Question about HP DeskJet 5550 InkJet Printer
Blinking light i am trying to set up my deskjet 5550 on my new laptop toshiba vista. i try to print something from notepad (or anywhere else i try) and i get a orange flashing light on the printer. can you help me to diaganose.
  • 300 Answers
You can try the following steps:
The Two-Sided Printing Accessory is installed incorrectly, not at all, or the back access door is unlocked or open.
Solution
  1. Turn the knob on the rear access door of the printer counter-clockwise, and then remove the door.
  2. Insert the accessory into the back of the printer.
  3. If the lights remain on, remove the Two-Sided Printing Accessory by pressing in the buttons on the ends of the unit.
  4. Reinstall the Two-Sided Printing Accessory by pushing the unit back into the printer without pressing the buttons, until it snaps firmly into place.
If you need further assistance, you will find a link that explains all the lights on the printer here.
Also, Vista doesn't have any full feature drivers available yet, other than the default drivers supplied with Vista. For more information click here for some workarounds.
Hope this helps. Please remember to rate this information.
Thanks
Posted on Sep 03, 2008
  • S C Sep 03, 2008
    Hello again,
    I need to make a correction on that link for an explanation of the lights on your product. You can find that information here instead. I apologize for the mistake.
    Thanks
I have hp deskjet 5550 printer,when i was trying to print a document there is no print out, two lights are blinking
Hi, This could be Low-Ink or paper Jam. Try turning off The printer, Unplug from The Mains Electric, for 3-5 Minutes. Turn back On, if Lights Are Still There. Check The Ink-Levels. And Replace Cartridges, if necessary.
Mike.
Jun 02, 2011 | HP DeskJet 5550 InkJet Printer
Printer installation
The first thing I would try is to install the latest drivers for the printer. http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=dj-7095-2&lc=en&cc=us&dlc=en&product=71896&os=228&lang=en If that doesn't work, let me know.
Aug 27, 2007 | Toshiba Satellite A100-S8111TD Notebook
Hp 5550 deskjet not printing
This is typical cartridge problem.Which cartridge changed?This printer can print with the only one cartridge inside it, whatever which.Try this: Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
If this not help your printer has problem in carriage unit and need repair.
Nov 04, 2009 | HP DeskJet 5550 InkJet Printer
Using XP, my HP Deskjet 5550 printer allowed me to set margins of 0.5 inches and the document printed correctly. With my new Vista 64-bit OS, I get a message that the margins are outside the printable area...
Try when the message comes up click on print anyway. I have to do this with my printer sometimes and when I click print anyway and do not try to correct it prints fine.
Nov 01, 2009 | HP DeskJet 5550 InkJet Printer
Top light blinking, will not print
I believe that the top light is the low printer cartridge signal. Did you replace the cartridge or just take it out and reinstall it? Did you use a new HP cartridge or refilled cartridge?
Try a new ink cartridge from HP and double check that you have the correct cartridge for your printer. If that doesn't solve the problem, contact HP.
Sep 15, 2009 | HP DeskJet 5550 InkJet Printer
Hhp deskjet 5550 - orange and green light keep
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.) 2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.) 3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons. 4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times. Finally press the Power button.
Jun 09, 2009 | HP DeskJet 5550 InkJet Printer
My HP 5550 Deskjet won't print mirror image
You'll need to go to the manufacturer's site and find Vista drivers for your HP. Going from Win 98 to Vista is a major jump. I had to convert from XP to Vista and I still had to go get Vista drivers.
Also, make sure you get 32 or 64 bit drivers for the system.
May 12, 2009 | HP DeskJet 5550 InkJet Printer
Duplex not recognised
You need to set the duplexer to installed. For Vista this would be done as follows: go to the Printers folder, Right Click on the 5550, Run as Administrator, Properties, (continue), Device Settings, Installable Options, Duplex unit (set to Installed), Apply, OK.
Once you have done this in Vista the duplexer will work but the back side may print upside down regardless of the settings. This can be corrected with a patch available here.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Mar 13, 2009 | HP DeskJet 5550 InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
56 people viewed this question
Ben Johnson
