Question about Sony Boom Box With CD Player & Cassette Recorder,CFD-S01CD Radio/Cassette/CD Boombox
Cd won't spin on Sony CFD-101
With cover open, safety switch held down, I see:
The CD spindle does not rotate under power; but it also ceases to be able to be free spun by hand.
The red laser comes on okay.
The lens moves up & down trying to focus okay.
I read .013 ohms across both th spindle & laser drive motors.
There are no fuses that are obvious.
What next??
Vic
  • 30 Answers
SOURCE: Sony CFD-S300 boombox would not run CDs
what i would suggest you to do is get a q-tip and a little bit of rubbing alcohol on the tip and gently clean the lens let it dry
Posted on Jul 17, 2007
robmonroe
  • 67 Answers
SOURCE: disc doesnt spin , the lens dont move up and down , only lights red
Sounds like a motor issue, not a laser issue.
http://cgi.ebay.co.uk/PSTwo-Slim-DVD-Drive-Snake-Motor_W0QQitemZ290237209741QQcmdZViewItem?IMSfp=TL080609158a11571
That link is for a new snake motor which moves the laser back and forth
http://cgi.ebay.com.my/Playstation-2-Ps2-PS2-Spindle-Motor-V3_W0QQitemZ250083031090QQihZ015QQcategoryZ11328QQcmdZViewItem
This link is for a new spindle motor.
Posted on Jun 11, 2008
SOURCE: How to preset a radio station on Sony CFD-S200 Cassette/CD boombox
You will need to use the Forward and Reverse buttons on the CD player. Set the station by holding the button you want to set it to until it blinks and shows the station number.
To set more that 10 stations. Press the (>10) button and then enter 11 or 12 or so on and set the stations the same as above.
Posted on Jun 12, 2008
SOURCE: Sony PlayStation 2 - Does not read CD
Well i have just pulled a mates ps2 apart as he has had the same problem No Read Cds, i have found a component from the cd rom within the case. Soldered it back on and its back up running again...
Posted on Oct 24, 2008
  • 3 Answers
SOURCE: dvd rom in ps3 not reading
first of all its a blu ray drive. And sorry to say your probably out of luck, blu ray drives in ps3's ****, they are the cheapest blu ray drive on the market and they wear out fast. I think sony fixes them for 160$ without warrenty, if u do have warrenty just send it in. Hope this helps.
joel 098 (also have busted ps3)
Posted on Jan 02, 2009
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
Sony cfd-z110 cd seems to not spin/play when door/lid is closed but will play when lid is open and lid switch is depressed, is there any thing (maintence) that needs done on that round piece (that is...
your on the right track. the piece on top should spin really freely. there is a spring inside of that piece. if it lost its track it will lock it up from spinning. one other think it maybe is the tab is broken that presses the switch down. inspect both things if it ends up being the tab missing you can simple hot glue the switch down or dissemble and twists the two wires together (ones at the switch) that will bypass the switch. beware if you do this the laser will be active every time you have it in cd mode. (don't look at the laser it can harm your eyes) hope this helps please rate me.
Dec 31, 2010 | Sony ZS-S2IP Radio Boombox
My sony CFD-E100 won't recognize CDs
use a cotton swab to clean the optical lens-which is seen by opening the CD cover. if after cleaning the lens it still doesnt play a cd - exercise all manual switches(could be a dirty cd/radio switch), several times. after these steps, and the cd still refuses to spin...its hopless. the optic is bad.and not economical to repair. bet the cotton swab does the trick.
Mar 04, 2010 | Sony CFD-E100 Boombox
The CD spins, but will not play. It does not seem
Your laser head has probably gotten weak, or the spindle motor is worn. You can probably replace either yourself if you're VERY mechanically inclined, otherwise I would leave that up to a shop.
Good luck.
Dec 01, 2009 | Sony CFD-S300 Radio/Cassette/CD Boombox
Transport malfunction
In my opinion, spindle plate is pressed and when top cover lowered there is not enough / required gap between optical lens and CD so laser is not being focused to read data properly.
Please hook a flat screwdriver under spindle plate and turn it very carefully so spindle plate pushed upward little bit as shown below picture....hope this will work.
Nov 28, 2008 | Shanling CDT-100
No sound
it may just be the speakers
Jul 16, 2008 | Sony CFD-G500 Radio/Cassette/CD Boombox
Marantz CD48 - CD spins backwards
Check the small signal transistors BC338 and BC328, they're under the transport mech and will be near where the spindle motor plugs in to the PCB.
One of the transistors acts as a brake which momentarily puts the motor in reverse polarity to stop the CD rotating during 'stop' or 'open tray' modes. The reason the CD is spinning backwards is that the transistor which drives the spindle motor forwards during playback is faulty and is triggering the braking transistor hence spinning backwards.
The transistors should be 'BC328-25' / 'BC338-25' (25v)
Replace these and all should be well.
Hope this helps
Sep 05, 2007 | Marantz CD-48 CD Player
Cd player cant read disc
Check that the disk is still spinning. If not then suspect the spindle motor
Mar 23, 2007 | Sony CFD-S350 Radio/Cassette/CD Boombox
Sony Boom Box With CD Player & Cassette Recorder,CFD-S01CD Radio/Cassette/CD Boombox Logo
112 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
