Question about Olympus Camedia D-435 Digital Camera
AC adapter Is there an AC adapter available for the D-435 camera?
    Master:
  • 852 Answers
The AC adapter recommended for use with the D-435 is the E-7AU (item# 200751). Use this adapter to conserve batteries when downloading to your computer, extended studio shoots, during printing, or while viewing images while connected to your TV or VCR. This can be purchased through our authorized dealers, or via the Olympus Emporium.
Posted on Aug 31, 2005
No it not digital cameras, it a Kodak Star 435.
The Kodak Star 435 uses standard 35mm film, also known as size 135. 35mm film is available in a variety of lengths: 12-, 20-, 24, and 36-exposure.
You can get 35mm film for black-and-white prints, color prints, and color slides at any decent camera store. Many supermarkets and drugstores also carry 35mm film, though not as wide a selection. And, of course, you can buy film online.
Jan 23, 2015 | Kodak Cameras
Camera does not respond
I see you can't even look on the screen, because you have to start the camera first, before you can switch between taking pictures and viewing. You you not even can see an error displayed on the screen.
Most obvious is the battery, or its connections. The manual says:
"The camera does not work even when batteries are installed."
Insert recharged batteries in the correct direction. "Inserting the battery and the SD/SDHC/SDXC memory card (sold separately)" (p. 13), "Charging the battery and setting up using the supplied CD" (p. 14), "Charging the battery with the supplied USB-AC adapter" (p. 17)
Battery performance may have been reduced temporarily due to low temperature. Take the batteries out of the camera, and warm them by putting them in your pocket for a while.
Then to make sure it is not the battery they advice to connect an external USB-AC adapter.:
An F-3AC USB-AC adapter (available separately) is recommended if the camera will be used for extended periods.
Note that the power cable supplied with the USB-AC adapter is for use exclusively with the USB-AC adapter. Do not use with other devices.
With the adapter, the voltage (and current it can deliver) could be enough to switch on the camera.
If it works, you should take aout the battery and check if the connection point of the battery and in the camera are clean and shiny. If not, please clean them with a dry cloth. Never use a sharp tool to clean electronic contacts. The manual says the battery will live up to 300 charge / discharge cycles. If the camera won't work with the battery and it works with the USB AC adapter, replace the battery.
Nov 16, 2013 | Olympus XZ-1 Digital Camera
Whats the part number for the ac power supply for CCD-TRV37
If you are looking for power adapter for CCD-TRV37 then AC charger model number is
AC-L10A / L15
Available in Part Store.
Mar 04, 2009 | Sony Handycam CCD-TRV37 Camcorder
Printer will not charge camera batteries. camera screen said to go on line and look for m627-435
Did you go online and look up this troubleshooting tip from HP?  Did you make sure the batteries are rechargeable and in the correct orientation ( + and - )? Here is the results from looking up the error code M627-435 at the HP website:
Solution
  1. Ensure that the batteries are rechargeable. If the batteries are not rechargeable, replace them with rechargeable batteries.
  2. If the batteries are rechargeable, take them out and check for obvious physical damage. If the batteries are damaged, replace the batteries with rechargeable batteries in good physical condition.
  3. If the batteries are in good condition, charge the batteries using the external charger that shipped with the camera before using them in the camera for the first time.
  4. If you have tried each of the steps above and the status message still displays when you try to charge the batteries, replace the batteries.
Cause The Batteries cannot be charged status message is usually caused by one of the following:
  • When first connected to an optional HP AC power adapter or placed on an optional dock, the camera performs a test to determine if the batteries are rechargeable. If the test determines that the batteries are non-rechargeable, an status message displays in the LCD.
  • If the battery charge falls below 1.1 volts, the camera cannot detect that the batteries are rechargeable. The camera does not charge batteries below a 1.1-volt threshold to prevent charging non-rechargeable batteries. Rechargeable batteries discharged below 1.1 volts can be charged in an external charger.
    Apparently, your batteries are either seriously discharged where you need to use an external AC charger to recharge the batteries or their damagaed and need replacing. Hope this helps.
Oct 31, 2008 | HP Cameras
AC adapter supplied by a third party
No, Minolta cannot guarantee the compatibility of any third party AC Adapters. We recommend the use of Minolta AC Adapters, AC-1L, and AC-2L. Any damage caused to the camera as a result of use of a third party AC Adapter may void your warranty.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
What optional accessories are available?
Camera Case CS-DG900, CS-DG501, Leather Neck Strap NS-DG1000 USA/CANADA/TAIWAN/JAPAN : AC adapter AC-1L EUROPE /SINGAPORE/UK/HONG KONG/CHINA : AC adapter AC-11 Wide-Angle Converter ZCW-300 KIT Adapter ring for filter/converter ZCA-300
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
A/C adapter
Yes, the D-7AC AC Adapter is available.
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
AC adapter
The AC adapter recommended for use with the D-630 is the D-7AU (item# 200850). Use this adapter to conserve batteries when downloading to your computer, extended studio shoots, during printing, or while viewing images while connected to your TV or VCR. This can be purchased through authorized dealers or through the Olympus Emporium.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
A/C adapter
Yes. The model is E-7AU. Use this 110V/120V AC Adapter to conserve batteries when downloading to your computer, for extended work in a studio, during printing, or while viewing images while connected to your TV or VCR. The Olympus stock number is 200 751.
Sep 01, 2005 | Olympus D-575 Zoom Digital Camera
A/C adapter
The A/C adapter recommended for use with the D-425 Camera is the E-7AU. Use this 110V/120V AC Adapter to conserve batteries when downloading to your computer, for extended work in a studio, during printing, or while viewing images while connected to your TV or VCR. You can purchase this through the Olympus Emporium or 1-800-201-7766.
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Olympus Camedia D-435 Digital Camera Logo
42 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you an Olympus Camera Expert? Answer questions, earn points and help others
