Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Feezer still cold frig warm
It is a top freezer fan in freezer seems to be working but frig is warm.also freezer is starting to frost up
    Genius:
  • 1,122 Answers
YOU HAVE A DEFROST PROBLEM WITH YOUR FREEZER,CALL AN HONEST APPLIANCE REPAIR SHOP(NOT SEARS$$$$) IT CAN BE ONE OR MORE OF 6 THINGS,MIKE
Posted on Sep 13, 2008
  • 639 Answers
Glenn V,
ngfam1 at your service,
Happy to assist!
What is the model and year of your fridge?
Or rather how old is it?
1.-First is the freezer packed to the top where the frozen food covers the vents or air vents in the freezer?
The freezer and the refrigerator share the compressor and the cold air and the vents or passages between them must be kept some what clear! This can cause the warm fridge some times!
2.- Did you ever clean the tons of dust accumulated under the fridge on the condenser?
You gently pull off the front grill and with a flash light while laying on the floor eye ball the situation under the fridge!
If it's full of dust 2 inches high and all the way across and you can not see the thin black tubes of the condenser then this is the reason!! You need a refrigerator brush from home depot or some place to clean it out! A VACUUM WILL NOT FIR IN THERE ! AND BE CAREFUL AND GENTLE THE FREON RUNS THROUGH THOSE TUBES!
I've seen this many times that the folks never ever ran a refrigerator brush under there as long as they owned the fridge!
And the next day, 24 hours later it was up to full temperature!!!!!!!!!!!!!!! if you can not remove the grill, open the user guide and the book will tell you how to install the grill by pressing with your fingertips at the top and bottom of two clips or flaps of plastic that are part of the grill. One set top and bottom about 6-8 inches from the left end and the opposite on the right end!
If there is no condenser under neath and it is in the rear of the fridge you will recognize it in the back ,being thin black tubes running up and down the back of the fridge! ITS ONLY ON REAL OLD MODELS OR REAL CHEAPPPPPPPPPPPP MODELS.
THE BOTTOM OF THE LINE FRIDGES!
IF THEIS DOES NOT WORK YOU MAY NEED TO CALL A&E FACTORY SERVICE AT 1 800-905-9505 24/7
IF THE FRIDGE IS 9 YEARS OLD OR MORE , DO NOT INVERST ANY GOOD MONEY INTO A BAD FRIDGE. And buying a new one will save you money on the elctric bill!
They are all much more effiecent than the older ones!
And it will pay for it self in a few years!
ngfam1 Bless YOu,
please give me the best rating here on fixya.com befroe you sighn off!
Let me know if it works!
Posted on Sep 01, 2008
Unplugged frig overnite once I plugged back in made a gurgeling sound whenever I opened the door what would that be?
Usually that is caused by a bad defrost heater thermostat or defrost timer. Failure to automatically defrost is the cause of freezing up.
If you don't feel up to doing the work yourself you should have an appliance repair shop look at it.
The gurgling is caused by water in the catch pan under the fridge. When you defrosted it some of the water made it into the drip pan (and maybe overflowed onto the floor). The fan inside the compressor area under and behind the freezer may be splashing in the excess water in the drip pan. This by itself is not a real problem since it is designed to automatically evaporate the water drained during automatic defrosting, but the excess water and potential overflow onto the floor can become a problem.
Mar 10, 2017 | Danby DFF8802 Top Freezer Refrigerator
MY FRIG DOES NOT SEEM TO BE WORKING IT IS WARM
If your freezer seems to be working, then the problem is probably in the freezer section. If you remove the inner shield of the freezer and see a lot of ice around the evaporator coil then your defrost circuit is not working. If the fan is not operating, it will not blow cold air into the fresh food side. If the cooling tubes between the freezer and fresh food side are blocked or frosted up that would not allow the cold air to pass.
Since you say it is an Amana, I would suspect either the fan or the defrost circuit.
Jan 08, 2012 | Amana Refrigerators
Freezer is very cold but main frig is not cold at all, we defrosted cleaned all ice built up under plate in freezer and still warm
did you check freezer fan behind the freezer? If not working check the wiring for it. If broken fan replace it. Find no leak in door gasket. Temp setting must be at least 5 degree.Thanks.
Jan 30, 2011 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Feezer cold frig.warm
sounds like your freezer is not defrosting, causing lack of air flow to fresh food side
May 09, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Frost in freezer fridge warm
Sounds like the circulating fan behind the rear panel inside the freezer section is starting to go bad, This problem is very hard to diagnose because the fan still spins but at a much lower rate than needed to circulate chilled air thru the freezer and the frig. The minimum cost for parts and labor is around $300.00.
Aug 02, 2009 | Maytag MFD2561HE Bottom Freezer French...
Freezer fan not running
Often times the defrost termination switch (which opens when it gets warm enough) will hold the fan off until it closes again when the freezer runs. It is possible that the switch is not closing, but be sure the freezer is getting cold enough for it to close.
You know the freezer is likely cold enough when you see frost covering the entire evaporator coil after a few hours of operation. A partial frost pattern could indicate low refrigerant, or a restriction of refrigerant.
May 29, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Top sections of Freezer and Fridge not Cold at all
hi!!! You seem to have a problem with your evaporator fan motor or the defrost mechanism on the frig.That the defrost timer..Listen manually turn of your refrigerature and turn it on again when all the ice melts away if the fan work or runs then its your defrost timer on the frig.Easy fix man..Good luck..
Jan 03, 2009 | KitchenAid KSRG25FKSS Side by Side...
HSS25IFMDWW- freezer frosting up but working
sounds like the defrost thermostat or you may have a crack in the water line causing the freezing.
Jun 10, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
125 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
