Question about Samsung 1200W 5.1-Ch. XM-Ready Home Theater System w/5-Disc Upconvert DVD Player
Cooling fan in reciever noise.
Is there a way to not have the cooling fan run all of the time? Mine comes on as soon as you cut the system on and runs the entire time.
  • 10,594 Answers
Its necessary to run cooling fan because Amplifiers in home theater system produce heat during its operation. If you shut down cooling fan, Amplifier ICs may be damaged due to over heat.
Posted on Aug 24, 2008
Where can I get a cooling fan wiring diagram?
The cooling fans should come with a sensor and tells fans to come on at certain temperature
Jan 02, 2016 | 1998 Plymouth Voyager
When my cooling fan kicks on it runs intermittently.
The fan will only run when it needs to. It's on a sensor. The only time mine comes on is if I'm hauling something
Sep 09, 2015 | Polaris 2013 Sportsman 500 HO
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
Air handler fan cuts on runs a few minutes and then cuts although thermostat is set to off.
your thermostat could be wired in to a energy recovery venilator which will bring the unit on for a certain amount of time every hour some thermostats have recirculate mode which will do the same thing to help filter the air
Apr 16, 2013 | Goodman Heating & Cooling
Overheating
there is a crack in the head or cylinder wall . test
Mar 20, 2012 | kawasaki GPZ 1100 Motorcycles
I have a 2001 intredpid 3.2 that is overheating. The passenger side cooling fan will not cut on. I just changed the fan motor yesterday and I still haven't seen the fan cut on. Since I changed the...
First off, there is a number of reason why u are hearing bubbling noises but first lets address your Fan. I take it that u have a 2 fan setup, when you say " The passenger side cooling fan will not cut in". This fan is associated with the AC, and only comes on when the AC runs. Helps with better air flow thru the condenser which is in front of the rad. Does the AC work?
OK, now for the bubbling noise. First off the noise indicates to me that maybe you still have problems with over heating. Does the fan on the drivers side come on? Where is the Temp gauge at when it does come on? You might have air in the system, which canbe bleed thru a bleeder screw on top of the motor. I found the best way to do this is have the frt of the car elevated abit with the car off when filling the coolant reservoir. Other things associated with over heating, thermostat not opening, or stuck open. Head gasket, possibly exhaust is getting into cooling system, building up pressure which vents when you shut engine off. Hench the sound. Water pump possibly leaking.
Aug 30, 2011 | 2001 Dodge Intrepid
What temp should my golf run at if the cooling system is operating properly? Runs perfectly on the highway but when i stop start it goes from min temp to only half on the gauge but seems to be runnning...
the temp seems to be fine. 80degrees celsius or less in stop and go traffic is normal,especially since the cooling fans are working and coming on at the proper time. the what seems to be running rough is another problem that doesn't seem to related to the cooling system temp. may want to check the spark plugs for worn electrodes.
Aug 08, 2011 | 1994 Volkswagen Golf
2004 Jaguar XJ8 with 60,000 miles. A/C was working intermittently, so took to dealer to fix. They found a "leaky" o-ring, replaced it, and recharged the system. No other problems found. Problem still...
sounds like you have a blockage in the system the fans come in to cool the condensor, have you had the system flushed and the receiver/drier replaced? or there maybe moisture in the system which will create ice in the system and cause a restriction or the ext. temp sensor is faulty
Jun 08, 2017 | 2005 Jaguar XJ-Series
Samsung 1200W 5.1-Ch. XM-Ready Home Theater System w/5-Disc Upconvert DVD Player Logo
280 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
