Question about Mitsubishi VS-50605 50" Rear Projection Television
Telvision does not turn on
Hello we have the vs-50605 and it does not turn on there is a green light but no other power indicators. any suggestions?
  • brettski1 Sep 20, 2008
    Exact same problem. I was able to get the blink codes; 1 blink, then 2 blinks. I assume this translates to "no problem detected".
  • 927 Answers
Good Day,
The most common problem with this Model is the Caps on the Main Board, but to make sure pull the codes. Follow this procedure:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Posted on Aug 30, 2008
I have a mitsubishi vs-50605 and when i turn it on the light comes on and clicks and the instantly clicks and shuts back off, I pushed the menu input buttons for five seconds and got one blink then two...
1,2 is no error detected---if during or before this you unplugged the set that clears the errors and you will get 1,2.
To confirm with set plugged in turn it on--when power light goes out repeat the self check.
May 15, 2012 | Mitsubishi VS-50605 50" Rear Projection...
My Mitsubishi projection TV just shut off
Heat problem. Cleaned the dust off the boards and did a full reset.
Sep 07, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Mitsubishi tv ws-55311
Mine did the same thing. It was too much money to invest in old technology. I chucked that baby to the curb and got a 42" LCD. LOVE IT!!
Apr 25, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS50605 rear projection TV won't come on
The power supply caps in the light engine power supply were faulty when they were installed. You need to remove the power supply and take it to your local electronics shop where they can remove the (7) faulty 1000uf 16v electrolytic capacitors and insert new ones. If you remove the power supply yourself (takes only a philips screwdriver) and reinstall it yourself, the electronics shop shouldn't charge you for more than an hour worth of time. The caps would be about $10.
Here's a photograph (thanks Don Crawford).
Nov 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Tv wont come on
Check the horizontal output and regulator transistors. If you ould like the service manual let me know I can post a link where you can purchase it and have it emailedto you along with free help to elp you diagnose and repair your set.
Feb 19, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Green lamp/bulb
Dec 07, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Power up on tv
Usually, that symptom indicates CRT coolant leakage on the
circuit board below the drip.....creates a short circuit,which
turns off set.....Have it examined by a Mits tech to be sure......T.
Dec 04, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 - Colors separated
You have a convergence problem and need to reset
Nov 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Timer light flashes 3 times
the code means that your tv power supply is not functioning your tv needs to be repaired call the tech.good luck
Apr 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
120 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
