Question about Black & Decker String Trimmer Cordless 12" 18V
The auto feed doesn't - Black & Decker String Trimmer Cordless 12" 18V
  • snosha Aug 28, 2008
    do not know how to feed the string
    Problem Solver:
  • 18 Answers
See my answer to this under B&D Grass Hog Electric Trimmer.
Posted on Sep 02, 2008
My MD5000 doesn't feed manually or auto all of a sudden. Followed the manual. I can print test page from the cd forth e MD500
check and make sure that you have that printer as the default printer. Start,control panel,dvices and printers
Apr 08, 2012 | Alps MD 5000 Thermal Printer
Why does my Auto Feed Screwdriver not screw deep enough?
What model auto-feed screwdriver do you have? All of the auto-feed drivers I have worked on have an adjustable nose peice that has to be set to the length of the screw so they will start properly and drive correctly. They also have a fine tune adjustment wheel somehwere on the tool so you can set the screw to be anywhere from just below the surface (dimpled) or flush or slightly above the surface (proud). This is all in relation to the surface the nose peice is touching. The driver is designed to release the bit when the screw has reached the depth set by the adjustment wheel so it doesn't strip out the head of the screw. I don't know of any that would let you set it so the screw would go through the plasterboard (drywall) and end up flush in the wood.
Feb 15, 2012 | Makita Drills
2002 Dodge Caravan,3.3L,Engine won't turn over at the key.Battery,starter and relay are good.Relay doesn't function when plugged in.It has 2 feeds.If you run a ground to the ground side of the...
It has 2 feeds.If you run a ground to the ground side of the relay,engine turns over but doesn,t run ????? The PCM - engine computer isn't supplying the ground for some reason . Anti-theft system problem . Disables fuel an starting systems . Have you checked for codes ?DTC'S - diagnostic trouble codes .
Mar 04, 2018 | 2001 Dodge Grand Caravan
Hello my nane is Tom. The shredder doesn't work. It will run in reverse but when I turn it to forward it run for a second or two than stops. I looked and I can't see anything jamed in it.
I got mine to work by running it on reverse for a moment then sliding it to auto. It stopped. Then I did it again. This time auto ran just for a second then stopped. I did it a third time but I had a sheet of paper ready in the feeder. Ran on reverse. Slid it to auto and it took the paper and shred it. I did it a fourth time. Reverse slide auto and feed shred the paper. Fifth time Auto shred the paper without reverse. :)
Aug 30, 2011 | Aurora Electronics AS662C Shredder
Minolta Dialta Di151. Set to most dark position, very light in pages two sides, middle is ok. User auto feed is little better. Now the auto feed doesn't work. After press the copy button, you can still...
this machine have a plastis pick clutch spring take it out and turn it so that it is loged up and put it back the is also a new firmware virsion check your rom virsion it must be vir2.** it inprove paper feed bud does not sove the macanical pick problem do the clutch spring first and see if you can still get the firmware the firware is not a must but cut papper jaming calls down
Aug 06, 2011 | Konica Minolta DiALTA Di200 Copier
Printing
In the print menu, you will see a Settings or Properties where you can set your paper feed as manual or auto. It looks like you have set it up for manual feed. so you have to go back to that settings and change the paper feed to auto.
Hope this will work for you.
Good luck
luciana44
May 04, 2010 | Brother MFC-6890CDW Printer
I620-auto feeding multiple sheet
I opened the hood on the machine, and between the first two intake rollers on the bottom, there is a small rubber strip. This strip comes packaged with a sticky yellow tape to protect the rubber. When it was installed, no one removed this tape. After doing so, the machine feeds great. Hope this helps someone else who may be experiencing a similar feed issue.
Jul 16, 2008 | Kodak I620 SHTFEDSCAN Path-Through Scanner
Black line in auto feed
If you lift the scanner cover, you should see an area on the right end of the platen glass marked at the edge with arrows as Read Area. This is the area used when documents are scanned through the auto feed. Make sure that the glass is completely clean in this area, as any dirt will show up as a line on the copied image.
Apr 18, 2008 | Canon imageCLASS D880 All-In-One Laser...
Black & Decker String Trimmer Cordless 12" 18V Logo
200 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
