Question about Splendide 2100 Vented Washer-Dryer
Splendide 2100 no longer dries clothes
We have a Splendide washer dryer about 18 months old. Just began an isssue with not getting hot during dry cycle. Unit spins but does not get hot enough to dry clothing.
I read through the book, only refers to the water waste line obstruction that might cause an issue.
  • Anonymous May 25, 2009
    These items are not resetable--------------with an ohmmeter are they to measure open or short
  • Barbara Valasek May 09, 2013
    no reset buttons found but found 2 ecos? one registers one doesnt.. I am assuming that one needs replaced.. will keep u posted.
No reset buttons found but found 2 ecos? one registers (with meter) one doesnt.. I am assuming that one needs replaced.. will keep u posted.
Posted on May 09, 2013
We had the same problem with our splendide 2100 top loader. If you remove the top cover, you will find 2 circular like black discs (the size of a dime) on the right hand side about 6 inches from the front. You need to push those down (with a very small blunt object) to reset them. Please make sure that you unplug your washer/dryer before you attempt this. Good luck.
Posted on Nov 01, 2008
Clicking noise in splendid dryer
We did not get a book. It washed the clothes BUT water still in washer. we don't no how to put it on to dry the clothes?
Mar 05, 2014 | Splendide 2100 Vented Washer-Dryer
Wdc1025 splendide all in one combo,the dryer doesnt seem to get hot enought to dry??help
Do the clothes eventually dry over a longer period time than usual? If so, there are 2 possible problems.
1. Your dryer vent is nearly clogged
2. If it is electric, then the heating element is going bad.
GOOD LUCK
Mr. Tin Man
Dec 19, 2010 | Washing Machines
Most recently, the dryer function is not drying
Run a cycle with the Dryer vent hose off. If the clothes come out dry, you need to have a duct cleaning company come out and vacuum out the duct.
Oct 20, 2009 | Splendide 2000S Front Load Washer / Dryer
Splendide 2100 washer/dryer now fails to dry -
Remove the top - two screws in the back then slide forward
In the front right top you will see the air box and the terminals for the heater coil along with other wires and sensors. Start the washer on a dry cycle and check the voltage to the heater terminals. You will be looking for 120 AC. If voltage there but no heat the heating element is bad. If no voltage there follow the wires to the overheat switches and check the voltage on the other side of these switches (round devices with two terminals on top). If there is voltage there then the switch has tripped. Unplug the machine. Look for a spot of paint on this switch, scratch it away and you will see a small hole. Insert a strightened paper clip into this hole and push to reset the switch. Re-power and test the results.
No power to these switches probably means a bad circuit board $$$.
Sep 19, 2009 | Splendide 2100 Vented Washer-Dryer
We bought a used motorhome with a Splendide 2100 w/d combo. It does not dry the clothes, but washes fine. There was no manual on this appliance, so don't know how to find out the problem. Can you help?...
Your heating element could be out. This could be just a bad element or if you don't hear the fan come in the the dry cycle, the fan probably failed and caused the element to burn out. If your clothes are getting warm but not drying completely then you need to check your exhaust hose and make sure it is not clogged with lint.
Jul 13, 2009 | Splendide 2100 Vented Washer-Dryer
Splendide 2100 vented washes clothes just fine but now when it goes into the dryer mode just roates the knob around without doing anything. This only happens in the dry mode.
This means that the washer has found something wrong and it is going to a diagnostic mode. When the knob starts going around, immediately begin counting how many times the red light blinks. Call Splendide and they can diagnose the error from the number of blinks you counted. I would recreate the problem more than once so you know that you counted right.
Jul 07, 2009 | Splendide 2100 Vented Washer-Dryer
Doesn't completely dry clothing
Make sure lint filter is clean and vent pipe and outlet are not clogged.  If the clothes are getting warm then the element is working.
May 30, 2009 | Splendide 2100 Vented Washer-Dryer
Splendide 2100 Vented Washer-Dryer Logo
649 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
