Question about Sony MHC-RX70 Shelf System
Sony rx70 3 cd changer
The on/off button doesn't work, the volume control doesn't work - it has a mind of it's own and now disc 1 doesn't work and disc 2 is temporamental.
  • johanknopper Aug 25, 2008
    I have a similar problem. The Volumebutton works really strange. When turning up the volume it´s going down and the other way around.
    With the remote controle it works fine.
    I tried to clean the inside by removing the cover but is does not help.
    Has anyone an idea what it can be?
    Kind regards,
    Johan Knopper
I would take it back to sony they will take it back and hopfully get everything back working cause i had the rx70 and had the same issue sent it back to sony and when it came back it felt like it was a totaly new machine
Posted on Sep 25, 2011
I also have exactly the same problem with the volume control. I was hoping to resolve the problem by doing some internal cleaning but seems like johanknopper tried it before.
I was thinking of buying a remote control separately as I lost mine in relocations. Found a second hand on-line but I am not sure if they all have the same frequency and if it works with mine.
Any Ideas?
Posted on Nov 16, 2008
  • prinses Mar 27, 2011
    Had the same problem. Volume went up or down at random when volumepot was turned. It even did go to max on it's own!! Not nice.
    Fixed it too :) You gotta take the volume 'potentiometer' out of the frontpanel. Once out, ply back the four metal clips and take off the aluminium part. Then you see the inside of this 'potentometer'. It's a special one as it has a metal ring at the edge and a 'toothwheel' like inner part and a few little pins which slide against these. Mine were covered with grease which took some time to clean off with cotton swaps and alcohol. Guess the grease got in from the potentiometer shaft. Refitted everything and it worked fine again.
    To get to the potentiometer: Take the stereo cover off, take two more side screws off and 5 more from the underside just below the cassette player. Switch on the stereo and push the button to open the CD player slide. Switch off again while slide is open. At the bottom tilt the plastic edges till they slide over their edges to release them. You can now slide the whole frontpanel far enough forward to get access to the volume potentiometer from the inside. Pull the plastic button from it at the frontpanel and unscrew the pot fixing screw. At the other side (inside) you'll see a little pcb where the pot is soldered onto. Pull the pot backwards. Unsolder the three wires going to it and you can take the pot out for cleaning. Many words but once started it will show itself. Good luck. You can do it too :)
I cant hear the music very well... it is very faint and i have my speakers plugged in. how do i turn up the volume? i cant find any buttons to do so.
CD changers don't normally drive speakers (the lack of a volume control and speaker connections being a HUGE clue). What are you using for a speaker amplifier?
Sep 18, 2011 | Kenwood CD-223M 200-Disc CD Changer
On a sony cdp-ce275 5-disc cd changer where is the volume button or nob? we got one donated to our program but we can't control the volume
since it is a changer and not a receiver there is no volume as that is controlled by a separate amplifier.
Oct 03, 2010 | Sony CDP-CE275 5-Disc CD Changer
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 14, 2009 | iLO CA3000V CD Player
Reset button on Sony 10 Disc CD changer
there is a reset button the the converter box that all the wires go into.
Oct 28, 2008 | Sony CDX-540RF 10-Disc CD Changer
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
I can't get the remote to work with my disc changer
take down the remote and check the circuit for lose solder if there there is any resolder all whole circuit.if that does not work take a look on the amp IR could be it has cold solder or the IR needs to be replace,for parts replacement contact www.dalbani.com
Apr 06, 2007 | Sony RM-U185 Remote Control
Volume is uncontrolable
Hi sounds like you have the audio out from the cd changer connected to the RCA/Phono out of the radio. double check that the output from the CD changer is going into the correct phono/rca connector regards Mark www.carradiospares.co.uk
Apr 04, 2007 | Panasonic CX-DP88 8-Disc CD Changer
Jumping Tracks when using "Next" control
find the "reset" button (this button usual is very small) find it in front of the control panel, if the control panel is removable find "reset" button after removed
Feb 02, 2007 | Sony CDX-T69 6-Disc CD Changer
968 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
