Question about Kenmore 22422 Top Load Washer
Kenmore ultra 2 dishwasher
Inside the door where u put the soap tabs, do u snap the door shut or leave it loose,reason being we did a load
last night and i snaped it shut,the soap tab never disvolved
  • 943 Answers
Hi thanks for the question leave the little door open when using the soap tabs thanks the appliance doc
Posted on Sep 27, 2008
Kenmore Ultra Wash Dishwasher door won't open
It seems most likely door latch stock and you going to need buy new door latch as for stock one most likely you hsve to forceit to open and replace it with new one
Dec 09, 2013 | Kenmore Dishwashers
Maytag washer, quiet series 200 can't get it to brting water ect
check your water supply from the tap to the dishwasher
Jun 28, 2010 | Dishwashers
Need instruction manual
Yes you put the dishwasher soap in the soap dispenser. Then you close the lid to it. then shut the door and start the dishwasher.
Apr 19, 2010 | Kenmore 24 in. 17602 / 17604 / 17609...
Dishwasher only a couple of months old. Ran it
The water may not be hot enough. Increase the temperature of the incoming hot water or try this: put the tab in the open soap cup so it will start to dissolve during the pre-wash. Then it will finish dissolving during the main wash. If the dishes get clean using this method you may not have to increase the water temp.
Aug 25, 2009 | Dishwashers
Kenmore ultra wash dishwasher control lock light flashing
Just press the 'Air Dry' button for 5-6 seconds....I have an ancient Kenmore Dishwasher (ULTRA)
Oct 02, 2008 | Kenmore 15899 Built-in Dishwasher
Soap doesn't dissolve
Possible problems:
1. Too much soap! For soft water use no more than 1 1/2 tablespoons.
Give dishes a good scrape and put them in. If you MUST prerinse dishes (and you shouldn't) drop down to about 1 TSP soap. Modern DW's use less water and soap is more concentrated.
2. Water not hot enough. Test water temp at kitchen faucet with thermometer. It should read at least 120 deg.
3. Our service guys recommend not using lipuid soap, only powder. I listen to them.
4. Broken control to soap door. If it is still closed after a cycle, ask for help from a service company.
Aug 16, 2008 | Kenmore 15892 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher: Lock On Button Issue
Have to hold the Air Dry button down til your finger hurts. Release button and the light will go off. The "4 second press" in the manual is incorrect!
May 26, 2008 | Dishwashers
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
Kenmore Ultra Wash 3 Leaking
Got a possible solution from a brilliant guy named Jake on another website and thought I would post it back here.
"Check the door vent on the inner side of the door, that should just snap out, I have seen those clog and start making more pressure inside to make it leak from the bottom. Jake"
I checked mine and got a nasty surprise. Who knew it could get so dirty.
Nov 01, 2007 | Kenmore 15129 Built-in Dishwasher
Kenmore 22422 Top Load Washer Logo
Sal De GO PATS
fordexpert
Ed Mac
