Question about Amana Dryers
I own an Amana Heavy Duty dryer, model # NDE880AYW, and I'm trying to change a three prong cord for a four prong cord. I know nothing about electricals so I need help at a very elementary level. I have been able to connect the black, white and red wires correctly, I believe. My problem is where to connect the green wire. There are two green bolts on my dryer, one on an inside wall that already has a small white wire connected to it, (this wire is coming from the control panel at the top of the dryer) and another green bolt about 12 inches below the hole that the wires fit into. Do I connect it to the one on the inside, even though there's a wire already connected to it, or to the outside bolt? I would have to cut the black plastic casing that holds the four wires in order for the green wire to reach the outside bolt. What do I do?
  • Ohdipper Aug 26, 2008
    Rickzilla, I appreciate your addressing my problem. I remain confused about the white wire that is attached to the green bolt nearest the terminal block. You said to connect the green wire to the green bolt nearest the terminal block and that it was okay to connect the green wire to another green wire. The problem is that the wire already attached to the green bolt is WHITE, not green. Do I still attach the green wire to the green bolt nearest the terminal block even though that WHITE wire is attached to it? If not, what ever do I do with the green wire......the white wire......both wires? (I told you I know nothing about electricals. Please don't give up on me.)
  • 706 Answers
First off. Do any and all electrical connections with the PLUG detached from the wall receptacle.. The Green Wire is earth ground and should be connected to the nearest Chassis or Frame terminal.. There should be one near the terminal block for the two power ( red & black) and one neutral ( white).. It's OK to double up the green wire with other green wires.. so your answer is YES.. connect it to the nearest Green wire terminal.. This green wire provides protection to you and anyone else from getting electrocuted by bonding the frame/chassis as well as other sheet metal parts to earth ground.. Hope that helps...
Posted on Aug 24, 2008
  • Rick Gelin
    Rick Gelin Aug 26, 2008
    Regardless of the wire color being white or green, if the terminal is physically bolted into or part of the washer chassis/frame then that is a ground terminal. The white wire coming from your control box and tied to that green terminal may be a ground wire or a neutral tied there as well so having that white wire tied to a green wire is ok..
    The only thing you need to do with the green wire is make sure it is electrically secured to the washer frame/chassis. No worries on the white wire fastened there.. just leave it and add your green one to that terminal..
    On a side note: If you were to access you circuit breaker box in your basement and open it up ( not suggesting you do this... just providing some incite).. You would see the Neutral Buss and Ground Buss are bonded together ( so white wires... representing neutral and green wires representing ground are actually bonded to the same place in your basement...) just an FYI ... Hope this gets you up and going without apprehension or questions.. Regards, Rick
The house came with a three prong outlet and so we purchased the four prong but when installing there were only three wires...is that OK or does there need to be a fourth?
It is possible you may be trying to connect a 240-volt dryer to a circuit formerly used for a 120-volt dryer. The ID plate on your dryer should make this clear. Also, the NEC changed the connection requirements in 1996 just to add to the confusion. If you have any doubts where heavy-duty wiring is concerned it might be advisable to have an electrician handle things.
Jul 31, 2015 | Dryers
How do I change the three prong dryer cord to a three prong
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 25, 2011 | Amana NDE2330AY Electric Dryer
How do i change the dryer cord from a four prong to a three prong the cord i bought does not have colors to match to
most cities require an electrician to do those changes. there is some changes needed at the dryer too to convert from 4 to 3 wires. because of code regulation I will not attempt to explain it. we may be responsible or liable if anything goes wrong. sorry. wish you luck.
Feb 07, 2011 | Amana NDE2335AY Electric Dryer
I have a Heavy Duty Super capacity 5 cycle dryer 3 temp range. Dryer came with 4 prongs and my recepticle only has three. Can I replace three prong cord with a three prong cord and how do I do that?
Yes you can. The 4th prong is ground. Just make sure you have the device grounded in some way. So you have 2 hots...a neutral and a ground.
Jan 05, 2011 | Dryers
Changing dryer plug
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Oct 07, 2009 | Amana NDE2335AY Electric Dryer
Changing from a 3 prong to a four prong
grasshopper_2.gifWiring in a new power cord for your electric dryer? Upgrading your electric dryer outlet from the old three-prong to the new four-prong outlet? Well, grab hold of those two large lumps at the base of your spinal cord and let's romp through the wild and wacky world of dryer cords and outlets.
tn_3cord_dryer_terminal.jpgtn_4cord_dryer_terminal.jpgThese two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Jul 23, 2009 | Dryers
I need to change my eltric cor from a four wire to
The following link explains how to install a power cord for your appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Refer to the section that discusses converting from a 4-prong to a 3-prong power cord.
If you have questions, let me know. I hope this helps you.
PS The GREEN wire is ground and gets grounded to the appliance frame.
Jul 06, 2009 | Whirlpool LER4634J Electric Dryer
Need to change cords
If your dryer has only the three treminal block you should change the recptacle to a 3 wire. The difference in the 3 and 4 recptacle is that you have 2 hots, a neutral, and a ground prong. Find your dryer breaker in the box and just use the 2 hot and the neutral. Unless you can find a four terminal block for the dryer and even then would it mount to the dryer? Probably not. The extra ground simply grounds the cabinet to prevent damage. Your four wire recptacle may have a red and black(hot) a white(neutral) and a green or plain copper(ground)
Apr 06, 2009 | Amana Dryers
Amana Dryer
there should be instructions on the cord that you purchased. if not here it is, on your dryer, the 3 prongs are L1-N-L2.. and the green is a ground L1 line 1, L2 line 2, and N nuetral. L1 and L2 dont make a diff. as long as the whie(nuetral) is in middle terminal and the green screws to hte ground screw
Mar 18, 2008 | Amana DLE330RAW Electric Dryer
Dryers Logo
81 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
