Question about Acer Aspire 5315 Notebook
Ram Memory How to instal memory upgrade from 1GB to 2 GB
  • stockmanci Jan 15, 2009
    (Similar) How do I install memory upgrade from 1GB to 2 GB. I have the memory piece but I've never opened the back of a laptop. Plus I wanted to know (if I do install it) is there special protocall when restarting the laptop?
    It's an aspire 5315-2153.
I did this 2 days ago on my gf's aspire 5315-2153 (walmart special $348). the underside panel has four tiny screws which must be removed and then the fun begins. The plastic panel is large and doesn't want to be removed. After 20 minutes of cursing, i was able to get it out with two hands and a small screwdriver. The plastic panel has about 7-8 tabs which also hold it in place. The original two memory modules must be removed and the two new ones installed in their place. i bought crucial memory from newegg.com (CT2KIT12864AC667) for $17 delivered (took a week to get) which was much cheaper than buying it direct from crucial.com Save the old memory modules just in case you have a problem with the new ones. After putting them in, I restarted the computer and it booted up fine. No BIOS changes or any of that were necessary. So for $17 and about 30 minutes, this lappy is now running strong with 2gb instead of 1gb. Initial impression is that it boots up faster and shuts down faster but that is about it in terms of improvement!!!
Posted on Feb 07, 2009
    Genius:
  • 1,847 Answers
Check the computer manual if it is compact able with 2 GB ram. if yes there is a memory sole on the bottom the laptop open it you will be able replace the ram.
Posted on Aug 24, 2008
How do I proceed to add memory to an Acer Aspire 5315 laptop? I have the memory stick but am unsure about opening the back of the computer
Posted on Nov 26, 2008
I have compaq presario V3070TU with 512mb ddr2 RAM. i tried to upgrade to 2 gb RAM into one bottom slot (not 2 numbers of 1GB), but 2gb RAM is not working(display is not UP). only 1gb RAM is working....
I could not figure out the relationship of the hard disk with the memory.
try change the memory dimms put 512 in bottom and 1gb in the other possition and see what amount of ram you get
Aug 02, 2013 | HP Pavilion ze4365us Notebook
HI I have a Gigabyte motherboard 945GCMX-S2, I have a 1GB ddr2 (667 Hz) hynix ram already installed ..to upgrade it i installed another 1GB dynet ram (666 Hz)..but my cpu beeps now...i remember runni
You should be able to as it can take 4 gig total according to the manual.
Memory:
2 DDRII DIMM memory slots (supports up to 4 GB memory) (Note 2)
Supports dual channel DDRII 667/533 unbuffered DIMMs (Note 3)
Supports 1.8V DDRII DIMMs
Note 2. Only for GA-945GCMX-S2.
Note 3. Only for GA-945GCM-S2.
Feb 06, 2012 | Gigabyte Computers & Internet
I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
Sep 26, 2010 | Computers & Internet
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Aug 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
I have 512 mg of memory. Would there be a big difference if I add a 1 gb stick and keep the 512 mb , as oppose to removing the 512 mb and replace with two 1 gb sticks?
The performance of your laptop will improve if similar memory is placed in each of memory slot.If 1gb memory and 512mb memory are placed in available slot you will only get the performance of a single 1gb memory.but two 1gb memory are used performance will be similar to a 2gb ram or more.
May 30, 2010 | Acer Aspire 3003WLCi Notebook
Do this model supporsts win xp service pack 2
Hi.
This unit has a Pentium 4 2GHz single core processor, and does support Windows XP SP2.
The standard memory installed on this unit was 256KB RAM, in order to run XP efficently you will need to upgrade the RAM. I suggest upgrading RAM to the maximum amount allowed of 2 GB RAM.
To upgrade the RAM to 2 GB you will need 2 modules of 1GB PC2100 184 pin DIMM ECC each.
Micron 1GB DDR RAM PC-2100 ECC
May 25, 2010 | IBM eserver xSeries 205 8480
Can I upgrade memory to only one gb of memory or install 2 512 mb on a toshiba satellite m35x series
http://www.shopping.com/xPF-Toshiba-Toshiba-Satellite-Notebook-PC-M35X-S114
Looking at the specs, the max is 2gb for your Toshiba. According to this website, its only a 256mb ddr sdram. So my guess is you only have 1 slot for the ram. I'd go with a 2gb ram if you can afford it, 1gb just don't cut it in todays technology.
I believe its the PC2700 model, so find a 1gb or 2gb PC2700 @ 333mhz and you should be set.
Sep 09, 2009 | Toshiba Satellite M35X-S114 Notebook
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Can i upgrade this with 1gb ram?
Hi again!
Yepp, you can upgrade it to 1GB memory
This is the spec of the memory on your 2055:
Memory RAM Technology DDR2 SDRAM Max Supported RAM 1 GB RAM Speed 533 MHz Installed Cache Memory 1024 KB
Good luck
Nic
DONT forget tp RATE me
Apr 07, 2009 | Intel Celeron M 420 1.6GHz 533MHz 1MB...
Acer Aspire 5315 Notebook Logo
1,941 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
