Question about Dryers
My clothes are not drying fast enough - Dryers
  • 2 more comments
  • Carrie Dawson
    Carrie Dawson Aug 24, 2008
    I have the same problem. The dryer is only 2 years old. Not sure if this would be under warranty or not, but it's taking a really long time to dry anything.
  • zanimul Dec 13, 2008
    My dryer is heating, but not sure if it is getting as hot as it should. Wet towels are still pretty much wet even after four cycles in the dryer (whereas it used to take 1 to completely dry). I've cleaned the lint trap completely and air seems to be moving out the vent normally. However, I cannot tell if the volume is good as the opening is about 10ft up under the roof soffit.
  • Laurabean113 Dec 29, 2008
    We've checked the vent, checked the filter, the drum spins, the clothes feel warm, but not hot and do not dry.
  • Lola116 Jan 09, 2009
    I have the same problem as well. Dryer is less than three years old. Never dried great but worse now. I clean lint traps religiously and have tried extra dry option to no avail. Towels seem to not dry at all.
Hello. I was the last person to post with problems with the Miele T1403 Electric dryer. Just wanted everyone to know I solved my problem and this could solve yours as well. To reiterate I too was frustrated with clothes that would not dry. I could feel heat but the vent/filter light would keep beeping and evetually turn off my dryer. The result would be damp clothes especially towels!! I had a certified Miele dealer come in and check out the machine. This was after I completely cleaned out the lint trap the inside of the machine, and the duct connecting it to the wall. Well they looked at everything and determined nothing was wrong with dryer and I had done a great job cleaning it. Armed with this info I was referred to a company that specializes in cleaning the entire interior duct system of the dryer(Not just the lint trap, inside of machine, and connector tubing). They came today and disconnected the machine again went into the attic and used a shopvac type of machine to really clean the entire duct system. Not rocket science but viola problem solved!! You could probably do this yourself if you have a shopvac with a long attachment (depending on how many bends your system has). The machine is working great and now I know to clean the system at least once or twice a year. I was told that slow drying clothes, extra moisture, machines that are very hot to the touch,etc. can all be symptoms of a blocked vent. By the way a blockage can be a fire hazard. This solution is a lot cheaper than a service call or worse getting a new dryer. I wouldn't listen to the hype about European dryers like Miele or Bosch not drying clothes all the way-could just be a blockage. These brands are very good at shutting themselves off when they get hot (which is a good thing).
Posted on Jan 16, 2009
    Sergeant:
  • 351 Answers
Wash the filters and check the venting.normally cleaning wont be covered by warranty.
Posted on Aug 27, 2008
How come my washing machine cannot spin dry my clothes even I put the function for spin dry
not spinning fast enough
call an technician to check program board or for other faults
Sep 26, 2016 | Washing Machines
Clothes don't spin dry enough
you mean to say the clothes are tangled with each other tightly right?
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hoover 2305L goes through all cycles well.does not spin fast enough to dry clothes.
how old is the 7 kg washing machine
should be direct drive to the drum not a belt drive
the motor could be wearing out
are you over loading
May 11, 2016 | Hoover Washing Machines
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Washer would spin dry but the clothes is still wet
Sounds like your transmission is starting to go bad. It is not creating enough power to spin fast enough to dry the clothes. A new transmission is going to run about 400 I would start shopping for new machines. Do light loads of laundry til you get a new washer..
Jul 14, 2011 | Whirlpool Washing Machines
Kenmore Automatic Washer Model 110.24642300 - problem is that spin cycle is not fast enough to get the water out, so clothing is sopping wet and loose at the bottom of the tub instead of plastered to the...
Your transmission is starting to go bad. It is not creating enough power to spin the clothes fast enough to dry them. It is cheaper to look for a new washer . To fix the transmission will cost you over 400 I would do light loads until your able to get a new washer
Jul 12, 2011 | Washing Machines
I have a L G and it does not spin dry the wash load How can this be fixed
Do you mean it doesn't spin at all...or it doesn't spin fast enough to dry the clothes?
If it will not spin at all you may have a loose belt or broken belt.
If it does not spin fast enough, you may have a loose belt or too latge a load.
Jun 26, 2011 | Washing Machines
Spin is not going fast enough to dry out clothes
spin is not suppose to dry the clothes, simply wring the most water it can from them.
are you sure you are not set on a gentle cycle? might your washer offer a extra spin cycle?
Dec 14, 2009 | Computers & Internet
Spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Feb 21, 2009 | Maytag Performa PAV2200
Broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Jan 07, 2008 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
1,069 people viewed this question
Top Dryers Experts
