Question about Targus Wireless Optical Notebook Mouse PAWM10U
Targus wireless mouse not working
Need directions as to which buttons to push for the USB attachment to recognize the cordless mouse
  • Anonymous Sep 29, 2008
    I am using Targus wireless mouse.. its came rechargable batteries two days back its stop working suddenly I thought problem with batteries so i bought new batteries still its not working..
    can any one tell me what is the problem...
    Thanks
My targus wireless mouse is not moving and the hardware is installed.
any simple solution\\\\\\\\\\/
thanks.
Posted on Sep 05, 2008
I think my mouse is not moving because one usb is missing. I
have trouble find one usb that can help move my mouse.
Posted on Sep 01, 2008
Pc not recognizing wireless logitech or usb mouse. I've replaced batteries in the wireless and plugged the usb into every slot available still doesn't work.
If you go into the device manager, look to see if the USB controllers and hubs are detected. Or do they have a yellow warning on them.
When USB ports misbehave for me, I go into the device manager and remove them all and let the machine find them again. Then stuff usually works.
You don't say if you have a desktop or laptop. If you have a desktop, are the USB ports in the front of the machine actually attached to the motherboard?
I'm thinking my first suggestion is the one you should try first.
Then make sure the devices you are installing actually work.
Also, for wireless, be sure you push the "connect" button on the device.
Nov 22, 2009 | Logitech Cordless Mouse
My cordless mouse was working fine, but now the computer does not recognize it, so I went out and bought another cordless mouse and it still doesn't work..... why? Thanks
If you're running XP or newer, your system should autodetect the wireless receiver plugged into your USB port which will then autodetect the signal from the mouse. Some wireless mice have a small button on the bottom that must be pushed and held for a few seconds each time the battery is installed.
By the way, the receiver that goes into the USB port may be different for each mouse. Use the one that came with the mouse.
Nov 12, 2009 | Dell Inspiron 6000 Notebook
Targus mouse not recognized and malfunctioned when plugged in....
install teh software first and then connect the mouse. It shall help
Sep 03, 2009 | Microsoft Wireless Notebook Optical Mouse...
Targus usb optical mouse not recognized by windows
Hi there!
The Targus WIreless Mouse with Power management is supported by Windows and does not require additional drivers. To confirm that Windows has loaded the drivers:
Click Start>Right-click My Computer>Select Manage
Select Device Manager
Expand the Human Interface Devices section.
You should see an entry for USB Human Interface Device. If you don't see an entry, right-click on the Human Interface Devices entry and select Scan for hardware changes.
If you don't see any results, look for any yellow question marks or exclamation marks underneath the Unknown Devices category. You may find the mouse listed there. If so, right-click on it and select "Update Driver". Select "Yes, this time only", then click Next, leave the default selection as is and click Next. If the update fails, try again except this time, after the first "Next", select the advanced option, "Install from a list or a specific location", then click Next.
Select "Don't search. I will choose the driver to install".
If a default selection appears on the screen that follows, click Next and it should install. If successful, I recommend you restart your machine for any changes to take effect. If the installation isn't successful, you may need to submit a ticket on Targus' support site.
I hope this helps you! If you have any questions, feel free to reply.
Aug 20, 2009 | Targus Wireless Optical Notebook Mouse...
What is the OS of your computer? This Targus mouse would work with Win 98, Win 2000 and Win XP. Vista was not mentioned. And if you are running Windows Vista for you laptop, then that could be the reason why it was not recognized by the computer.
Is this the wireless optical mouse? If yes, you need to follow the steps below to isolate the problem:
1. Connect the USB receiver into different USB ports of the computer.
2. Replace the batteries with the fresh ones.
3. Try connecting the mouse into different computer to see if you've got a defective mouse.
If you've tried everything and got the same problem, you may need to refer to the manufacturer, because I'm not sure if this mouse is a Plug-n-Play device or if it needs a driver.
Have a great day!
May 26, 2009 | Targus PAWM001U Mouse
My wireless mouse doesn't work
There might be a connect button on the mouse and the USB dongle that might work. Push one with the tip of a pencil, then the other. If that doesn't work, try it the other way (pushing connect on the mouse first).
Mar 19, 2009 | Targus Stow-N-Go (AMW07US) Mouse
Logitech LX8 will not work
When you pllugged in the receiver, did you push the little button on it?
Once you did that, did you turn the mouse over and push the little "connect" button? I'm assuming, of course, that you put new batteries in it!
Also, I'm assuming that the USB port is working.
You could always go into the device manager and see if the device shows up. If it does, delete it and try to connect it again.
If all that fails, you have a dead mouse.
Feb 27, 2009 | Logitech Cordless Mouse
Logitech wireless keyboard and mouse (ex 100) won't connect
The mouse and keyborard have to be in direct view of the reciever. Even a small obstruction will effect the operation
Nov 02, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
How to set up and use targus wireless computer mouse model#amw26
Under the mouse there should be a usb stick attached to the mouse which most likely should slide out from the mouse. It also appears that the plastic cover behind the two buttons (this cover has targus written on it) Should come off. After you remove the usb stick there might be a button somewhere on the bottom of the mouse that you should be able to press to get the battery cover to pop up. Then you should be able to pull up on the battery cover and remove it from the mouse. This mouse takes two AA batteries. Once the batteries are installed then plug the usb stick into any of the usb ports on the computer. The computer should recognize the drivers for this mouse (if you are using Windows 2000, XP, Vista, or Mac OS X [or higher]). If the drivers are not immediately recognized then restart your computer and the computer should then recognize the mouse. If this still does not happen then let me know. Also there is software that can be downloaded from the Targus website for the tilt wheel as it has some added capabilities that can be set using this software. The link for that software is here ------> http://www.targus.com/us/product_details.asp?sku=AMW26US
I hope this helps, and enjoy that mouse, it looks pretty nice!
Sep 20, 2008 | Computers & Internet
Mouse not working
Are the batteries dead? Try different batteries.
May 15, 2008 | Targus Wireless Optical Notebook Mouse...
Targus Wireless Optical Notebook Mouse PAWM10U Logo
1,083 people viewed this question
Top Targus Computers & Internet Experts
dhnguyen
Josh Whitehead
Josh Whitehead
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
