Cellular Phone Hello, My phone is not letting me get in to any of the settings because it says system memory is full but then it only says 81%. How can i fix this or why does it do this.
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Thank you for using FixYa!
Do have a nice day and please remember to rate this solution.
have you checked your memory space? removing the messages may still not have given it enough if you have media related files on your cell phone look in the phone settings there should be something on the memory you may need to delete some music or something. best of luck. yours, LoLuMaD
That means there are many settings are already saved in your Nokia device . Just discard them and try again. If you couldn't discard them here is another solution : Just restore factory settings and I'm sure that you'll solve the problem .To restore factory settings here is the way: Switch-off your phone.
good luck .
rate if useful please !
dial key, * Star key, no 3 key on keypad and then press the power
on/off to switch on the phone.
Remember, do not let go the 3 keys press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting. then here is what to do :
Just call your service provider support center and they'll help you for
sure . don't try it by yourself . let them help you . they are the only ones , who can help you correctly .
your rating is very important for me , that's why I've helped you .
hello darom look for msg setting, smsctr no. if correct setting, u need format the phone. by pressing hold :send+3+*power. first back up the contact no. and save file
solved
thanks
