Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Memory Card Slot Fault
Hi all.
Have had my D40 for about 18 months now, but approximately 6-8 months ago, the memory card slot developed a fault and it seems to be the mechanism that holds the card in that is the problem. When I put the card into the camera, it simply springs back out, meaning that the catch that 'clicks' when you put a memory card in has developed a fault.
I realise it's obviously outside of it's years Manufacturing Guarantee, but I never registered the item at the time of purchase. Should I do that now and seek assistance from NIkon or will that not work? Alternatively, does anyone know how to fix this problem without having to send the camera away for repair?
Many thanks!
Ben.
  • 2 more comments
  • Anonymous Nov 10, 2008
    I have the same probelm. Help please!
  • benhutch Dec 13, 2008
    Exactly the ame problem
  • Anonymous Jan 03, 2009
    Mine however is on my motorola rizr z8 phone. It just would let the card in. What I did was to place something (I cut a plastic) and squeezed it through the slot so my memory card will stay there. In case I want to remove it, I just get something like a needle or tweezer and pull the damn thing out. haha!
  • vision63 Mar 05, 2009
    Nikon wants over $200 dollars to fix it. A real fix would help other than "take it to a service center."
    Scholar:
  • 170 Answers
Please take it immediately to the nearest authorized service center
Posted on Feb 16, 2009
I receive a Card Error message when I try to take a picture. I have replaced the batteries and have a new sim card.
hi,
either your memory card or memory card slot have snags, if you checked with another memory card then the fault should be in memory slot, just look inside the memory card slot with a flash lite if the contacts is bent, if it is bend or shot circuited, open the camera and make it straight with a tweezer tool. if any dirt or dust inside, try to clean it with an air blower then spray some contact cleaner in.
Feb 18, 2016 | Cameras
Memorey card is not work in a phone
Hello, welcome to Fixya!
The fault is either from the phone or the phone's memory card slot.
Test the memory card on another phone or any other device that uses memory card. If the memor card doesn't work, then it means the memory card is not good. But if the memory card works, it means fault is from the phone.
Get a phone screw driver, disassemble the phone, clean the memory car slot with a tooth brush. This will clear off all particles that maybe preventing the memory card from contacting the phone properly.
The cleaning the memory card slot doesn't help, it means the memory card slot of the phone is defective. It takes only a repairman to fix this fault for you.
I hope the above information is celar.
Regards.
Walesarumi
Dec 14, 2011 | Samsung Lands Phones
No memory card inserted
Possible there is damage on the memorry card slot or the card slot contacts.
Also if there is fault on the motherboard interface or if there is fault on the memory card.
Check the card on another phone or PC. Also check with another card to confirm.
Sep 24, 2011 | Nokia N72 Cellular Phone
When i insert the memory card "card error" appears
Please try this card with your PC and if there is any issues in detection after inserting into the card detection slot, then the card is faulty for sure.
If not make sure there are no foreign particles inside of the slot, make sure with a good air jet the slot is clear.
If there is no detection remove battery, keep it off for few hours/overnight and retry.
If the fault stays the fault is in the interface to the processor in the main board.
Nov 24, 2010 | Samsung i85 Digital Camera
Pleeze help, ok i insert my memory card reader and computer recognises, fine, however when i insert my 16gb sandisk m2 memory card.....nada, nothing, zilch!?? It says that there is no media inserted and...
This is because there is a fault in the slot where you put the memory card.
The problem is the memory card contact surface in not in contact with the memory card reader contact surfcae.
So please change the memory card reader it wil be fine.
Thanx
Jul 08, 2010 | SanDisk 1GB Memory Stick M2 Memory Card
5800 MMC NOT WORKING
If you Nokia 5800's memory card is not working.
It simply means there is a problem or two,
1. the phone might not be reading the memory card,
2, the memory card might be faulty.
test to know if it is the phone,
  1. insert the same memory card into another phone to see if the phone will read it.
  2. insert another tested okay memory card into the phone to see if it will work.
  3. if it does not,then the fault is from the phone,
to fix this,
  1. get the appropriate screwdriver,
  2. open the phone,
  3. carefully open the memory card slot,
  4. clean it properly with naphthalene and dry it under the heat of a bulb,
  5. or you can replace the memory card slot completely,
  6. insert the memory card and turn it on to see if it will read it.
  7. before you couple it back together.
To test if it is the memory card
  1. insert the memory card into another phone to see if it will do the read it, if it does not, then the fault is from the memory card.
to fix this
all you have to do is to change the memory card.
take care
Jun 18, 2010 | Nokia 5800 XpressMusic Smartphone
Continues to tell me to insert it when it's there
The reason the phone is not reading the memory card is either the phones memory card slot is faulty or the memory card is not in good conditions.
To test if it is the phone, try a well tested memory card in the phone to see if it reads it, if it does not then it is the memory card slot.
to solve that, try to open the phone and clean with spirit and drey it with the heat from a bulb, or you can replace the slot.
To test if it is the memory card, try the memory card another phone that the memory card is working fine.
if it does not read the memory card, then the fault is from the memory card, and the solution is simply to replace the memory card.
Make sure the memory card is not above 16GB.
Take care
Jun 14, 2010 | Samsung SCH-U450 Cell Phone
Memory card slot broken with damage to pins Acer Aspire 2920
Hi there
I'm a PC technician and i have come across this problem before with built in card readers and i can usually fix the problem myself.
It sounds like Acer are just trying to swindle more money from you.
Warranty is supposed to cover hardware up to a year and should be their responsibility to repair.
Can you tell me just what they said to you?
Jan 08, 2009 | Acer Aspire 5610-4648 Notebook
Fuji S9600 Memory Card Holder Broken
sadly a warrenty will not cover accidentally putting the card in the wrong way, as it is tecnically your fault, but you can use the slot for xd cards, if you do not want to pay for a new cf slot
Aug 27, 2008 | Fuji Finepix S9600 Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
248 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
