Can not load your program printshop 2009 - Computers & Internet
    Sergeant:
  • 226 Answers
What makes you think that PrintShop 2009 is somehow OUR program? Fixya doesn't produce software but it does produce techs to help with your software issues.
Print Shop is produced by the company here
Questions concerning specific issues about program installation or loading might best be taken there
Posted on Aug 24, 2008
Installing print shop 23 on windows 8.1 get framework incompatibility error. what should i do?
I now have PrintShop 23.1 up and running on my Windows 8.1. This is what worked for me:
1. First, RIGHT CLICK on the Printshop icon on your desktop, select Properties, click on Compatibility, and make the selection to run the program in Compatibility Mode for Windows 8. Click Apply, then OK to exit.
2. Double click the Printshop icon on your desk top to open Printshop. If it works - great! However, if it does NOT work, it means the .NET framework required to run the program was uninstalled or corrupted by the Windows 8.1 upgrade and needs to be reinstalled, so please do the following.
3. From your Control Panel, select Programs and Features; in Programs and Features, uninstall Printshop. (You get to the Control Panel by clicking on Settings in your desktop popout taskbar, usually on the right side.) 4. Check to make sure the Microsoft .NET framework is also uninstalled. If not, attempt to uninstall. If you have recently gone to Windows 8.1, it may be partly or fully uninstalled because the 8.1 upgrade might have removed (or damaged) part of it. If it will not uninstall, don't worry! Proceed . . . 5. Follow this step even if you see no sign of the .NET framework in Programs and Features. It is almost certain that you have debris from it on your computer because this is a known problem, and Printshop will not reinstall unless the debris is removed. THEREFORE, clean your computer by using the Microsoft .NET Framework Cleanup Tool found at the following link:
.NET Framework Cleanup Tool http://blogs.msdn.com/b/astebner/archive/2008/08/28/8904493.aspx
6. AFTER Printshop is once again installed, it will very likely NOT RUN unless you follow Step #1, above, to run it in Windows 8 Compatibility Mode.
Dec 20, 2013 | Broderbund The Print Shop 23 Deluxe
Broderbund print shop signature greetings older program won't install on my windows 8 pc
It will not install. That is why I kept my old xp computer. Some older programs will not run on Windows 8 and newer as they use apps to run the program. You can see of printshop has an app. As for installing the program using the cd...forget it.
Oct 15, 2013 | Broderbund PrintShop Signature Greetings...
I'm trying to install Printshop Zoom made for Vista/XP to my Windows 7 laptop -- it won't load properly after installation and tells me some of the files are missing and I need to run repair. I ran it 3...
Do you have a repair program? Like Macphee for example. These programs should be located on your task bar at the bottom right of monitor. The arrow pointing up is where these programs are located.
Nov 18, 2010 | Computers & Internet
Bought new computer. Cannot download my printshop
You might be trying to loading a 32 bit software packege to a 64 bit operating system. See it the store has a 64 bit version. Or you could upgrade the OS with the microsoft pro packege.
Thanks
Feb 20, 2010 | Broderbund Print Shop Deluxe Version 22...
I have an old printshop deluxe program and i am not able to load it into my new comp with vista.I love that program. I like the borders and i know how to use it.lol anyway it tells me my computer isnt...
This is one of the most common complaints with Vista - your old programs may not work. Your only solutions are to either buy a copy of Windows XP (what I would do, personally) and lose the Vista, or find a Vista-compatible version of Printshop. You can try this link, which Microsoft says it will update for free to make your old printshop compatable. If that doesn't work, there are 1000's of excellent free print programs at download.com here.
Apr 18, 2009 | Broderbund PrintMaster Platinum 16
Wasn't prompted to load image disc print shop pro deluxe 23
just go to control panel, add remove programs, select print shop (change) and select modify it will allow you to change content to hard drive and not cd.
Mar 19, 2009 | Broderbund PrintShop Pro Publisher Deluxe...
Program "Printshop CD Label Creator
the problem will solve after registration. go to the printshop web site and register your product.
Nov 26, 2008 | Computers & Internet
Install Printshop V.5 on a computer using Vista
The Printshop V5 program is supposed to run with Windows 98 or Me, therefore in order to use it with Vista or XP, you should open it using Compatibility mode--> Right click on the program icon--> properties-->Compatibility--> select Windows 98 or Windows Me
Oct 31, 2008 | Computers & Internet
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
