Question about Fuji FP-988D 19" Flat Panel LCD Monitor
Color on monitor
No red tint on screen ????
    Champion:
  • 293 Answers
Hi..there,
Check your cable... see if is loose or pins damaged. If you have a DVI connection, switch to that cable. If the cables if OK...Then you need to replaced a new AD Board. Check out this website @ www.3rd-rocks.com They have the necessary replacement parts for your LCD monitor. Have a nice day!
Posted on Sep 07, 2008
Is the color filter going out?sometimes i have a red screen
The most common cause of a red or pnik tint to the picture is a weak or failing backlight tube. LCD monitors use very small florescent tubes to provide the backlight and when they start to go out the output red or pink tinted light not white. You can replace the bulbes but in most cases it is not worth the trouble. You should chack the date on the back of the monitor, if it is less than 3 years old then contact Samsung for a warranty repair, if older than 3 years then get a new monitor.
Feb 24, 2012 | Samsung SyncMaster 205BW LCD Monitor
HI,the color on my monitor has gone blueish its like
try reseating or/replacing the cable. If the connection isn't good then you can lose one of the three basic color channels resulting is a tinted screen color
Jan 08, 2010 | Acer AL1916B 19" LCD Monitor
Viewsonic VP930b color problem - Red tint
Go to the setup menu on the LCD panel by pressing button 1 on the front. See if there is an option to reset the lcd to factory settings. Reset it and report if it helps not.
Jul 29, 2009 | ViewSonic VP930b 19" LCD Monitor
My display has a red tint to it
Try adjusting the color properties of the monitor using the controls located on the front of the monitor.
If you can't correct the color, then it's a problem in the color circuit. As an ex tv repair guy I can tell you it may cost more than the monitor is worth to fix it unless it's still under warranty.
Jul 13, 2009 | Dell Computers & Internet
Can"t find white or comfortable background screen other than a light green that is hurting my eyes
If you have a screen that gets "tints" of various colors on a corner or edge, check that the monitor plugin cable is not near or laying on top of a power cable, the magnetic field around a power cord will cause a monitor to get strange tints or lines in the screen. Option two if the entire screen has a tint equally all over it is possibly the color is out of adjustment or failing - a technician should be able to adjust it internally.
Apr 29, 2009 | AOpen A75PF Monitor
Monitor red tint not functional.
Unplug the monitor cable from the computer and look into the cable where the metal connector are at. Everytime I've had a problem with one color not showing on the monitor, there has been a bent or flattened pin on the connector. Those pins can be bent out but be VERY carefull, they can break very easily.
Dec 22, 2008 | Gateway FPD1975W 19" LCD Monitor
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Monitor screen changes from regular color to a green tinted screen?
Is the cable connected securely? You may need to check your video card also. You may be able to disconnect the cable and get a red, green, blue icon on the screen. If that appears normal then there is nothing wrong with the monitor itself, it may be the cord or the video card.
Hope this helps!
May 31, 2008 | Dell 1503FP 15" LCD Monitor
Monitor is blue-evrything has a blue tint-i can see colors,they just have a ble tint
I've found that strange color tints are usually the result of a loose cable connection, either at the computer end of the monitor end.
Try unplugging both ends, and then replugging both nice and securely (might even try reversing the direction of the cable, if it is a simple VGA-VGA cable).
Feb 27, 2008 | Computers & Internet
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Fuji FP-988D 19" Flat Panel LCD Monitor Logo
57 people viewed this question
Top Fuji Computers & Internet Experts
Computer Links
Victorman
Victorman
robert
Are you a Fuji Computer and Internet Expert? Answer questions, earn points and help others
