Question about Dryers
Kenmore dryer I have removed rear panel and checked continuity on all the leads and components I can see, the only one I didn't get tone on was the dryer cycling therm. with internal bias. I get continuity on the big outer leads but not on the small inner leads. Could this be why my dryer runs but has no heat?
  • michael4 Aug 25, 2008
    Thank you so much for your help, my apologies for not including model number, it is Kenmore dryer 110.66702690.
  • 5,911 Answers
I apologize for taking so long getting back to you on this. Have you verified everything? The following link provides some helpful information on how to troubleshoot common ELECTRIC dryer problems:
http://www.fixya.com/support/r385301-thorough_dryer_advice
The component you mention, sounds like an operating thermostat, but I'm not sure. From the readings you provided, it sounds like it may be good. That's why I suggested the link in order for you to double check all your readings and symptoms. I'm not trying to undermine you technical abilities, but you may have overlooked something.
A model number would be a great help in understanding how your dryer is configured. You also never mentioned if this was an electric or gas dryer. I'm assuming we're talking about an electric dryer.
If this is a GAS dryer, the common source of a no heat problem is a bad igniter or gas safety valve coils. Please let me know which dryer type you have. I hope all this information helps you.
PS I failed to mention (I think) in the link I provided that there is also a centrifugal switch on the drive motor that (if faulty) will not enable the heating circuits. Double check everything else before looking into this option.
Posted on Aug 25, 2008
  • Jeff Rockwell
    Jeff Rockwell Aug 25, 2008
    Okay, thank you for the model number. Now, I know it is an electric dryer, but I still need to know more about your symptoms and what you have checked. Is the dryer running, but not heating? Or, does the dryer not start at all? Have you looked at the link I provided to you? Have you checked the heating element? Please let me know.
Kenmore HE5 dryer won't start
Several different problems could prevent your dryer from running. Make sure that the door is firmly closed and hold down the start button for a couple of seconds to start the dryer. If you hear a click from the control board then the door switch and the control board are likely okay. You could have a blown thermal fuse or a broken belt in the dryer. To check these components,unplug the dryer and remove the bottom front service panel as shown in the first image below. With this panel removed, you can tell whether the drive belt is broken. If the drive belt is okay, I recommend checking the thermal fuse. This fuse is located on the blower housing as shown in the second image below. It will have light blue wires attached. To test the fuse, remove one wire and measure the resistance across the leads of the fuse with a volt/ohm meter. You should measure near zero ohms of resistance (continuity). If you measure infinite resistance, then the fuse is blown and will need to be replaced. You can verify that this is your failure by taping the contacts of the light blue wires together with electrical tape to "bypass" the thermal fuse. Reassemble the dryer and see if the motor runs with this fuse bypassed. If it does, then this verifies that the blown thermal fuse prevented the dryer from running and that this was the only failure. NOTE: Do not continue to run the dryer beyond this brief test with the thermal fuse bypassed. This component must be replaced. It is an important safety feature of the dryer.
You can order a new thermal fuse from the Sears PartsDirect website. The part number is 3392519.
May 01, 2012 | Kenmore HE5 Electric Dryer
Dryer tumbles but does not put out heat
Make sure the unit is not plugged in when testing these fuses.You should also check the continuity on the heating element if all fuses check out as good.You may also need to check the main power at the terminal block and make sure you have 220 volts to the terminal block.These are all located on the rear of the dryer remove the back panel to get to them.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Mar 19, 2011 | Kenmore 62602 Electric Dryer
My dryer stoped working it is a Kenmore 70 series model #110.66712694 What do i check first
if you mean wont start do this : unplug dryer, remove back panel, look for a white part with2 connectors on the blower housing and remove one, using a continuity or ohmmeter put across the leads and if you hear no sound or see no reading in meterreplace that part. is the thermal fuse. this is the most common problem forthat failure.
Feb 14, 2011 | Kenmore Dryers
Does not heat.
What I do is first check for air restrictions and do a bit of cleaning. Then I unplug the dryer and remove the rear panel. I check the heating element for breaks and the safetys. Any component that does not have continuity is the culprit.themobilian_769.jpg
I have some videos, a service manual, and more HERE
Jan 07, 2011 | Kenmore Dryers
Dryer is running but the heater element is not working
Unplug the dryer and remove the rear dust cover. Check these safetys and the element for continuity. Any open component is the problem. MORE HERE
Dec 02, 2010 | Kenmore 64852 Electric Dryer
I have kenmore front load dryer. wont do anything when you turn it on. was working fine then just stopped. is getting power. what could cause this?
check thermal fuse located in back panel. make sure power is unplugged before removing cover. thermal fuse is located near exhaust and it's coated with white plastic with 2 leads sticking out. with volt meter check for continuity, no continuity must replace thermal fuse, it cannot be reset.p.s. remove wires from fuse to get accurate reading.
rwpfn@aol.com
Sep 01, 2010 | Kenmore 63942 Dryer
MY DRYER IS NOT HEATING WHEN IT IS ON
Unplug the machine and remove the rear cover.
Get an ohm meter and check the heater and safetys for continuity.
Any open components will cause the heater to malfunction. If you have power to the machine and all the components are good then replace the timer. Dryer Solutions with repair pix and manuals
Dec 17, 2009 | Kenmore Dryers
No heat, clothes are not getting dry
If the dryer isn't heating, check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. Both components are located in the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Hope this helped and best wishes.
Sep 06, 2009 | Kenmore 600 7962 Dryer
Kenmore dryer
Most likely the heating element however it could be a limit IF you have lint problems. The best thing you could do is break down the dryer and go over it with a vacuum. Ohm out all the safetys and heater. Fairly simple process.Just remember to remove a wire from each component so you won't get a back feed or what we call a false reading.I like to use an ohmeter with an audible continuity reading. (when the 2 leads are joined it beeps) then check each component for a beep. See easy! let me know
Jan 02, 2009 | Kenmore 63942 Dryer
Kenmore home dryer not heating but will turn on and spin
If your dryer turns on, but does not heat, the Thermal Fuse is GOOD. A blown Thermal Fuse will stop a dryer completely.
If the dryer turns on, drum spins, but you have no heat, any of the following components could be bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
Getting to those components to determine if they are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the the seam in the front about 2 inches in from each side.
The heating circuit should be troubleshot with the dryer UNPLUGGED. Resistance readings are as follows:
Heating Element (located inside heater box) - take reading across the two RED leads on the heating element. It should read 9 - 13 ohms.
Thermal Cut-Out (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended to replace BOTH components at the same time. They are often sold as a set.
I hope this information is helpful to you. Post back with comments if you have any further questions.
Nov 01, 2007 | Whirlpool LGV4634JQ Gas Dryer
Dryers Logo
78 people viewed this question
Top Dryers Experts
