Question about Cameras
Cannot charge camera as battery charger doesn't light up.
My camera is completly dead and will not turn on and when i plug it up to the computer it doesn t charge
Posted on Apr 26, 2009
How do i know it charging
The DVR 508HD is a video camera, not a battery charger. As such it doesn't charge batteries at all. It uses three standard AAA batteries, either disposables or rechargeables. If you use rechargeables, they must be recharged outside the camera using a separate charger.
Nov 16, 2012 | Vivitar DVR 508HD Digital Video Recorder
No charger
The camera doesn't come with a charger. It uses standard AA batteries. If you use rechargeable batteries then you must charge them outside the camera using a separate battery charger. Rechargeable AAs and charges should be available at just about any department, electronics, or office-supply store.
Jul 18, 2012 | Olympus Camedia C-350 Digital Camera
Where can i buy a charger ?
Can i charge battery via USB connection or do i need the charger?
The USB cable port doesn't provide charging for the Li-Ion battery. You need to pull the battery and charge it in an AC charger.
Mar 03, 2012 | FUJIFILM FinePix XP20 / XP22 Digital...
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
Does my vivitar 528 need a charger
The camera doesn't NEED a charger. It runs on three standard AAA batteries, disposable or rechargeable. If you use rechargeable batteries then you must charge them using a separate charger, the camera will not charge batteries.
Aug 18, 2011 | Cameras
Battery charger doesn't charge batteries. Light
Check the output on the adapter also check the voltage on the battery , If there is none then the particular unit needs a check. If the adaptor voltage is good then the battery can be faulty
Jul 11, 2011 | Cameras
Fujifilm battery fully charged but camera says no charge or very little. Just bought a new Duracell Battery and Charger for my Fuji FinePix J10 Camera. Used the charge on the battery in the camera from...
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Jun 11, 2011 | Fuji FinePix J10 Digital Camera
Battery Charging light does not light when charger is plugged in.
Here are the steps for no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 13, 2010 | Kodak Easyshare M341 12.2MP Digital Camera...
Cameras Logo
157 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
