SOURCE: Every time I start my
Hope you had deleted some files that relate to your system files.
Try to repair your system by Inserting your Windows XP Service Pack2. in your CD/DVD ROM and boot it again.
And if it's not working than you must format your system.
And installed it.
Here are the procedure to repair/install for reference.
Thanks for Using FixYa
All the Best!
SOURCE: this is problem in my laptop -- Windows Script
The only position that the ':' ("colon") can appear is immediately before the first '\'' ("slash") -- it's not allowed to have the ':' between the '\' and the 'Microsoft' strings.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\WPA\PosReady]
"Installed"=dword:00000001Save it, and then double-click the file. That will make that change to the registry. That's all you need to do. Windows will now automatically fetch updates designed for POSReady 2009, ensuring XP remains protected for the foreseeable future.
This trick only works for 32-bit editions of XP, but there's a workaround for 64-bit versionshere.
Naturally, there's no way of knowing how long this trick will work -- Microsoft could put a stop to it at any moment. Also, because you're installing updates for a system other than Windows XP, there's the possibility that not all updates will work as intended. But it's still worth a shot.
