Question about Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso
No espresso When I start the machine, it warms up properly and after the lcd shows it ready, I select the numbre of cups I want. Unfortunately, the machine only pumps a small amount of expresso and I have to start over again. It takes a number of cycles in order to get a fulol up of espresso.
  • medfield Sep 10, 2008
    Same problem.  Takes several restarts to get enough to make a cup of espresso.
    Descaled, but it did not help.
    Also, frothing is poor.
  • taucrit Oct 05, 2008
    Exact same problem
    New Friend:
  • 39 Answers
I had the same problem and found out that the flow meter was not working. The control unit was not getting flow information and after about 5-10 seconds it will just stop and blink all the lights. I replaced the flow meter and solved the problem. The flow meter is located between the water tank and the pump.
Posted on Dec 31, 2009
  • emuzic Aug 24, 2010
    Thanks, same problem were with my coffe machine. If someone else have similar problem this is procedure how to test if flow meter is cause: Open coffe machine and pull out flow meter (do not disconnect it, just unscrew it from housing), prepare any magnet (neodimium magnet if possible), press the button to start making coffe. Coffe machine will start, then stop for a second, then start again. When it starts again put magnet close to flow meter's contacts and then move the magnet away and keep repeating that moves very fast. If coffe machine is working fine then you have to replace flow meter.
  • Kritione Oct 05, 2010
    I have exactly the same problem with my XP2070. Your info was helpful and I'll go to the local Krups service center to check it out. Thank you.
Where can I buy the flow meter for my Krups coffee maker XP-2070 ?
Posted on Mar 24, 2011
  • 916carl May 29, 2011
    Flow meter:http://www.smallappliance.com/product.as...
    I consider myself to be fairly handy (wired my kitchen/bath, etc...) but this is not an easy thing to replace. Removed the back panel, then the bottom panel. Had a tough time getting to 1 screw that held the flow meter in. The side panel was in the way and I couldn't figure out how to take it off without breaking it. Used a very small flat head screw driver (from eye glass repair kit) and small pliers (to grasp and turn it) to remove the screw. Took about 2 hours to get it out and replaced, however it took 2 more to re-assemble the damn thing. I recommend patience, a sound proof room so no one hears you curse and take pictures as you go for reference.
2 Suggested Answers
SOURCE: where can I buy the
Same problem I have, flow meter! you could buy it @ http://www.smallappliance.com/product.asp?pid=13677&cur=USD&cam=krupsusa although I am not sure which cluster you would connect the flow meter to the power board. My husband and I have opened the machine and we forgot to reconnect the flow meter to the power board. If you could take a look for us either J3 or J6 I will be more than happy to know. thks
Posted on Apr 20, 2011
Why can't i get cup size in capresso impressa?
Hold the button in, until it says "Enough?" then release..
When you have the right amount, push the button again.
Jul 06, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
Keurig B70 automatically pumps water when turned on
When you purged the lines or tubes retained debris and need full purging and flushing.
May 30, 2012 | Keurig Platinum B70 Coffee Maker
Where can I buy the water flow meter When I start the machine, it warms up properly and after the lcd shows it ready, I select the numbre of cups I want. Unfortunately, the machine only pumps a small...
Mar 24, 2011 | Krups XP2070 10 cup Coffee Maker/15 bar...
Saeco Royal Professional Espresso Machine Problem IT KEEPS GIVING ME ENERGY SAVING. WHAT DOSE THAT MEAN? I HAVE FORGOT T TURNED ON THESE MORNING. THANKS
There is a main switch on the lower left side, as well as a standby switch on the front. Make sure the main switch is on, and the press the power button on the front. It will warm up & be ready to make a cup of coffee (about 30 sec.) when you select one of the coffee (cup) buttons.
Dec 15, 2010 | Microwave Ovens
My mother decided to make a cup of coffee. She
Make sure the k-cup holder is snapped completely back into place. If the arrows aren't aligned and you don't snap the arrow-side in first, it won't work. If that doesn't do it, check your water reservoir to ensure it is properly seated in it's base. Hope that helps...best of luck!
Jul 14, 2009 | Keurig B60 Coffee Maker
Coffee not hot enough
hi elite 288! have you tried pre-heating your coffee cups? i fill w/hot water, then set them on cup warmer until i brew coffee (dump out water & slide cup under spout at last moment) and i do my frothing of milk before brewing espresso. also, have you allowed adequate time for machine to warm up/run just water through machine: after it indicates it's ready to go, hit the brew button & allow about a 1/2 cup or cup of water to run thru, warming up the brewhead. when ready button again lights up, brew your espresso. if this doesn't get it hot enough for you, try descaling your machine (you can look online or in manual for how to do this). since you have a refurb unit & heating element may not have been replaced, it could have some build up on it causing it to heat up all the water less efficiently. if this doesn't work, you may need to have the place you purchased it from diagnose and repair. good luck!
Jan 11, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Cup warming pad
I think, if the machine goes in standby then the warming pad also goes in standby.
/Mirran
Aug 06, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco magic
I believe the model you have has no user-selectable temperature settings. The manual for the Magic line suggests preheating the cups as the fix. You can use the electronic cup warner OR run your tap/faucet water as hot as possible, fill the cup you're going to be dispensing espresso into with hot water while your Saeco warms up...right before you hit the button to dispense espresso, empty the hot water, dry the preheated cup and you're set! It only takes a few seconds. This way, you waste none of your coffee's thermal emergy on cup heating and your coffee will stay hot longer. Hope this helps!
Jan 02, 2008 | Saeco Magic De Luxe Espresso Machine
Locked into warming up mode
According to this current situation, you can check witha local professional..b-cos the internal circuitry has to be checked..
check with him if it can be repaired..if not you can replace it..
Dec 07, 2007 | Miele CVA610
Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso Logo
1,051 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
