Question about Denon DP-26F Turntable
Belt is off on my DENON dp-26F tURNTABLE
This unit has been in storage. I just unpacked it and the belt is off. Any help would be GREATLY appreciated. Thanks!
Mike
  • 104 Answers
Http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things.
Posted on Feb 12, 2009
Replace cartridge stylus
Hi, my advise to customers is to buy the best quality audio gear you can afford. If you tell me your budget I will suggest a couple of carts that match. Cheers John. Styluscity
May 27, 2013 | Denon DP-26F Turntable
My Denon DP-26F tonearm does not return "all" the way when finished playing a record.
Tonearm can be adjusted to travel back to its support. At the base of the tonearm is a small rubber stopper. Remove the stopper and insert a flat blade screwdriver into the slot beneath. Turn to the left and then test arm for repositioning correct. Adjust until its correct. John
Dec 27, 2012 | Denon DP-26F Turntable
Sound is too loud and harsh.
Hi, connect it to an aux or CD input. John Styluscity.com
Dec 03, 2011 | Denon DP-26F Turntable
I just bought a used DP26F and see that under the platter the belt goes around only a spinning thing (sorry) near the front, but nothing else. Something must be connected to whatever it is that spins the...
This picture is from the manual for a DP-29F, a similar belt-drive turntable:
The view is through the rectangular hole in the platter you see with the turntable mat removed. This picture is from the setup section for a new turntable, so the ribbon tape won't be on your belt. But it shows how the belt should go around the drive roller (it's the shaft of the drive motor underneath). Other than the routing of the belt over the roller, there's nothing else to connect. If the belt is working correctly (hasn't stretched so it's too loose), the roller drives the belt which in turn spins the platter. If your turntable isn't turning, either the belt is too loose to transmit the motion, the drive motor isn't spinning, or something is binding and preventing the platter from turning.
Jan 20, 2011 | Denon DP-26F Turntable
Do I need an adapter for playing 45rpm records on my denon dp-26f
The only adapter you will need for 45's are for the ones with a large hole in often used in jukeboxes.
Jul 17, 2010 | Denon DP-47F Turntable
Denon turntable DP 26F turntable doesn't turn
through the platter motor access window, unhook belt from motor spindle (usually brass) which is exposed on the left side when you remove the mat.
Now give the motor a spin with your thumb/index finger. repeat up to maybe a dozen times. sometimes a motor like this will get a dead spot where a bit of debris will 'gum up the works' and stop the electrical contact it needs to spin.
if it does start working by some miracle, then just let is sit and run at 45rpm for hours or even days, this may kinda rub off some very light corrosion that might have built up on the armature over the years. (if it is a brush type motor)
Jan 08, 2009 | Denon DP-26F Turntable
Platter turns slow
This turntable design has a direct drive system instead of belt drive (two types). If this unit has been in storage for some time, it has most likely been at hot or cold tempuratures - not good for any electronic/mechanical system.
My guess is that the direct drive motor needs to be rebuilt - internal friction is probably keeping it from operating at proper speed. Best to consult with a repair shop that can handle direct drive turntables - several on the internet, if you cannot find one locally.
BTW: You can find a manual for this at : http://www.vinylengine.com/library/denon/dp-45f.shtml
Best regards,
Andre
Apr 06, 2008 | Denon DP-47F Turntable
Help~~ the belt fall off
Most turntables have the belt wrapped around the bottom of the turntable platter, and then around the motor. You'll have to remove the rubber mat, to expose some holes on the platter, where you can squeeze your fingers in to pinch/wrap the belt around the motor shaft - generally on the lower left side. You can't miss it. Also, for future reference, here is the operating manual for your unit, and it has instructions on replacement the belt - it is on page 6: http://usa.denon.com/DP29F_DFU_ownersmanual.pdf
Aug 02, 2007 | Denon DP-29F Turntable
Denon DP-26F Turntable Logo
569 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
