Question about Olympus DS-50 Digital Voice Recorder
I took some files off of my DS-40 Olympus recorder and now I keep getting the message "can't make the system file. connect to PC and delete unnecessary file." Any help getting it to work again would be very much appreciated! Thanks, Whitney
SOURCE:
JULIANFIX
  • 975 Answers
SOURCE: Where can I obtain the software for the Olympus DS 330 voice recorder that is required to be able to download files to my PC
go to this link:
http://www.olympus-europa.com/consumer/2590_3505.htm?prodID=P_053011 , hope this helpful
Posted on Apr 27, 2008
SOURCE: Can't get PC to recognize audio files on Olympus DS-40
same problem. olypmus sucks.
Posted on May 15, 2008
  • 17 Answers
SOURCE: Restoring Deleted Olympus Files
Yes, will restore any kind of files, including DSS files
Best Regards
Posted on Aug 20, 2008
  • 919 Answers
SOURCE: converting wma files to wav files on olympus DDS player version 7
When using the DSS Player v7 software the program is unable to convert WMA to WAV. The option you see there only works when it is a .dss file that needs to be converted to .wav. In order to convert WMA to WAV you will need to locate a third party software program that does this type of conversion.
Go to google and search on WMA to WAV conversion editors.
Posted on Dec 12, 2008
  • 479 Answers
SOURCE: deleted files and want to undelete
there is no solution... wrong type of memory for data recovery to use
Posted on Feb 11, 2009
How to restore audio files from formated Olympus digital recorder
You should stop recording new ones to prevent the old ones from being overwritten. If your digital recorder has a memory card, take it out and insert it to your computer with a card reader. If the device has built-in memory, just connect it to your PC directly. On your computer, you need a video/audio recovery program. Fine one, install and run it. The software will help you scan lost audio files from your recorder, then it'll show you what it's found. Choose the files you want and hit the "Recover" button to start recovery process.
If you're a Mac user, please feel free to try this Mac based video/audio recovery app. http://www.leawo.org/photo-recovery-mac/
May 16, 2016 | Olympus DS-40 Digital Voice Recorder
Ds-40 can deleted files be restored?
In this case you should connect your recorder to PC and then you can try to restore your files with Easy Drive Data Recovery software:
http://www.munsoft.com/EasyDriveDataRecovery/
It uses unique modern algorithms to recover files that other software either recovers incorrectly or is unable to detect.
Feb 20, 2011 | Olympus DS-40 Digital Voice Recorder
Olympus ds 40 can't display recorded voice folders on pc
There are a total of eight folders in the recorder that are in a tree format. Under the “Root” folder
are “Folder A” through “Folder E”, “Audible” and “Music” folders, and recorded or transferred
Language and music data from a computer can be saved as “files”. “Folder A” through “Folder E”
are voice-recording folders, so choose one of these five folders when recording on this recorder.
Up to 200 files can be saved in each folder, and up to two layers can be created within the “Music” folders.
Feb 14, 2010 | Olympus DS-40 Digital Voice Recorder
File Recovery from Olympus VN-6200 PC voice recorder
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your recorder to another PC with a recovery program installed. Photo Recovery Software (also recover Voice memos, audio and video files) is right what you need to use if you are running Windows. If you are Mac OS X users, turn to Data Recovery for Mac.
But you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. Good Luck!
Jan 10, 2010 | Olympus DS-40 Digital Voice Recorder
I cannot delete files because the are locked. How did this happen? I don't know. How can I unlock these files?
Your DS-40 DVR has lock function to avoid important files from being accidentally erased.Locking and unlocking a file folder can be found on page 68 of your user manual.
An electronic copy of DS-40 DVR User Manual can be downloaded on this link.
Nov 03, 2009 | Olympus DS-40 Digital Voice Recorder
Lost my DS-40 audio files after upload. Can I recover them?
you can use card recovery software that helped me before
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is this photo recovery (simply because i was using it and it worked)
http://www.asoftech.com/adr/
4. Install and open the data recovery program, select your memory drive, and click 'Next' button to start scanning process which will find your deleted files.
Sep 08, 2009 | Olympus DS-40 Digital Voice Recorder
Olympus ds-30 deleted file recovery
on your computer, you will need some sort of media recovery software. also go to options under the tools menu and uncheck delete after transfer to turn off deletion. this is usually best since you can delete the files through the recorder by the erase button
Sep 26, 2008 | Olympus DS-30 Digital Voice Recorder
Best Regards
Aug 17, 2008 | Olympus DS-2 Digital Voice Recorder
Can't use my voice recorder anymore
try to connect the recorder to the PC and with the Olympus DSS Player Version 7 change the folders name to default
Mar 05, 2008 | Olympus DS-50 Digital Voice Recorder
Olympus DS-50 Digital Voice Recorder Logo
104 people viewed this question
Top Olympus Audio Players & Recorders Experts
Ekse
leoz
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
