SOURCE: any ideas how to de restrict hyosung gv650 or
The most common way is move the throttle cable from position one to position two. Check to see if this method will work for you by watching the throttle mechanism at the engine while an assistant turns the throttle (engine not running). When the assistant can turn the handle no farther, see if you can push the mechanism open farther with your finger or a screwdriver. If you can, then you will be able to derestrict the bike by repositioning the cable.
