3) Press the "on" button for 10 seconds.
4) Disconnect the printer and have re-start.
5) Call a friend that knows about electronics.
Also, you could check HP's website. You can troubleshoot your particular problem here:
http://h10025.www1.hp.com/ewfrf/wc/docum…
Posted on Nov 15, 2009
  • 10406 Answers
SOURCE: says copier lid open
The small "sensor" that should "trip" when you close the lid is not engaging. Blow a little compressed-air into that micro-switch, so that it works correctly.
Posted on May 07, 2010
SOURCE: canon mg6100 printer scanner...open the
just push it down, It feels like it is stuck up, but just push it down it will go
Posted on Apr 19, 2011
How to change the ink of printer Epson stylus Office BX300F. Show me in the computer to change the ink in printer now.
Turn on your printer and raise the lid or press the cartridge changing button. Wait for the cartridge carrier to slide out.
Lift the cartridge holder lid, and the cartridge will pop up for removal.
Carefully remove the tape from the ink opening on the bottom of new cartridge.
Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
Close the cartridge holder lid and press the cleaning button to charge the cartridge.
Close printer cover.
Watch here full details:-https://www.youtube.com/watch?v=8gL5xoiDenA
Still unable to change the ink, you should go to customer support at +1-800-243-0051 ' +1-800-243-0019
May 05, 2017 | Epson Office Equipment & Supplies
HOW TO CHANGE CATRIDGE
Purchase an ink cartridge made specifically for your printerTurn on your printer and raise the lid or press the cartridge changing button Wait for the cartridge carrier to slide out. Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal. Carefully remove the tape from the ink opening on the bottom of new cartridge. Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been. Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned. Close printer cover.If you have an Epson printer, close the cartridge holder lid and press the cleaning button to charge the cartridge.
Sep 06, 2011 | Computers & Internet
Top lid will not close after fixing a paper jam
Often times the lid will not close if the toner cartridge is out of place. Will the lid close with the toner cartridge removed? If it does then reinstall the toner cartridge and make sure that it is fully seated.
Sep 02, 2010 | HP Laserjet P4015x Printer
I lifted the lid to change the ink cartridge and the cartridges go to the left and then back to the right where I cannot get to them
Withe power on, lift the lid, on light will flash, wait 15-20 seconds, manually pull the ink cartridge to the left. It will not return untill you close the lid again. If you cahnge the ink you will get the question about which ink cartridge did you just change, this happens the first time you want to print something. Answer the question and you are done done.
Dec 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Lexmark x85 multifunctional, not recognize cartidrige color
The cartridges are only installed through the printer itself and there is no installation of cartridges through the Lexmark software. You should ensure the Lexmark X85 has the cartridges installed in stand-alone mode. To do so, please follow the steps given below:
1. Push the "Menu" button 10 times, until "Maintenance" appears.
2. Then hit "Select" and "Change Cartridges" should appear.
3. Hit "Select" again. It will prompt you to open the lid and change the cartridges. Please do so.
4. When the lid is closed, the display will ask you if new or old cartridges were installed. If new, it may ask you to align the cartridges and you should do this too.
If it is not noticing a change, remove and reinsert the cartridges about 3 times in a row to re-establish pin connections. If this still presents you with a "Change Cartridge" or "Low Ink Level" message or something similar, try a different cartridge.
Oct 17, 2009 | Lexmark X85 All-In-One InkJet Printer
HOW DO I CHANGE INK IN AN EPSON SX200
Hi
Thanks for using FixYa. Turn the printer on. Now raise the lid of the cartridge cage and wait for the cartridge carrier to slide out. Lift the cartridge holder lid and remove the cartridge. Before installing the new Cartridge, remove the tape from the ink opening point on the bottom. Now insert the new cartridge into the cartridge case and close the cartridge holder lid. Close printer cover. After doing all the above steps, print a test page.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 26, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Get message error change cartriges the cartriges are new
All cartridge installation and level reporting is done through the printer itself, not the software. You should ensure the X125 has the cartridges installed in stand alone mode first. To do so, open the lid and remove the cartridges. Then unplug the power cord for one minute. Reinsert the cartridges, connect the power cord and close the lid. When the lid is closed, the display will ask you if "New" or "Old" cartridges were installed. If new, align the cartridges, if asked to do so. If this still presents you with a "Change Cartridge" message or something similar, please try a different cartridge.
Apr 22, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
Can't change ink on dell 810. what do I do first? I don't know how to change ink in dell 810,I couldn't see how to take old one out as well and how to put new one please
Lift the priner unit lid on the printer llift he print cartridge lid,
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
Press down on the ink cartridge lever to raise the ink cartridge lid.
Remove the old ink cartridge.
Dispose of the old cartridge properly.
If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
Insert the new ink cartridge.
Snap the lid closed.
Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed. Let me know if you have any questions.
Apr 14, 2009 | Dell 810 All-In-One InkJet Printer
Changing ink cartridge
Mar 07, 2009 | Epson Stylus C86 InkJet Printer
I need to change the ink cartridges on epson stylus sx200 but i need help as instruction book doesntreally tellyou how-thanks
buy an ink cartridge made specifically for your printer. Turn on your printer and raise the lid or press the cartridge changing button. 3 Wait for the cartridge carrier to slide out. with an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal. Carefully remove the tape from the ink opening on the bottom of new cartridge. Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been. 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned. with an Epson printer close the cartridge holder lid and press the cleaning button to charge the cartridge. Close printer cover.
Dec 09, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
161 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
