Question about Cameras
I was in the middle of shooting a wedding, when suddenly my camera said that it was 'busy' - it was taking a while to go back to normal, so I decided to shut the camera off and just turn it back on again (I didn't mind loosing the last image). When I turned the camera back on... all of the sudden the shutter kept going off extremely fast (without me pressing the shutter button). I turned the camera back off, but the shutter kept going off. I freaked out and too the battery out to make it stop. But when I put the camera battery back in, the shutter once again was going nuts (even though the camera was off). I have tried keeping the battery out for a few hours to hopefully let the camera reset... that hasn't worked. I tried switching my setting to the green square... nothing. The shutter still goes off on its own at a crazy fast speed as soon as I turn the camera on (at least now it doesn't go off with the battery inside the camera). What should I do?
  • 5 more comments
  • dory21 Aug 24, 2008
    I forgot to mention - it's a Canon 20D... thanks!
    I don't think it has anything to do with the lens... I've tried switching lenses... and the shutter still goes off like crazy on it's own. The camera does not shut off by itself... the shutter just keeps on going off rapidly without me doing it.
    Another thing I noticed is that it says Error 99 on the screen... but of course, I know that Error 99 is a 'catchall' for anything going wrong with the camera.
    Like I mentioned, the lens is not the problem... it's the camera body itself that's making the shutter go off.
    I've owned the camera for 2.5 years. It is used heavily (I do wedding and event photography as a part time job). Nothing like this has ever happened to me before.
    I there like a camera reset button on the camera that I can't seem to find? (like a reboot button?)
    I'm not sure if this solution might help... I would like more info on what you might suggest I do to fix the problem... thanks!
    wait... I think I just closed my question when I shouldn't have. I didn't mean to close my question out... the problem is still not fixed.
  • Cameras Master
  • 19,396 Answers
Did you remove batteries for a couple of minutes, that is the first thing to do.
Posted on Aug 26, 2008
    Genius:
  • 2,035 Answers
First remove the sd Card and check if the camera is working or You may need to update the firmware as its corrupted ,Please use this link :
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=224&modelid=10596#DownloadDetailAct
Good luck...
    Master:
  • 763 Answers
Base on some solutions and the problem still persist. you might bring it back that to the place were you bought it and let the technician of them help you because they have tools to open your camera and replace something just incase if needed. be sure to have the warranty or the receipt.
CHARCOIS
  • Cameras Master
  • 6,487 Answers
Sounds to me like there might be a issue with the release switch.This should be replace and if its still under warranty have it replace from Canon..
Hope that helps.......
Posted on Aug 24, 2008
  • 4,472 Answers
How long have you owned the camera? Have you had any problems with the unit in the past? Once I have more information I can assist you properly. Please don't reject my help til I have assisted you further.
Thanks,
Lee
  • Lee A.
    Lee A. Aug 24, 2008
    I am more then happy to assist you further on this problem if you want you can send me a free request to continue further by clicking ask me at www.fixya.com/users/leethedeuce
    If you have tried a different card and formatting it and that still didnt help then I would recommend finding the nearest authorized service center. The link can be found here
    http://www.usa.canon.com/consumer/contro...
    Thanks,
    Lee
    Genius:
  • 3,422 Answers
If the lens does not extend then it is possible that it has become jammed. Sometimes this can cause the camera to sense an error and shut itself down immediately after powering on.
There are other explanations for the behavior, but if the lens does not move this is the most likely cause. If the lens does extend but then the camera shuts right back off it is possible that an inner component such as the focusing element is not functioning properly.
  • 5 more comments
  • Priya darshan Aug 24, 2008
    You should have told me that error 99 before rating the solution.I could've helped you.
    Nope reset button will not fix the issue.Please follow the below steps if they don't help then there are no home remedies you will have to get it repaired and please do not forget to accept the solution.
    1. Turn off the camera.
    2. Remove the lens, battery, and CF card.
    3. Allow the camera to sit without power for approximately 20 minutes.
    4. Insert a fully charged battery, and turn on the camera.
    5. Depress the shutter button as you would to take a picture.
    Does the “ERR 99′ message appear? If it does, then the camera should be
    serviced. If it does not, then please proceed to the next set of steps:
    2. Insert the CF card.
    3. Turn on the camera.
    4. Format the CF card in the camera.
    Does the “ERR 99′ message appear? If so, then the CF card is the most
    likely source of the issue. Try using a different card.
    If the message does not appear, please complete the following steps:
    2. Clean the lens contacts by gently rubbing them with a pencil eraser
    or soft cloth. Be careful that you do not let any debris fall into the
    camera body.
    3. Reattach your lens.
    4. Turn on the camera.
    If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
    If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
    Please don't forget to accept the solution as fixya.
    You have rated the wrong expert.
    I gave you all the steps to troubleshoot the problem and you did not accept my solution.You have rated the wrong expert.
    Well then give that expert a thanks for trying rating.
    Please accept my solution.I have already given the complete answer to your problem.If that doesn't help then you will have to get it repaired.There are no more home remedies.
  • Priya darshan Aug 25, 2008
    You have not accepted my solution yet.I request you to please do this.Let me know if you need anymore help.
How can we create best wedding management sites?
There are certain sites available on the Internet which can provide the best services regarding the Wedding management business.
These sites contain software and apps which will help to develop the best Web Design for Wedding Businesses and also helps to manage your wedding management business services.
You can search for these sites on Internet, they are provided with reviews which will help you to decide the best one according to your choice.
Oct 23, 2017 | Best Computers & Internet
My camera just decides what shutter speed it wants to take the photo at .....it will be 1/125 then all of a sudden be 1/30 and i need fast pictures for my motocross how do i have a constant shutter speed
Unfortunately you can't. More sophisticated cameras will let you control more facets of your photography. With a point&shoot camera about all you can is point and shoot, and let the camera make its decisions.
Jun 14, 2011 | Nikon COOLPIX L20 Digital Camera
Canon XSI showing "busy" when taking multiple shots
It can be that your batteries are low and takes longer to charge the flash... It can also be that your memory card is a slow on. If the red processing light on the back of the camera is staying on a long time, it means the camera is having trouble feeding the picture to the card... You might try decreasing the picture quality a little...
Jun 12, 2009 | Canon EOS Rebel XSi Digital Camera
Black display on speedlight Sb800
You have a defective LCD assembly and it needs to be replaced . Check out the rest of the unit and see if it fires..
Berrie Smith Camera Repair
Certified in NIKON and CANON
Mar 29, 2009 | Nikon Speedlight SB-800 TTL Flash
Bad film or Camera.
Return the camera to the company and see if you can get a return or at least an even exchange. Get another roll of film and shoot casual stuff. Never test a camera, film or digital for the first time at any mission critical event like an anniversary or wedding. It can lead to potential disaster. Shoot the roll with the new camera if you got it exchanged and then have it developed at Walmart or wherever is cheapest. If it works, keep it. If not, don't. BTW, if you are ever going to have to shoot a wedding or anything ever again with a film point and shoot and don't want hassles, just get disposable cameras. They are designed to work out of the box with no problems. They are of higher quality then most people think for image qulity.
Polaroid used to make good instant cameras, but their 35mm film and digital stuff I wouldn't trust as much. It's not the real Polaroid which can makes only instant film gear. . It's another company using the Polaroid brand name to try and make otherwise generic stuff look better then it is. Their digital cameras have a poor reputation. I don't think their non instant film cameras are much better. Good luck.
Apr 08, 2008 | Photography
I'm having 3 different problems with my Canon Rebel XT
According to Canon, Error code 02 means that "There is a problem with the CF card. Try any of the following: Remove and re-insert the CF card. Format the CF card, use a different CF card."
Are both CF cards the same brand? Sometimes some brands have conflicts with the camera, you might try using two different brands.
It may not be the card, did you try on the third attempt to remove the battery and put it back in? There may be a problem with the contact points where the CF card plugs into the camera, or in the transfer system itself.
Dec 01, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Extreme Difficulties With My Canon
Problem #1
this is not a problem.. if you leave the camera in the ON setting for long enough.. it goes to sleep ... in order to conserve battery life.. you need to keep some of the buttons pressed for a bit for it to wake up... e.g. keep the picture taking button depressed for 5 secs.
Problem #2
If you were checking the pictures after just shooting them then its probably a CF card problem. You can also get the same error .. i.e. corrupted files from the cameras perspective.. if you use a CF card reader and try to change the pictures on the card.
You should try to connect the CF card that has those pictures to a computer it might be able to open them.. .
Otherwise try another CF card.
Nov 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Pictures too white and blurry
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
It's need repair camera machine shutter.
more detail casio ex-s600 overexpourse
Nov 09, 2007 | Casio Exilim EX-S600 Digital Camera
Help!! 10-year old Accura Zoom 80 film camera is taking blurry photos all of a sudden
you should be able to place your hand in front of the auto focus window while looking in front of camera (be careful not to blind yourself with the flash) you should notice the lens moving sightly as if to focus. The best way though is to actually shoot a roll through it. Do not shoot a wedding or anything of real importance...the cost of a roll of film and develop is worth piece of mind.
Jul 04, 2007 | Olympus Accura Zoom 80 35mm Point and...
"busy" Error
check your firmware version and update if necessary. Usually you get the "busy" message when your camera is writing to the card and it's possible the card isn't quite right - a format should fix it. Alternatately you might try a different CF card to see if the problem goes away. Good luck!
Sep 14, 2005 | Canon EOS-20D Digital Camera
Cameras Logo
41 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
