Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Washer won't start water fill/ the dryer works fine
I have tried every combination of cycles and water fill options but still nothing. Lid open or closed it will not even begin cycle or water fill.
  • 639 Answers
I'm Neil, Glad to be of assistance for you!
Sounds like an Electronic problem.
You should call service.
Try :
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a solution solved rating in this site
Thank You
Neil
Posted on Aug 24, 2008
Kenmore Model 21082000 won't fill during wash cycle
Try checking the lid switch. Sometimes the switch goes bad or the stem breakes and when the lid shuts it will not activate the switch. Usually located on the right side of the dryer. When the lid closes it will allow water to.fill. Washers are easy to fix and the part is cheap. Get it from amazon dont pay the crazy price your dealer wants. Trust me, i just fixed my mothers...
Feb 16, 2013 | Kenmore Calypso
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Maytag_lse7804ace: washer won't fill with water. If I fill it by hand, the cycle works fine (until it gets to the rinse cycle, when it won't fill again).
Hello John,
The most probable reason the washer is not filling is because of a blown fuse that is part of the lid switch asm. By UNPLUGGING THE WASHER and removing the 2 INNER screws on the the control panel and the control panel can be rotated down to see the fuse in the lid switch asm. Here is where the fuse is on the switch asm. its circled in red 11_4_2011_1_39_54_am.jpg
Nov 03, 2011 | Washing Machines
Filled up with water/then stopped
Most dryers (unless this is a gas dryer) use 220 service. Which means, the dryer would not be on the same circuit as the washer. In addition most major applainces require a dedicated circuit. This means the appliance is the ONLY thing running on that particular branch circuit to prevent loading. The dryer working properly may or may not be a good indication that the washer has power. If the washer fills, then it has electrical power. The water inlet solenoids are electronically controlled.
More than likely you have a defective lid switch. If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
NOTE: Some washer models have the lid switch located near either the left or right hinge of the lid. This type of switch is activated by a rod on the hinge pin. If not functioning, it can often be adjusted by bending the hinge rod until it engages the switch.
If you have questions, please let me know. I hope this helps you.
Jul 20, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer won"t fill with water
check your lid switch if its a top load
May 18, 2009 | Maytag LSE7806A Top Load Stacked...
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
