Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Water hose popped out form water dispenser outlet
I try to remove the bottom platic cover (together with water outlet), but do not know how and afraid. I sawe your answer to remove the grill. What do you mean "grill".My Frigidaire model # FLSC23F6DS5.
  • 639 Answers
Dear Friend,
ngfam1 here for you!
I am happy to be of assistance!
Do you have the users manual?
In there will be a diagram showing you where the water filter is and tell you how to remove it to change filters!
If you do not understand it !!STOP and call service!
the number of a good nation wide service company is below
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. Please give me a good rating here in fixya.com before you sign out!
Posted on Aug 28, 2008
The water supply hose where it enters the door at the bottom has cracked and broken how do we replace the hose in the door
The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
May 06, 2012 | Refrigerators
How do I replace the water dispenser tube for a Kenmore Coldspot model # 106.53769201. The end of the line disintegrated at the spot where you put your glass under the dispenser.
Ice makers and water dispensers are convenient to have on your refrigerator, but can also cause a lot of aggravation if they are not functioning properly.
If your water valves are not defective and you are still experiencing water or ice delays, you may have a clog in your refrigerator hose line.
Instructions and material needed to fix it up.
  • Towel,Flathead screwdriver,New water hose
  1. Turn off the water supply to the refrigerator and place a towel under the line to soak up any residual water that leaks from the hose when you remove it. Unplug the refrigerator.
  2. Disconnect the hose from the back of the refrigerator by pushing in on the collar while pulling the water tube out. If you have a model with an ice and water dispenser, you will need to disassemble the dispenser on the front of the freezer in order to completely remove the water hose.
  3. Remove the water drip tray from beneath the ice/water dispenser and locate the screws at the bottom of the cover (if any). Remove screws and pop off the panel that houses the dispenser. If the unit does not have screws, you will need to pry the cover off with a flat-nosed screwdriver.
  4. Once the cover is removed, you should be able to see the screws that hold the dispenser unit in place. Remove these screws and reposition the unit so you can free the water hose, by pulling it through the dispenser.
  5. Thread the new water line through the freezer door and reassemble dispenser unit. Push the new water hose into the fitting on the back panel, making sure it is properly seated. Turn on water supply and check for any leaks before moving the refrigerator unit back against the wall.
Good Luck and thanks for using fixya.
Jan 16, 2011 | Kenmore 57029 Side by Side Refrigerator
Hose somewhere inside leake,it is my MOMs and I do not know the mdl.only that it is a front load mfg in 2005
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 12, 2009 | Kenmore Elite 45986 Front Load Washer
Detergent dispenser clogged-Kenmore 90 series washer
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Jun 16, 2009 | Kenmore 24902 Top Load Washer
Water leaking
there should be a quick disconnect about 4 inches from the bottom of the door. look behind the toe kick. if it leaks from the disconnect try pushing the plastic lines into the disconnect. the disconnect is about 1.5 inches long and should have red or blue ends. to get the lines out you push the colored ends in while pulling the plastic line out, try cutting off the ends smooth and straight up and down and re-insert. if the water is coming out of the bottom of the door you need to replace the water line in the door.
to get the line out of the door. use a flat blade screwdriver to pry the dispenser cover off the door. there are two slots on the bottom of the dispenser facia. use a pen or something hard for a pivot point and use tape to protect door finish. push on the screwdriver until you think the plastic will break, then push a bit harder and it will pop off. now you can disconnect the facia and remove the screws holding the switches etc. disconnect the water line and pull it through the dispenser. to put the facia back on just hook the top and line it up and press the bottom back on.
May 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water stopped running in the dispenser
I had a simular problem! I tried multiple things to make it work!
- bought new filter
- open back of the fridge... (dual outlet water valve)
Finally, I went to a different forum and found a unique idea.
First at the very bottom of the fridge theres a cover remove the cover and you should see the water hose running to the door from the back. In the middle of the hose there a coupler where the hose was spliced by the manufactuer. Now this valve once you separate it will not work correctly, unless you buy a new coupler (4$)... I'm el cheapo, I bought teflon tape for 50 cents (from previous project)... Wrapped around about half dozen times and made sure it wasnt leaking...
Secondly, when you disconnect the coupler no water should shoot out, until you press the water dispenser arm. If water shoots out of the hose on the bottom then you problem is really, really, really easy. You have simplely ice/ or another item blocking water hose to the actual dispenser.
I turned off the frezzer left the door open for an hour or so. I also used my wife's blow dryer on hot, and put it where the ice comes out of the ice maker. I would press the arm peridocially to see if the ice blockage melted yet. REMEMBER: door must be closed for pressure to push on the ice blockage. Thinking back, I might have been finished sooner... I was thinking the water dispenser would work with the door open.
If this doesnt work, then you have other problems... Bad water dispenser selonoid (you can hear this little motor turning even without water), dual water outlet valve maybe broken... Going outside my knowldege level at this point.... But i guess you computer board maybe going bad. Not sure if this computer has anything to do with water dispensing....
Hope this helps! My wife left me alone for about a day or two while she enjoyed the water dispenser...And she broke the vaccum.
Dec 23, 2008 | GE GSL22JFPBS Side by Side Refrigerator
Ice/Water Dispenser
Squat down and look up at the bottom of the cover where it meets the door. You will see two shallow slots where you can fit a flat bladed screwdriver to "pop" the cover loose. Once popped loose, disconnect the electrical connector by bending the locking tab out.
Aug 12, 2008 | Whirlpool ED2NTGXL Side by Side...
Ice door for ice dispenser not shutting.
How do I remove the ice/water dispenser front cover assembly
May 22, 2008 | Kenmore 53542 / 53544 Side by Side...
WATER LEAKING FROM FRONT BOTTOM
try onscrewing top panel on machine...when machine agitaes strongly a hose my pop lose up from top.
Jan 22, 2008 | GE WBVH6240F Front Load Washer
Water dispenser is spraying water from behind the paddle instead of the opening
the grill will pop off with just a little bit of pressure. the grill will not break. once you remove the cover there is a conncetor that most likely has come loose..
Dec 04, 2007 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
89 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
