Question about Intel Frontier Design Dakota 24-Bit PCI Soundcard Sound Card
Sound Problem I have a sound problem... I speak with people on skype, then people on the other end tell me my sound dies and cuts off intermittantly, but' returns now and then when I shout a lot louder into the Mic. Many Thanks Tommy
  • Tommybkk Aug 24, 2008
    Many Thanks
    Tommy
  • Tommybkk Aug 27, 2008
    Many thanks for fixing my sound problem ?
  • 83 Answers
Hey Mathsafet
You Need To Install The sound Max
And here Is
------Download Link-----
Thinks
Rate This Solution When You Can
Your Friend Fix-Shad0
Posted on Aug 24, 2008
My computer is dell latitude e6400. when using skypes i hear but the one who play with me doesnot hear me so whatis the solution
try this:
you may need to turn your microphone sensitivity up.
make a call to echo/sound test service. follow the instructions. if everything is ok then the problem is with your friens at the other end - he may need to turn the sound up on his computer or in the skype program.
if necessary turn your mic setting up. select from the menu bar at the top of the skype window tools > options > audio settings. under microphone, move (by positioning the mouse pointer on it and holding the left button down, while moving the mouse to the left and right) the slider (a blue dot) up and down while speaking, you will see the green indicator move up and down as you are speaking, more when the blue dot is more to the right. if the green bar is solid and does not change, move the blue dot to the left until you see it going up and down. if the green bar is not present try moving the blue dot to the right more until you see it go up and down, but never reaches its maximum/
otherwise you may need to change the settings on your pc, or there may be a hardware failure
21.january.2015
Jan 21, 2015 | SKYPE Computers & Internet
Bush 4.1 sound bar cuts out, connected via optical sound cuts out it is intermittent, happens on tv, dvd/blue ray and media player setting. Any ideas how to stop this happening. Have tried rca cables etc
I get a similar issue from my Bush sound bar. The sound drops out when the tv programme/movie etc has a period of silence in the audio track or just very low background music (no speech). As soon as someone begins to speak it starts up, but usually it misses the first couple of words. Bar is connected directly to a Samsung tv via the optical cable. Any ideas?
Aug 12, 2013 | Audio Players & Recorders
While using Skype with my Toshiba laptop and webcam the sound will all of a sudden cut out. I have to end call and then click video call again to get the other party can hear me and after a few minutes,...
1. this could be several reason why the sound cut out when using skype
2. check the hard drive capacity
3. you may need more RAM ( random access memory). If you are at minimum this may not be enough to complete the VOIP ( voice over IP)
4. this could be the connection with the skype recipient.
5.check your skype settings
6.check the sound card in your laptop ( drivers etc)
7. check the speakers of the laptop the may be malfunctioning or the earphones if used.
Jun 13, 2011 | Computers & Internet
No sound is heard with calls on Skype, I get video, and i hear sounds made by the program, but no sound from the recipient of the caller. I get sound when I video chat Mac to Mac, but not Mac to Windows,...
Ok, by the sound of it both yourself and whoever you're calling have not set up Skype quite right.
On your end, you need to:
  • Make sure you have a working microphone - try using Skype's built in 'Echo' feature (try calling 'echo123')
  • In Skype -> Preferences -> Audio, make sure that microphone is selected.
On their end, make sure they've done the same - they must have a working microphone, correctly setup with Skype in order to send you sound.
Hope that helped!
Jan 18, 2011 | Apple Customized 15" MacBook Pro Laptop...
Windows Vista. Using Skype, the person on the receiving end can't hear me. If I am running iTunes on that computer, though, the recipient can hear the music, just not my voice. I can hear them.
Hi
Start skype. Choose the menu calls then sound settings, select the device through which to speak: web camera, if you are using a built-in microphone or any other bluetooth headset if you are using or external microphone
Oct 03, 2010 | HP Pavilion dv1000 Notebook
Microphone distorted sound
You need to get into you setup for the micro phone to adjust the the output or the gain. look under the sound management in the control panel
Sep 05, 2009 | Dell Inspiron 1521 Notebook
QuickCam Connect Audio test - OK Skype audio test -OK but the sound is intermittent. Your advise? victor victordan33@msn.com
Test the sound offline using your webcam center software. If it isn't intermittent there then its likely being caused by your internet connection.
Mar 06, 2009 | Logitech QuickCam Connect Webcam
Can't hear my sound playback on sound test with skype
After you install Skype and have it operational with you ID . Go to "TOOLS", click on "OPTIONS", nect go to "Audio Settings" and click on it. Make sure both the Microphone and Speaker's are correct Then "make a free test call" .Wait till the voice tells you to record. Then when finished talking waite for the test voice and the test persons voice to insue you audio transmition is work. Then go back to options and test your video.setting. Click on Video Settings and procede to set up you video camera. Also Visit this site to setup video.
http://www.skype.com/help/guides/video/
Hope this helps. Bud
Jan 05, 2009 | Logitech Quickcam Chat Webcam
Skype microphone
When you are installing the skype software, there comes a time when skype will offer you the option to test your hardware. Here you will try out the speakers and mic, and skype will tell you if they are in skype accepted order.
My friend actually installed it not too long ago, and after the install, I saw that skype gave him the option to make a test call right on the program interface window. We used it, and it made a call to a skype computer voice which advised us that if we could hear her talking, then our speakers are fine, and to now go ahead and speak into our mic, if the mic is working we will be able to hear what we just said into it.
That was a great little way to make sure our speakers and mic were in fact working, and they were.
Try that out on your pc and your friend's pc to test components individually. If you are unable to find the test call option, or the option to test components, you can uninstall skype and reinstall the latest version, which may not be a bad idea to preclude any other weird problems which may be at fault.
Hope that helps.
Dec 30, 2008 | Acer Creative Sound Blaster AWE64 Sound...
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
Intel Frontier Design Dakota 24-Bit PCI Soundcard Sound Card Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
