Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Oven wan work
Oven wont heat or brioler
  • Anonymous Jan 07, 2009
    broiler heats oven wont heat
    Problem Solver:
  • 8 Answers
Make of stove .. digital or standard controls .. may not even be the oven ovens are 220 volts 110 works stove top other 110 works oven
Posted on Oct 11, 2008
GE JGBP33 gas oven will not light. Burners and brioler will light. When trying to ignite oven, igniter will not glow, and I see no change in voltage accross igniter contacts. What's next step to...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 27, 2011 | GE Ovens
Whirlpool electric oven won't heat just barely
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then test the door switch. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Whirlpool RBS305PD Electric Single Oven
My Maytag Gas Oven will not heat up very much. It's a 50/50 guess if the oven will heat to the correct temp. Sometimes it works fine, the other times it is not very warm at all in the ove, even after...
This indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 06, 2011 | Maytag CWG3100A Gas Single Oven
I have not so new Kenmore 790 gas range oven. The gas range and brioler work but the oven won't heat up. Suggestions?
I have the same oven and the same thing happened to me. I had to change out the heating element to Ignite the lower baking part. Trying to change it out is another story. I used metal snips to "open" the rear part to change it out. I was not ready to take apart the whole oven. The Part cost about 75$ from a part store, and the connections are easy. Hope this helped.
Aug 12, 2010 | Kenmore Ovens
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Apr 05, 2009 | Belling XOU252 Electric Single Oven
Burners & clock are working, but oven, brioler & self-cleaner won't. Error F-0, EO
Brandyz Most likely the problem with your range is the spark module. It is located in the control panel on the right hand side. You can access it by removing the back panel held with four screws from the back. Remember to unplug the range first. The name plate with the model number and the serial number is on the frame behind the storage drawer. You can buy the spark module here: http://click.linksynergy.com/fs-bin/click?id=SrmyP8LkIos&offerid=92089.545301030&type=10&subid= It comes with installation instructions. Gendos...post back
Jan 30, 2007 | Whirlpool RBS245PDS Electric Single Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
105 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
