Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Same problem but the suction still not working
I have the same problem with no suction and the air escaping out the top vent.  i checked the u shaped tube on the lower portion as you suggested and it was clear.   i've also check all the wands, tubes, etc.  any other suggestions?  thanks in advance.
  • 3 more comments
  • Deej1069 Oct 01, 2008
    I am having a similar problem. My Dyson DC14 seems to be working fine in the vaccum mode, but when i put the vacuum upright to take out the wand it makes this loud noise "air noise", if that makes sense, and there is little to no suction coming from the wand. Is this kindof what is happening to you? Do you hear a different sound when you go from vacuuming to upright to use the wand?
  • Paul Humberstone Nov 02, 2008
    I have exactly the same problem.
    Does anyone know what's happening!
  • HMLEROY2 Nov 14, 2008
    TOOK IT APART TO CLEAN IT, AND THE SUCTION FROM THE HOSE STOPPED WORKING. AND YES, I PUT IT BACK TOGETHER THE SAME WAY IT CAME APART! :-)
  • Anonymous Dec 26, 2008
    My dyson sucks from the hose, ut not main
  • doylestowned Dec 27, 2008
    Air escaping out of top vent just above where filter goes. Can't get it to work. Aren't these supposed to be good vaccuums?.
  • 107 Answers
Try taking off the U bend and see if there is suction coming out from where the right end of the U bend connects. If there is suction then the problem lies after the u bend in the hose or wand.
Posted on Dec 11, 2008
  • Joe Lepe Dec 11, 2008
    Also take a battery or a weighted object and drop it down the wand to see if there is any blockage Clog is most likely cause. dead motor can cause bad suction but will make a funny noise and smell.
AFTER NOT USING THE HOSE ATTACHMENT FOREVER, I FINALLY BROUGHT IT IN. (NEAREST SERVICE CENTER IS 55 MILES AWAY FROM MY HOUSE). ON THE VERY TOP, WHERE THE FLEXIBLE, RETRACTABLE PART OF THE WAND ENTERS THE PLASTIC MOUNTED PIECE ON THE BODY, WAS A WATER BOTTLE CAP. IT HAD LOOKED LIKE IT WAS PART OF THE VACCUUM, LOOKED LIKE THE SAME COLOR AND ALL. HE DROPPED A SCREWDRIVER THRU THE TUBE TO PUSH IT OUT. FELT LIKE A TOTAL IDIOT. THE REPAIRMAN SAID IT HAPPENS ALL THE TIME.
I REPLACED MY CLUTCH WHILE I WAS THERE TOO. MY VACCUUM IS 5 YEARS OLD, AND HE TOLD ME I WAS LUCKY IT WAS STILL AROUND. HE SAID THE NEW ONES WERE BETTER, BUT DIDNT SEEM TO IMPRESSED. I DO LOVE THE DYSON, BUT $120 FOR A CLUTCH WAS PAINFUL. BUT, ON THE OTHER HAND, I WOULD PURCHASE ANOTHER DYSON IN A HEARTBEAT
I HOPE IT'S MERELY AN INVISIBLE CAP FOR ALL OF YOU!
Posted on Dec 12, 2008
My Shark Navigator works very well, great suction. However, it is very hard to push on carpet. Can this be adjusted?
Two things make carpet vacing easier. First is the floor piece. It should be a smooth slight rounded shaped piece with just a small line of bristles or none at all. Second is mostly for area rugs is to open the suction vent usually located near the handle. That allows some air in which takes suction away from the floor piece allowing it to slide on the rug rather than drag it around.
May 02, 2015 | Shark Vacuums
I have a dc19. It has lost suction and air is coming out of the vent by the cord release button. What can i do to repair it
John, as you know air flow and CFM of the air is what makes the vacuum work. There is rubber seals or gaskets all along the air way to keep the air moving from the floor through the vacuum motor. You need to be sure a gasket has not wore out and allowing the vacuum air to escape. The vacuum motor must have a place exhaust the used vacuum and that pathway also has seals to insure it leaves the machine at the place the engineer who designed the machine wanted to go. Check for worn seals/gaskets in both incoming and outgoing airways. D&R Services, Inc.
Dec 15, 2014 | Vacuums
Vax mach air reach suction problems
Thanks to N3FAR. It was very helpful, i have been callinv Vax and they are asking me to do all sorts of other things. Thanks you again
Dec 31, 2012 | Vacuums
Low suction
I suspect the hoses are plugged with debris.
Apr 21, 2017 | Hoover L2310 GUV Central System Vacuum
No vacumm pressure. the passages are clear and the motor runs but there is very little suction.
if you are certain no blockages ? and the dust collector is clear/clean ? have you checked that the outlet filter which is located inside dust compartment is clean/clear this is usually a gauze filter its purpose is - as vac works and draws dust into collector the air that is sucked up thro vac builds up in collector chamber or bag on most vacs? and so for vac to maintain suction the air has to be able to escape to atmosphere/room without dust which is left insude chamber/bag if fitted and so air escapes via the gauze vent as prev mentioned ? however if gauze filter is not clear to vent then vacuuum is restricted due to air drawn being unable to expel sometimes on vacs they will eventually cut off due to o/heat but will operate when cooled so may i suggest checking the above possibility ?
Dec 13, 2009 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Low Suction When Using the hoses on the Dyson Animal
there is a washable filter either on the side of the motor or in the dust cup clean it out using water make sure it is dry before reinstalling also check for clogs there are several pices that are removeable the peice under the hose and vent clip? on the side remove and check for clogs
May 22, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Loss of suction, loud blowing noise
Hi.
Try cleaning out the vortex this will sort out poor suction.
http://dysonmanuals.llc.nu/
Oct 16, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Suction problem
first thing you need to do is replace the disc filter benieth the conical shaped shroud. also there is batting in the upper part of the vacuum tat should be replaced once every 4 years as well as it gets clogged with carbonfrom the motor. this increases the air flow through the vacuum keeping the motor cool and increasing your suction as well. the disc filter benieth the conical shroud should be replaced every 6 months under normal use and every 3 months under really dusty situations, and if vacuuming up fine talk powder every month. also check for a clog in the hose by hooking the hose up to the blower port on the top of the vacuum.
Sep 15, 2008 | Filter Queen Majestic Canister Vacuum
Dyson blowing top of cyclone air release valve.
It sounds like the same problem I was having. I had loss of suction through he hose then all of the air was coming out through the vent/valve on top of canister. If you are looking at your dyson from the back, look at the bottom. You will see a purple plastic tab on the bottom left. That allows you to remove the plastic u-shaped hose that goes from the hose to the bottom of the dyson. I just removed that and found it was completley blocked. I removed it and the dyson has no loss of suction orair through top valve/vent. I hope this helps. I never post but i'm just excited that I got my dyson working perfectly again.
Jul 08, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Sudden loss of suction.
Check the inlet down by the brush roll to see if it is clogged. Also check the belt to be sure it is ok. Is there suction at the hose? If not then it is still clogged.
Oct 30, 2007 | Kenmore 33721 Upright Vacuum
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
265 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
