Question about RCA Scenium HDLP61W151 61 in. HD-Ready Television
Picture goes off and on
TV will start up fine. Stay on for about three minutes and then the lamp goes out. The power button will blink five times. After about 30 seconds the lamp comes back on. The cylcle then starts over.
  • 8 more comments
  • dlabass Aug 24, 2008
    The bulb is less than a year old
  • dlabass Aug 25, 2008
    TV picture goes on and off (i.e. lamp goes on and off). unplugging for several hours did not help.
    model no is hdlp61w151. lamp is less than a year old
    lamp is less than a year old. picture comes on, but won't stay on for more than a few minutes.
    why would the lamp go off an on if it were burned out. doesnt make sense
    what is reputable online bulb store.
  • dlabass Aug 26, 2008
    pulled bulb today. how can you tell if fan is working or not. the bulb had a burnt electrical smell to it.
    how do you test fan operation
  • Anonymous Mar 23, 2014
    good picture, color wheel is fine, bulb was just replace with another osmar bulb, an just cleaned the inside, an light tunnel repaired. could it be the ballast, an what is the dmd?
  • Anonymous Mar 25, 2014
    Starts blinking after 30 minutes
  • 4,234 Answers
A couple of things to check and info we need to assist further:
1) When the set shuts down, is ther eany indication on the front such as a blinking standby or power light?
2) When you replaced the lamp, were all of the access doors closed completely?
3) Have you tried reseating the lamp. If the lamp is not entirely in the socket, it will still work for a while. The burnt smell may be because of arcing.
4) Is the area around the air intake for the fan clear?
The set is going into shutdown because a problem has been detected. When the problem clears up, the set will fire up again. This type of cyclic behavior suggests that the problem is heat related. With the set unplugged, try turning the fan by hand. It should move freely. If not, then clean the area using a vacuum or compressed air and try again.
This could also be the beginning of the failure of the "ballast". This is the part that "fires" the lamp. This is similar in concept to the ballast present in flourescent lights.
Please keep us posted on your progress.
Dan
Posted on Aug 26, 2008
  • RCA Master
  • 19,396 Answers
Try first removing the lamp and putting it back in place, to test if it is a lamp connection problem.
If you still get the problem lamp is overheating and must be replaced, here is a seller
RCA HDLP61W151 Lamp $130
  • 1,879 Answers
Read what libra_eng said :
"sometimes, lamp quality does matter."
follow his suggestions as i cannot add "new" stuffs to try.
Posted on Aug 25, 2008
  • monk3ybidzness
    monk3ybidzness Aug 25, 2008
    from your TV manufacturer (so that you get a warranty for the bulb) or their recommended bulb merchandiser
  • monk3ybidzness
    need to add - before shopping for a new lamp/bulb - exert an effort to try that replacement lamp you purchased on another TV (to get an exact answer to whether it is the lamp or the TV is malfunctioning).
    Genius:
  • 1,011 Answers
Dear sir/madam,
The problem is with lamp. Better to replace the lamp. It will be OK.
Give me the Model No. of your TV
thanks
good luck
Posted on Aug 24, 2008
    Genius:
  • 1,011 Answers
Ok dear,
u said lamp is less than a year old. why dont u check it with other lamp, a new or spare less old one.
regards,
dont rate it untill satisfied
    Genius:
  • 1,269 Answers
Please turn off your TV for about 3 hours, please unplug the power cable. That will reset it back to normal.
Sony kds-rx60xbr1 red light blinking turn it on and off and tv goes on
The lamp for this model number is XL-5100
Before ordering the lamp, I would inspect the inside of the TV, be certain that the three fans are clean and free from dust. Often if a fan does not start the first time it may start on a restart. Due to the nature of televisions operating, dust seems drawn to these TV's. Cleaning the fans might correct your issue.
Oct 12, 2017 | Sony KDS-R60XBR1 60" Projection HDTV
I have a samsung hls6186 rear projection tv and it comes on and the picture is fine and about a minute later it goes off and three lights in the front are blinking. how can i tell whats wrong
I had the same issue, I purchased a new lamp, installed it in 2 minutes. The picture is like when I first purchased the tv. You can find the lamp code sticker on the left when facing the tv.
Feb 27, 2011 | Samsung HLS6186 Television
Turn on tv...green lamp blinks several times.lights up but no picture...press any remote button timer in green blinks...tv turns off and goes to standby
The tv "LAMP"LED light indication flashes or stay lit?The tv projection lamp been in this tv like 1/2 or 2 years?Tv been on and used like 4 or 5 hours a day?Yes,than the tv projection lamp life are over.Require a new tv projection lamp.
Nov 17, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
Pictures goes black while power light blinks green
I have a 40 but i was having the same problem. It turned out to be my lamp. I got a brand new lamp from Projector Lamp Services (relampit.com) and my tv works fine now. Im pretty sure that the 40 and the 60 take the same lamp. You might want to give them a call.
Jan 05, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony KDF-46E2000 - Screen Goes Blank
The lamp can cause the picture to cycle without spitting out a lamp error. I'd replace the lamp and clean out the dust/dirt from fans, etc to hopefully resolve your issues.
Dec 06, 2008 | Televison & Video
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Very faint picture- no sound
If the red lamp light is blinking the lamp is probably shot. The pricing of the lamp varies from $200 and up plus installation. Or you can buy the lamp and install yourself. See the owners manual on instructions to replace the lamp.
Nov 17, 2007 | Sony KDF-E55A20 55 in. LCD Television
Problems turning my tv on, need to try several times
I just recently had the same problem and finally my set would no longer turn on. I replaced the projector lamp and now my set works. However, when it first comes on, it only stays on for about 2 minutes and then goes off. After another minute, it comes back on and works fine from then on. I don't believe this double power up can be any good for the lamp, but I don't know if the problem is the lamp or the set. These lamps run on about 65 volts, but require a short blast from 5000 volt source to fire up. At $200.00 a lamp, I don't want to go buy another!
May 30, 2006 | Sony Grand WEGA KF50WE610 50" Rear...
RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
101 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
