Question about GE (PSS26MSRSS) Side by Side Refrigerator
Fridge issues im having a fridge issue, plugged it in worked great next day nothing. freezer melted fridge went bad and now its blowing out air but its not cold or hot air...and i dont know how to tell if a compressor is shot or anything else. i took the back panel off and when i put my ear to the computer board i hear a humming sound and the board is warm...also is there supposed to be a green wire with a metal ring at the end just dangling?
    Problem Solver:
  • 25 Answers
Hi adamvovo.
It sounds like the compressor isn't running. The way you can tell if it is or not, is to pull the back off of the refrigerator, and listen, or put your hand on the compressor. It's the small black thing at the bottom, with tubes running into and out of it.
If you don't feel a vibration, or if it cold to the touch after it has been plugged in for awhile, the compressors' bad, or some circuit which controls it.
Greg.
Posted on Aug 27, 2008
My kenmore side-by-side refrigerator is less than 4-years old. freezer works but refrigerator stde does not get cold. ice accumulates on lower vent in refrigerator.
all it does is the evap fan blows cold air from the freezer into the fridge section and returns through the bottom air vent,so if there's ice there most likely one of the doors was left open,check the freezer for frozen water droplets on packages or on the walls and shelves of the machine,if you don't see that open the freezer door,if you don't hear the fan blowing you could have a bad evap fan motor.if the fan is blowing in the freezer from the bottom remove the second draw or bin and put your hand on the back inside wall of the freezer,if there's frost or like snow on the back wall you have a defrost problem,bad defrost thermostat,defrost heater,timer or board depending on what model you have,if the fan is blowing and you don't see any problems that i talked about you could have a bad damper,on some machines there's a damper door that opens and closes to let cold air into the fridge section,if it's bad it won't open and no cold air can blow in from the freezer,if you think the door was left open,remove anything that's in the way,in the freezer side and the fridge side,shut the machine down or unplug it and with a hair dryer melt out the ice,don't keep the heat in one place for to long,you can melt the vent if it's plastic or styrofoam,after you think it's melted out start the machine and put your hand up in the left hand corner in the fridge section and see if you can feel any cold air blowing in,there could be ice up there too,next time send the model number so i can look up your model,on a side by side you'll find the tag on the right hand side wall in the fridge up near the ceiling or on the ceiling near the light.hope this helps,if you have another fridge you could move the food and just shut the fridge down with the doors open and let it melt out on it's own overnight.good luck
Sep 05, 2011 | Kenmore Side by Side Refrigerator
My freezer frosted over everything because the door was not shut tight and now it will not clear.
take out all the food out of the freezer,unplug the fridge and get a hair dryer and start melting out all the ice in the freezer,then blow the hot air into the vent holes on the back wall until you don't see any more water dripping down through the slots in the back wall.turn the machine back on,open the fridge door after around 5 or 10 minutes and if you feel cold air blowing into the fridge you fixed the problem,if you don't feel cold air keep hitting the inside back wall with the hair dryer and keep blowing the hot air into the holes in the back wall.all that it does is the freezer gets cold and there's a fan behind the back wall in the freezer,the fan blows the cold air into the fridge side,if the air ducts are frozen the air can't circulate into the fridge section so you have to melt the ice out so the cold air can blow from the freezer to the fridge.good luck,if you have another fridge remove the food and unplug it and leave the doors open for a day and it will melt out.good luck
Jun 16, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
GS2126 not cooling the food but freezer still working
Just switch off the fridge for 12 hours or more so that the defrost in the fridge will melt.The flow of air is from freezer to the fridge.The frozen ice will melt and flow of air will become normal.Check for all the ice behind the freezer section melts fully.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Jan 02, 2011 | Maytag Refrigerators
Bought this model from someone new, it was working great when I checked it out, transported it to our house and plugged it in the next day. Freezer works well but fridge barely cools at all. Any...
HI There,
If it was transported to to your house not in an upright position, then you may need to unplug it and wait for 8 hours to have the fluids settle before starting it again. If that is not the issue, ensure that there is ample space at the back of the unit, between the wall and the fridge to help circulate the air. Inspect the coil found at the back of the freezer for ice build up or dirt. If there is let it melt and have the unit cleaned out first before restarting.
Aug 22, 2009 | Refrigerators
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
Frigidaire Refrigerator not cooling
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 16, 2008 | Refrigerators
Fridge is warm, freezer works.
  • possible causes:
Jul 16, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Maytag MSD2651HES fridge not cooling freezer works find
  • possible causes:
Jul 06, 2008 | Maytag MSD2650HES Stainless Steel Side by...
Freezer working fine, but no cold air to fridge
  • possible causes:
  1. bad defrost timer/control unit
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 29, 2008 | Whirlpool GB9SHKXL Bottom Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
