Question about Freezers
Gibon upright freezer
Not keeping everything frozen...sauces, icecream, and stuff of that souce defrosting.
  • 639 Answers
Hi smrours
Happy to help you!!
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
PS. Before you leave this site please leave a "Problem Solved" rating for me on
Posted on Aug 25, 2008
Freezer runs but won't keep most foods frozen even on coldest setting
Check condenser clean and fan working. Check it's not frozen solid because you've been running it full pelt; if it is, fully defrost it then set it at a mid range setting.
May 13, 2012 | Kenmore Freezer 20.6 cu. ft. Frost Free...
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
Upright frigidaire freezer not running properly
Sounds like your defrost timer has packed it in you need to fit another timer to it and everything will be as good as new.
by turning the timer you have forced it to run nothing to worry about. It has just stopped in the defrost position. What you have done is the first diagnostic test a tech would have performed. I hope this has helped you out.
Jun 30, 2009 | Frigidaire 14 cu. ft. / 396 liter Upright...
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Food not totally frozen, icecream melted
if it a frost free freezer then chances are it is a defrost hearter, fan motor or defrost timer
if it is not frost free then it will either be the compressor or a gas leak ( which should be under warranty)
Apr 29, 2009 | Frigidaire 16.8 cu. ft. Upright Freezer...
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire upright 13.7 cf
Will it freeze water? The vent coming into the freezer may be blocked. Check that and see. Is the refrigerator keeping those items cool? You may also have a vent blocked by the fan cover (dusty). If all this is right, you may have a freon leak or worse a compressor or evaporator going bad.
Feb 02, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Dec 28, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore model 2539280412 upright freezer alarm keeps going off
might have a defrost problem check to see if it is building up with on the back panel if it is you need a defrost timer or limiter or heater or fan
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer not keeping items completly frozen
thius suggests the defrost system not working and the defrost drain blocked. take off the back panel inside the freezer, melt off excessive ice and free the drain at the bottom with hot water and patience
Apr 30, 2007 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezers Logo
47 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
