Question about Cannon Office Equipment & Supplies
I have a Cannon i550 printer that just stopped printing in color it prints in black & white okay but will not print in color all all inks are full I have run it through deep cleaning.
  • jake274 Aug 24, 2008
    I have done this reinstalled the dics no change
  • 435 Answers
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
power button.)
2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
release the Resume button and Power button.
3) The green indicator flashes during initialization.
When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
(The indicator toggles between orange and green each time the Resume button is pressed.)
4) Next, press the Power button, and the green indicator will light, and the function will be executed.
5) Turn off the printer then back on and error should clear.
Posted on Aug 24, 2008
    Genius:
  • 3,422 Answers
Please reinstall the drivers if you have not done so and let me know.
Why can't I print black and white, without colored ink?
I have the same problem & have been searching for weeks for a replacement printer that will print B & W with one or more colors empty. I haven't had any luck yet - I did run across a post that said: For black and white images and photos, a blend of colors called "composite black" may be used to achieve significantly better image quality and smoother gray tones than can be accomplished with black inks alone. I'm still searching...
Jul 28, 2010 | Epson Stylus CX5000 InkJet Photo Printer
Cannon pixma 1500 printer stopped printing color ink is full
Print a test pattern print first to make sure that the problems is the printer and not the file you are trying to print , then check you color cartridge if it's empty.
Aug 17, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Printer will not print in color
try to check  the printer setting of your printer maybe it enabled the black color printing setup in your printer. Then try also to remove the color ink cartridge then installed it back and try to print it again.
Jun 19, 2009 | Canon i860 InkJet Photo Printer
Kodak ESP 5 runs out of ink after about 40 pages of standard text black & white documents. Also the color ink level is dropping, but no color is being used (the printer is set for black & white...
As far as the quantity of black & white - to get more out of it - go to start menu.. Click on on settings,, then printers,, Right click on the ESP 5,, click on printing preferences,, then clcik on draft,, then click on (at the top) advanced,, click on black & white.. Then click on apply then ok..
Now - every time you print it will be in this mode.. If you want to print in color - you will have to choose that each time..
For you black & white docs - this will print faster & use allot less ink..
As far as your color issue & puddling - It could be the printer head.. If it is new enough - call Kodak & maybe get a replacement.. If to old - maybe keep the color cartrige out and caped with the plastic caps until you need to print color.. Snap it in & out as needed..
I hope this helped..
Jun 11, 2009 | Kodak ESP 5 Printer
Won't print because color cartridge is empty and l don't need color
Try changing printing preferences/properties. Click on option for color, then click on box for "black ink only" or similar. Try now. If you still cannot print after changing preferences/properties, you will need to replace color ink cartridge due to manufacturer's built-in software that prevents printing when ink is low. Great for the ink companies!!!
May 18, 2009 | Cannon i70 Printer
Can't print color only black and white
Please check if your Colour Ink Cartridge is not emply. If their's ink in the cartridge then try to service your printer through the Print Preferences. Your Colour Cartridge Nozzels could have been blocked thats why your printer is unable to print in Colour.
In case if both the above doesn't work then check in the Print Preferences that you should not have saved the option of PRINT DOCUMENT IN BLACK ONLY. hope this helps , AJ
May 18, 2009 | Dell 966 All-In-One InkJet Printer
Color printing
If your using windows OS go to control panel , then printer and fax icon open it you will see canon printer series listed right click on it and go to printing preference tab ,check print all documents in black and white click okay and then try to print....
Good luck...
Feb 26, 2009 | Canon PIXMA MX310 All-In-One Printer
I need color documents from my x2500 lexmark printer
Okay if your using windows OS go to control panel , then printer and fax icon open it you will see Lexmark printer series listed right click on it and go to printing preference tab ,uncheck print all documents in black and white click okay and then try to print....
Good luck...
Feb 25, 2009 | Lexmark X2500 All-In-One Printer
Only black!
The printer require print head repalcement.
Apr 18, 2008 | Canon BubbleJet i550 InkJet Printer
Wont print
Hi, yes I have had problems with these HP printers B4 and it was in fact the INK... strange as it may seem, Ya gota have them "Full" as it were. I have "Fooled" it sometimes by removing the cartridge(s) and powering on & of re-inserting them. But eventually always ended up paying thru the nose for the cartridges. I saved a bit by using refilled ones, but I now use printers that have cheap single color ones, eg: Canon i550
Jul 14, 2007 | HP DeskJet 920c InkJet Printer
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Victorman
Victorman
Greg Cann
Greg Cann
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
