Computers & Internet Logo
Posted on Jul 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wont install its a ZEN V PLUS ON WINDOWS VISTA PREMIUM ERROR 10 MAY BE O.S. PROBLEM THE NEW APPLICATION RIGHT FROM OEM FAILED TO INSTALL MULTUBLE ERRORS for the zen its 4 years old so dont kill me is it woth a few bucks to fix
  • syncere98 Jul 05, 2011
    thanx but i had to email you guys back none of your answers worked i was up all night workin on it for my son im pc savey so u can explain in more detail if another solution is in your head its just this mp3 it has me STUMPED THE PC IS NOT RECONIZING THE DEVICE WHICH IN TURN IS MAKIN IT IMPOSSIBLE TO INSTALL ANY APP OR FIRMWARE IF THE DEVICE ITSELF IS NOT INSTALLING I GET A DRIVER LOADED FOR THIS DEVICE BUT ENCOUNTERED AN ERROR CODE 10 SO THE DRIVER INSTALLS FOR A SECOND AND THEN IS KICKED OUT boy this has me baffled all my other devices are fine loading drivers its 4AM HERE I GOT AN EMAIL FROM FIXYA BECAUSE I EMAILED THEM TODAY VOICING MY NONE SATISFACTION SO THEY SENT A LINK TO EITHER WORK WITH YOU ON ANOTHER SOLUTION OR A TECH OF MY CHOICE BUT IM TO TIRED NOW AND I HAVE WORK SO I WILL RESPOND TO THE LINK AS SOON AS I GET HOME THANX AGAIN YOU TRIED AND IF THIS WASNT THE MP3 FROM HE.. YOUR ANSWER PROBLABLBY WOULD HAVE WORKED IN FACT I DID THAT JUST BEFORE I CONTACTED YOUR CO, SO U WILL HEAR FROM ME ABOUT 4PM THANK YOU
    Best Regards
    Mike
Anonymous
Level 3:
  • Master 844 Answers
  • Posted on Jul 03, 2011
Anonymous
Master
Level 3:
Answers
844
Questions
Helped
418537
Points
2542
Welcome to FixYa!
Solution 1.
Do Windows Update. It will download and install the service packs that you need as well as the latest driver for your ZEN V Plus if it has found one. Make sure to install all the suggested updates.
  • Click Start
  • Type windows update in the search box
  • Click the Windows Update icon from the search list
  • Windows Update windows will open
  • Click the Check for updates button
  • It will show number of updates available
  • Click Install Updates
  • The updates may take a while and your computer might restart a couple of times
Solution 2.
Install the driver/software manually. (Make sure you installed windows update)
Requirements:
  • Microsoft® Windows Vista™
  • Windows Media® Player 11
  • USB 1.1 port (USB 2.0 recommended for faster transfers)
  • Creative ZEN V or ZEN V Plus
Notes:
  • To install this software pack
    1. Download the ZNV_PCApp64_LA_6_41_10.exe file into your local hard disk.
    2. Close all application and Windows Explorer windows that are currently running.
    3. Connect your player to your computer.
    4. Double-click the downloaded file and follow the instructions on the screen.
This software pack includes the following:
  • Creative Media Explorer (version 6.41.10)
    Enables you to manage your player easily in the familiar "Windows Explorer" environment
  • Creative Audio CD Ripper (version 5.20.10)
    Extracts songs from an audio CD and transfers them to your player
  • Creative Sync Manager (version 6.03.21)
    Synchronizes data between your computer and player
  • Video Converter (version 5.60.12)
    Converts videos to a suitable format and transfers them to your player
  • SmartFill (version 2.00.26)
    Fills up your player with songs automatically
Thank you for using FixYa.
Have a great day.
Jas247
2answers
Download windows vista
Just stay away from Vista.
Go for Winodws 7 Pro or Windows 8.1
Error 1722
You may encounter the following error on installation:
Installation ended prematurely because of an error
when trying to install 32-bit or 64-bit qlikView on Windows 7. With or without UAC (User Access Control), installation fails.
Suggestions to (re-)install vbscript.dll using regsvr32 vbscript.dll in the c:\windows\system32 (64-bit equivalent) directory didn't help.
On execution of the installer, c:\program files\common files\wise installation wizard has a new msi added that includes the full installer for the qlikView application.
Installation worked by opening your command window (Start -> (All Programs) -> Accessories ->Command Prompt (right-click and run as Administrator) by calling the msi, above, with a few switches:
msiexec /a WISB3[...].msi
That worked.
The command-line registry fix as below
reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f
didn't do anything...
This application has failed to start because d3d10.dll was not found. and error 8003002: could not start application sky orb. the requested render path could not be loaded.
Download DirectX 10 and install. SkyORB 3D
  • Operating Systems: Windows Vista, Windows 7
  • Requirements: 29.6MB hard drive space to download, 52.3MB installed; DirectX 10 required (Windows Vista or 7 only); updated graphics drivers recommended
  • 0helpful
    Creative zen uploading data on windows vista
    Support for the Zen V plus is on this site
    http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=15306&prodName=ZEN+V+Plus
    Get downwards on this page and go to Manual selection.
    Next choose your language and the Operating System, in this case: Vista and SUBMIT.
    The name of the application software for Vista is called:
    ZNV_PCApp32_LA_6_41_10.exe
    1helpful
    3answers
    Zen Micro wont exit recovery mode or clean up
    OK to everyone who messed up the firmware of Zen Micro and run vista, u r all idiots, including me. my zen was stuck in recovery mode and recovery menu as everyone experienced and tried to upgrade the firmware via the firmware updater that didnt work, right? ok through research and time i came to realize that what was causing the updater to fail (...please connect your media player...) is windows media player 11 (ELEVEN !!) zen update firmware will work only with windows media player 10 (TEN !!) installed. y? i dont know and i dont care anymore now that my micro is fixed up and running with the latest released firmware.
    method 1:
    u can find smne with xp and wmp10 (rare) install drivers and run the updater or
    method 2:
    u can DIY and since it is impossible to uninstall wmp11 i did the unthinkable, no no not format and install xp to use wmp10 no no.
    instead i used a program called VIRTUAL MACHINE WORKSTATION 6.5 (for links keep confidential suppling ur email to me) this program will allow u to install and run several operating systems at a time regardless of your current hardware, it will run as an application in vista O/S. so i installed xp pro (on vmware 6.5) that i had handy somewhere, and then the drivers from the creative disc. then i run the firmware updater and yes it recognises my zen for the first time and loads a brand new firmware. easy as that, zen reboots and main menu appears, what a joy.
    so all i used was:
    vmware 6.5
    xp pro (wmp10)
    creative disc
    firmware updater by creative
    installing operating systems on vmware is very easy and doesnt require restarts etc.. u can switch through vista and xp like a window application just like that.
    hope this helps, zen micro is by far the ultimate mp3 player for its sound breathtaking performance and loudness, totally worth the trouble. this is 100% fixable
    3answers
    My zen micro will not work on windows 11 media player
    Try the recovery tool from here (this is relevant to your recovery mode question also), but not all mp3 players will work with Windows Media Player 11 - causes a DB corruption - roll back to Windows Media Player 10 if this is the case:
    http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=213&subCatName=ZEN&prodID=14107&prodName=ZEN+MicroPhoto
    6helpful
    4answers
    Zen micro firmware problem
    I just got a ZEN Micro 4GB player for free due to Firmware problem. This totally fixed the firmware issue. Windows XP PC with Media Player 10 and the latest driver and firmware from creative. Once I had all that I plugged in my player, let it recognize and then re-flashed to latest firmware. BAM now the play is working perfectly and I can sync music to it. Thanks for the fix.
    1helpful
    2answers
    Creative ZEN MICRO
    method 1:
    method 2:
    so all i used was:
    vmware 6.5
    xp pro (wmp10)
    creative disc
    1helpful
    Recogniton problems
    Get the Vista compat software. If you already have:
    Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
    Error with Napster
    http://193.95.171.84/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=70,E=0000000000295074190,K=561,Sxi=1,Kb=ww_english_add,VARSET=ws:http://us.creative.com/,Case=obj(7931),Kb=ww_english_add
    To use an MP3 player with online music subscription services, the following is needed:
    • A specific application from the online music service provider
    • Windows Media Player 11.
    • Windows XP Service Pack 2 or Vista. To check the Service Pack version, click on Start, Control Panel and then System.
    • An MP3 player with MTP/PlaysForSure firmware installed. Currently, the following players support PlaysForSure either out of box or with an available firmware upgrade: ZEN Vision W, ZEN V Plus, ZEN V, ZEN Vision:M, ZEN Vision, ZEN Sleek Photo, ZEN Micro, ZEN MicroPhoto, ZEN Sleek, ZEN Touch, ZEN Xtra, and ZEN PMC.
    Grand Canyon Tech
    Grand Canyon Tech
