Question about Canon PowerShot A540 Digital Camera
How do you change picture quality
I can change the picture size but can't seem to fine out how to change the resolution.
  • 4 Answers
No change
Posted on Aug 29, 2008
Problem with size of scanned document using HP laserjet 3380
It depends also on what you are scanning....half tones, pictures etc. but the easiest way to control the file size of PDF's is to change the resolution setting. Also referred to as the quality setting. These are settings like Super Fine, Fine, Standard. It should be right on your control panel. It is the same setting you can change when sending a fax. If your default setting is Fine for example, changing it to standard will use a lower resolution and reduce the file size. In other words the higher resolution/quality setting you use make the file size much larger.
Good Luck and Thank You for using Fixya.
Apr 06, 2010 | HP LaserJet 3380 All-In-One Printer
Change picture resoltion
While it is common to down size images without losing picture quality, it is unfortunately not really possible to Increase the size of an image without losing picture quality (As you are currently experiencing)
This is why most digital cameras have such a high resolution, so that they can produce very large images that may be scaled down to the end users requirements.
Nov 25, 2009 | Cell Phones
Change resolution
Press the menu button and go into the image mode setting. Use the right arrow to go into the table of quality options. Use the up/down on the dial to select the file size (quality) you want. You will then see the quantity of images the card has room for, at the selected resolution.
May 19, 2009 | Nikon COOLPIX L18 Digital Camera
I have a panasonic DMC-Fz8 12x optical zoom camera. How can I adjust the resolution? When I get my pictures developed they are low resolution; you can see the pixels.
Hi!
You need to change the PRINT SIZE and image QUALITY to have have a better picture. Try these:
Press 3049231.jpg then select aa5a871.jpg(Picture Size) . You will be given an option for the number of
pixels - ranges from 0.3 to 7 Megapixel. For better print quality, select 7M.
Next thing that you need to change is the Quality. You need to go back to Menu then 4e59df3.jpg. These are your options for quality:
I hope that helps.
Good luck and have a nice day!
Oct 02, 2008 | Panasonic Cameras
300 dpi
Shooting pictures in Fine quality will give you atleast 300 DPI resolution. Check your camera setup menu to see what quality you're shooting in, and adjust as necessary.
If you need to print 300dpi, this is done in whatever program you're using to output. In Photoshop, this is done by going to image>image size and changing Resolution to 300 (or whatever other resolution you want)
Apr 08, 2008 | Nikon D40x Digital Camera
Changing the picture resolution
Turn on your camera.
Trun the switch on the top of the camera to AUTO.
Press the middle button right of the display (x/-).
Then you can first change the size (7M, 6M, 5M, 5M, 3M, 1M).
If you now use the circle button on the right bottom and on this button you press up or down you can change the quality (very fine, fine, normal).
You can change the size and quality if you press left/right on the circle button.
Jan 04, 2008 | Samsung Digimax S730 Digital Camera
Changing Resolution On A Fuji A350 Camera
photos that have been already taken before any changes will not be affected after photo setting.Use camera menu or setup to look for RESOLUTION, PHOTO SETUP, IMAGE TYPE,STANDARD OR TYPE on menu to change photo resolution..
Dec 06, 2007 | Cameras
My sony cyber shot dsc-p32 camera
just change the resolution
set the camera on photo mode
then press trash button, it should display the resolutions
i recomend 1.3 megapixels for normal pictures, when you need the high resolution change it to better
also if you use the options of the photo mode you can change from fine to normal picture quality
Dec 04, 2007 | Sony Cyber-Shot DSC-P32 Digital Camera
Power shot A95
It is the setting on your camera ,if you set at (2592x1944) superfine ,you were only can take 11 picture.So if you want to take more pictures ,try set to lower resolution. Below is the setting table: Reso Quality Approx.file size # images on 32MB card Large (2592 x 1944) Superfine 2.4 MB 11 Fine 1.4 MB 21 Normal 695 KB 43 Medium 1 (2048 x 1536) Superfine 1.6 MB 18 Fine 893 KB 33 Normal 445 KB 67 Medium 2 (1600 x 1200) Superfine 1002 KB 30 Fine 558 KB 54 Normal 278 KB 107 Small (640 x 480) Superfine 249 KB 119 Fine 150 KB 195 Normal 84 KB 336
Aug 04, 2007 | Canon PowerShot A95 Digital Camera
FD73 Photo Quality
I'm guessing, cause i own a F505 and not a FD73......but, I dont even see a use for the F505 "standard" quality setting. It will stay on "FINE" quality always. I've got a HP 882c and it prints just fine. I use HP premium photo paper and the printer setting BEST. Are you using photo paper? Regular paper will bleed the colors around. Take some pictures on FINE and print them out on photo paper w/ printer BEST and compare.
Sep 11, 2005 | Sony Mavica MVC-FD73 Digital Camera
Canon PowerShot A540 Digital Camera Logo
109 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
