Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side freezer fan
Making howling sound and will not stop
    Problem Solver:
  • 25 Answers
Hi johnwayne751.
Your freezer fan bearings are toast, time for a new freezer fan.
Posted on Aug 27, 2008
My GE Side by Side Freezer sounds like a Cessna when the fan goes on.
Here is a permanant fix based on a simple design change to address the cause of the howling - ice build up on the evaporator fan cowling:
http://www.deaven.net/~deaven/Make/fix-arctica-howling/index.html
Total cost of solution is less than $5
Aug 08, 2015 | GE (PSS26MSRSS) Side by Side Refrigerator
Anyone solve the howling problem please share.
sounds like the fan bearings are wearing out. this causes imbalance and makes a vibrating howling noise.
Aug 26, 2009 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
My fridge is howling pretty loudly when ever it runs , the howling is coming from behind the ice maker turned the ic e maker off but unit st ill howls what s wrong
Hi, It sounds like the evaporator fan motor is going bad or there is frost building up and hitting the fan blade.
Unplug the refrigerator and remove the rear panel inside the freezer and locate the fan.
You can plug the refrigerator in and see if the fan is making the noise.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whining/howling on freezer side
Need to unplug the refrigerator and remove the cover inside freezer compartment. Sounds like the evaporator fan is hitting something and we need to resolve this as soon as possible. Thanks Sea Breeze
Mar 26, 2009 | GE Refrigerators
GE GSL25JFR Freezer fan noise.
Replace the fan motor is my guess to cure the noise.
Mar 01, 2017 | GE Profile¿ 42" Built-In Side-by-Side...
My GE side by side refridgerator makes a "howling" sound. Any ideas?
the problem you are having is in the main control board. ge has had a problem with this part causing the fan motor to go into high and low speed which causes the howling noise. unfortunately it is a costly fix, around $125 for the part. if you are savy to changing this part it is a matter of unplgging about 5 connections and replugging them. the new board has an extra set of pin that nothing connects to. READ the instuctions and it is a simple fix, saving about $50-60 in labor costs.
Sep 08, 2008 | GE GSH22SGRSS Side by Side Refrigerator
Howling sound from freezer fan section
it is most likely the fan bushings that are making the noise. you can try to lube them with a light oil if you want to buy some time. but the fan motor will need to be replaced soon.
Jul 05, 2008 | GE Refrigerators
Noise
this fan is a variable speed and is controlled by a board in the rear of the unit. your bearings maybe going out. The fan will ramp up to speed depending on the call for cooling the Thermistors is asking for
May 20, 2008 | GE GSS22JFMWW Side by Side Refrigerator
It is very common for the fan inside the freezer to develop a loud noise as it runs. Its in an environment that is hard on them, cold, wet. Its a small and simple motor, and you are right in believing there will be more problem in the future, as the stator is probably touching the housing. It has a sleeve type bearing, and its probably worn a little causing the shaft to wobble. Eventually it will stop completely and the freezer will get warm.
Mar 07, 2008 | GE DSS25KGT Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
138 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
