Question about RCA L32WD250 32 in. LCD HDTV
Rca l32wd250 telivision
I can not get no sound through television or receiver i also can not get picture on television from dvd player.
  • 3 more comments
  • frankairski Aug 24, 2008
    need help trouble shooting rca l32wd250 television ican not get no sound
  • loverslane Nov 28, 2008
    i AM HAVING THE SAME PROBLEM EVERYTHING WORKED FINE YESTERDAY BUT WHEN WE TURNED IT ON TODAY WE HAVE NO SOUND AND NO PIC FROM THE DVD PLAYER EITHER PLEASE HELP
  • bkopp13 Jan 08, 2009
    This TV is a piece of ****. None of my inputs function except for the HDMI input (no sound though). I complained to RCA, they wanted $400 to pay for shipping each way. I waited too long and the POS is out of warranty. I'm now using it as an enormous computer monitor, and the picture quality still looks horrible. Speakers fritzed out as well. Total and complete piece of junk.
  • bosteraas Apr 04, 2009
    my audio just stopped working yesterday.my dvd input also stopped working,hdmi still works but no sound.did you get your's fixed?
  • Anonymous Apr 29, 2009
    first the internal speakers went out, then no video from vcr input or s-video from the sony home theatre receiver, then garbage video from the sat dish.... RCA turns a deaf ear and blind mice attitude... america where did you go?
I have seen this posted on Google under RCA service bulletin #TV09-001 which states it is an open fuse on the digital board causing the symptoms. Not something I would recommend for a consumer to fix since it is a surface mounted fuse that is soldered to the circuit board. Very repairable by a service center. Good luck!
Posted on Dec 10, 2008
I want to connect sansui dvd to Samsung led television
There are typically 3 ways depending on the age of the dvd player.
Red White and Yello RCA Jacks (Out) of DVD to (IN) on tv Red, Green, Blue rca Jacks and red and whit rca jacks(Sound) Or, an HDMI cable which transfers both sound and picture.
Jun 17, 2014 | Televison & Video
Correct placing of leads from dvd player into back of TV?
If you are using RCA jacks to connect from the DVD player to the Television (RCA jacks are the connectors that have a white & red colored end for right and left speaker sound and another yellow end for video) connect one end to the back of the DVD player where it says "out going connections" and the other end to the television in the "incoming" connections. Remove your television antenna from the tv to the DVD player. The antenna signal goes to the DVD player and the Dvd player sends the picture outgoing to your tv set.
I hope this helps?
Sep 12, 2011 | Panasonic Televison & Video
When I turn on the tv I have very little sound and after a few minutes I lose that. Picture is clear so I don't think it is a connection problem.
Let verify first to narrow down to where the problem can be, attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Nov 20, 2009 | RCA L32WD250 32 in. LCD HDTV
Dvd player not working with sound
Ok, first thing is to know how it's hooked up. If you used RCA cables, the yellow plug is video, the red and white are audio. Make sure all your connections are "out" on the dvd and "in" on the receiver. If all this is correct, there may e an issue on the audio settings for your unit.
Jul 08, 2009 | RCA RT2300 System
RCA 32" LCD television Picture goes blank and then comes back on
which band of channels did you lose if is any that are not working like 2-7 it is your tuner and will need to be resoldered all the grounds
Jun 09, 2009 | RCA L32WD250 32 in. LCD HDTV
No picture with VIDEO INPUT, only AUDIO INPUT works
Hi ,disconnect the cable and leave the three RCA cables in.Switch off TV and DVD player ,then switch on tv and dvd player next .If you see the dvd picture and have sound then i think the cable box is overriding the rca channel.I normaly use a scart connection for the dvd to cable box then another scart from cable to tv.Hope this helps..
Feb 06, 2009 | Toshiba 37AV500U 37 in. LCD TV
No sound
Is the DVD player connected to the TV via component cables? If so you should have 5 connectors total that will bring picture and audio information to the TV.
Jun 22, 2008 | RCA D52W19 52" Rear Projection Television
Double image playing DVD's
check your picture in picture, sounds like your dvd imput is set for split screen, dvd on both sides
Apr 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
How to connect surround sound system, at the moment its connected through cable, each time we use the dvd player we have take them out of the cable box then into the dvd player, we have a LG 42PC55 tv.
In order of picture and sound quality -- from best to worst:
1. The best way to connect, assuming your TV and A/V Receiver and/or Cable Box have the jacks, is to use a HDMI cable ( this cable is for both sound and video).
2. Use Component Video out to input (3 RCA plugs, Red, Blue & Green) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
3. Use S-Video out to input (1 din plug) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
4. Use Video out to input (1 RCA plug, yellow) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
Be sure to select the correct inputs on your TV and Audio/Video receiver when you are watching TV. For example if you have connected your TV to HDMI 1 and DVD to HDMI 2, you will not see or hear anything if you don't select the correct input on your TV and A/V receiver for the input you want to see and hear.
Detailed connection instructions will be found in your owners' manuals.
Hope this helped you. :)
Mar 30, 2008 | Televison & Video
RCA L32WD250 32 in. LCD HDTV Logo
677 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
